This thread is privately moderated by JimDrew, who may elect to delete unwanted replies.
Old Apr 05, 2014, 11:09 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
I use Artic Silver SCCE. This is a slow cure ceramic epoxy with very good W/mēK rating. But, more importantly is its high temperature handling. CPUs and such don't get to hundreds of degrees like a heat sink can with ESCs. The ceramic handles the heat transfer perfectly. Being ceramic, it's not electrically conductive at all. So, there is no danger of accidentally getting some on a PCB causing an issue.
JimDrew is offline Find More Posts by JimDrew
Old Apr 05, 2014, 12:08 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
a second for Arctic Silver. it's rather awesome.
theKM is offline Find More Posts by theKM
Old Apr 19, 2014, 04:20 PM
Lake Havasu, AZ
Joined Jun 2005
New updater (updater45.exe) has been released! Includes new firmware for the Nano, Nano II, RFU, and X10+ to support long frame rates used by radios using PPM data with more than 12 channels.
Nano II also now uses the port based outputs instead of channel based outputs. This means that every output can be reversed and/or have an offset position from center.
Changes made for all updates is available on the downloads page, located here:
http://www.xtremepowersystems.net/xd...are%20Upgrades
Don't forget that you need to perform a RESET a device has had its firmware updated!
Old Apr 19, 2014, 06:06 PM
The Villages, Florida
Joined May 2003
Jim,
You're the best ! Nice work.....
JuanRodriguez is offline Find More Posts by JuanRodriguez
Old May 08, 2014, 01:06 PM
Lake Havasu, AZ
Joined Jun 2005
Updater46
New updater (updater46.exe) has been released! Includes new firmware for the Nano II, RFU, X10+, and JR transmitter modules (fix for Taranis). The firmware for the X10+ adds DMSS X-BUS support.
Old Jun 11, 2014, 03:56 PM
Lake Havasu, AZ
Joined Jun 2005
Updater 48
A new version of the updater was released. This corrects a problem with SBUS2 mode with the X10+. Nothing else has changed.
http://www.xtremepowersystems.net/xdp/updater48.exe
Old Jun 11, 2014, 09:22 PM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Ran 4.8. Just to let you know it still says 4.7 at top of window.
GBR2 is offline Find More Posts by GBR2
Old Jun 12, 2014, 12:47 AM
Lake Havasu, AZ
Joined Jun 2005
Ok, I will look into that. It shouldn't!
Old Jul 20, 2014, 09:02 PM
Lake Havasu, AZ
Joined Jun 2005
Updater 49
This updater is a complete re-write for the Taranis' XJT mode support using our JR module. No other changes were made for other products.
http://www.xtremepowersystems.net/xdp/updater49.exe
