Closed Thread
Old Apr 28, 2013, 01:23 PM
United States, TN, Nashville
Joined Feb 2013
New X-4 FPV Fiberglass frame from HK
Looks nice but heavy...
http://www.hobbyking.com/hobbyking/s...ame_485mm.html
Just when you thought that all multi-rotor frames looked the same...the X-4 FPV appeared on the scene and is breaking all the rules! Featuring fiberglass construction with ply reinforcement, the X-4 is super rigid yet lightweight. Its high gloss paint job is impressive to look at making it really stand out in the air.
This is the first purpose built fiberglass FPV multi-rotor frame on the market today and is very unique. It features a very large internal canopy space allowing for mounting of all your electronic components including your FPV system. It even provides mounting grooves for LED light strips on the bottom of the arms making it perfect to setup for night flying as well!
The unique fiberglass body design is beautifully finished and fully enclosed. It even includes top and bottom motor covers to hide all of the wires making for a super sleek and futuristic look.
The X-4 arrives mostly pre-built and with all necessary hardware. You will simply need to add your own radio system, brushless motors/ESCs, multi-rotor control board and lipoly battery.
Features:
• Unique full-body fiberglass construction
• Integrated clear canopy dome for FPV camera use
• Beautiful high gloss paint job
• Full body design makes for easy orientation while flying
• LED strip mounting grooves
Specs:
Width: 485mm (motor shaft center to center between front/rear arms)
Length: 685mm
Frame weight: 730g (w/out electronics)
Requires:
28-XX or 35-XX brushless outrunner motor x 4
25~40A brushless ESC x 4
10~12 inch propeller x 4 (2 standard/2 reverse rotation)
Multi-rotor control board
2200~3000mAh 3~4S lipoly battery
4CH transmitter and receiver
stan11003 is offline Find More Posts by stan11003
Old Apr 28, 2013, 01:26 PM
Norway, Hedmark, Brumunddal
Joined Aug 2012
Check out this thread
http://www.rcgroups.com/forums/showthread.php?t=1879938
tormodnt is online now Find More Posts by tormodnt
Closed Thread
Discussion Hobbyking X-4 FPV Fiberglass Quadcopter Frame WOW neobot Multirotor Talk 79 Today 09:18 PM
Discussion New Y-3 Frame from HK Morphin Multirotor Talk 124 Apr 28, 2013 01:20 PM
Alert Stay away from the HK 235 PCB frame with built in ESC's FIRE HAZARD!!!! tc3wins Multirotor Talk 11 Mar 31, 2013 10:33 PM
New Product Blade 130X Carbon Fiber Main Frame X Frame from Microheli Howeroll Micro Helis 0 Mar 13, 2013 08:35 AM
Sold HT-FPV, 4 x FlyColor SimonK 30a ESC, and 4 x Sunnysky 2216 800kv motors Wingbreaker Aircraft - Electric - Multirotor (FS/W) 2 Feb 28, 2013 07:50 PM
