Old Sep 08, 2014, 01:11 PM
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Actually this is one question I know the answer for...
Sorry to tell you but your 6.4 G figure is far too low. Because of the speeds and tight turn radius our models can achieve the actual limit you want to use for structural stress should be 30-40 G's. We have had this discussion regarding G forces several times on another message board, and engineers have repeatedly shown us figures that reach or exceed these ranges, even using trainers as examples.
I have folded several flying wings where I used 30 G's as the design limit, twice when pulling out of shallow dives I would not have thought I was even close to this limit.
iron eagle is offline Find More Posts by iron eagle
Latest blog entry: The third time is a charm!
Old Sep 09, 2014, 11:18 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
My God, y're kidding !
things to consider ..
Let me do my same calculation on a classic spar setup, this G figure should be a good basis to compare to the carbon former G value ..
So then the G values are to be considered relative to eachother and not absolute .
vincent123 is offline Find More Posts by vincent123
Latest blog entry: FZ5: design phase
Old Sep 09, 2014, 01:36 PM
iron eagle's Avatar
Joined Jul 2007
I know a lot of DS guys have pegged the eagle tree limits of +/- 38 G's on a regular basis, they may have actually pulled way beyond that.
It's pretty dependent on speed and turn radius, I know many years ago they did a test on pattern ships that were pulling over +/- 25 G's back in the late 80's.
Old Sep 09, 2014, 02:14 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Ok, let's do a simplified math.
I just want to compare a usual classic spar design I always use, with the carbon former i plan to use.
1) The classic spar as a reference:
- Suppose you have only one spar system, with one spar top and one spar below, and webbing in between.
- the spars have 5x3mm cross section (15mm2 area)
- center spar to center spar distance is 25mm
2) Max compressive strength data of spar material: 40N/mm2
--> max compressive strength of spar = 40N/mm2 x 15mm2 = 600N
--> max moment on spar system = 600N x 25 mm = 15000Nmm
3) Take wing span of 1100mm and suppose that lift takes place a wing tip (=worst case approach), then the max allowable force at the wing tip would be = 15000Nmm /550mm = 27N.
Thus the max. lifting force would be 2 x 27N = 54N
Suppose the plane is 1.7kg heavy, the max G = 54N/(1.7kgx10) = 3.2G's
So what does this mean ?
That my classic spar setup, existing of 2 spars 5x3mm can pull about 3.2G's,
meaning the carbon former setup is stronger with it's max 6.4G's.
I cannot refer to the G's you mention, but only compare to the classic spar design I used several times before, which did fine.
Vincent
Old Sep 09, 2014, 09:54 PM
iron eagle's Avatar
Joined Jul 2007
The G levels I was talking about is the forces that can be generated during maneuvers at speed. During a discussion regarding the German Speed Cup rules in order for an aircraft to enter the course you have to make a turn with a radius of less than 50 meters at the 300+ mph these aircraft pull something like 50 G's. Now keep in mind these are extreme high performance airplanes but if you have a "quick airframe" and make a tight turn you can really pile on the G's quickly, granted this is more of an issue the faster you go. Your design has potential to be a fairly quick and nimble airframe that will generate G forces the like of a jet fighter rather than a Cessna. One thing I noticed you didn't add the strength the skin added when calculating your strength and it really adds a lot of strength we sometimes forget about.
I would say your delta probably has gone over 30 G's in some of the flying in your video. Either way what you have been doing has worked thus far. Heck that delta took a serious hit and came away with pretty minor damage.
Originally Posted by podavis View Post
I gave this some thought when the recent 'holding wings on with magnets thread' was active. I came up with a way to estimate it g's in a loop based on the classic formula centrifical_acceleration (aka radial acceleration) = velocity^2 / radius_of_turn, which is a variation of omega^2*r. Both of these are things we can estimate with practice, preparation and visual cues. A frame-by-frame analysis of video would be more accurate. A loop at the bottom of a vertical dive will test the plane's capability and can be performed square to the observer for better accuracy. I put together a little table of the solution for the the radial acceleration versus various velocities in feet/sec and turn radii in feet and the results suprised me, it took some pretty tight loops at speeds over 50mph to get past 10 g's. The table is at home, I'm eating my lunch at my desk right now, if anyone is interested I'll post the table when I'm home.
Old Sep 10, 2014, 12:13 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
What we all use frequently is a carbon rod, or 2 of them, for joining wings.
I'm surprised their strength is not so high:
http://en.wikipedia.org/wiki/Bending
Formulas:
SIGMA (y) = M* y / I
with:
- SIGMA(y)= stress at location y (N/mm2)
- M = bending moment (Nmm)
- y = distance to neutral bending line of cross section (mm)
- I = moment of area (mm4)
--> max bending moment is then:
M_max = SIGMA_max / y_max * I
I of cirkel cross section = 1/4 * pi() * r^4
Material data:
SIGMA_max for carbon = 720 N/mm2
Resulting max. bending moment:
Rod diameter = 8mm --> I = 201mm4--> M_max= 720 / 4 * I = 18.096Nmm
The same for the classic spar setup of before gives = 15.000Nmm
The same for the carbon former results in = 39.690Nmm
Summary:
- A carbon rod of 8mm is as strong as a classic spar setup
- A carbon rod is 2 times weaker than the carbon former.
Old Sep 10, 2014, 03:19 PM
iron eagle's Avatar
Joined Jul 2007
I think as a joiner we are using it as much for it shear strength as much as it bending strength, and a good portion of the compressive force on the wing is transferred to the body through the surface of the wing root itself. On my new plane I will probably be using dual joiners (top and bottom) and (forward and aft) to join the wing if I scale it up enough that they need to be removable because of the operational envelope and stresses it may encounter. But I really hope I can keep it down to a size where it is built all in one piece it will be much lighter. The final version is going to end up having retracts along with gear doors so it's probably going to have to be a bit larger than the first or second "test" airframes.
Of late I am leaning toward the classic spar setup using carbon as spar elements supported by a very strong shear web. Carbon is good under tension and using it as the top and bottom spar keeps the wings fairly rigid. I also like using two or three spar pairs in each wing as you saw me do with my delta. I can use much lighter elements for each spar since each is only carrying only a portion of the load a single spar setup has to endure. This method also makes it resist any torsional movement as well.
While the concept of a carbon tube or former in the center of the wing makes it fairly easy to keep everything aligned while building it isn't as strong as using smaller carbon elements within the classic spar/web configuration, at least that is my opinion. I used the tube/former in the center of the wing, and the classic spar with small carbon elements, and have found that the classic setup (using small carbon elements as far from the center of the airfoil as I can get them) is the strongest method by far.
If I have to use joiners for the wing I always have them as close to the spar as I can, if it is a swept wing I always make sure they at least tie in to the spar where they end.
Old Sep 11, 2014, 11:22 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
I can only confirm what you said.
Smaller components as far from the center as possible, gives the most strength for the smallest weight.
You saw my design of the plane, I chose an open design: the bottom is completely removable for battery and gear hatch. Meaning the cross section of the main carbon spar is nothing than about 10x3mm in the middle of the fuselage.
With my calculations i posted here, i strongly believe that the 10x3mm section is large enough, thanks to the massive carbon strength, to withstand the forces. And as compared to a classic spar setup, it should be ok.
Concerning the sheeting, tensile strength is low, as the sheet is devided at the wing root.
Compressible strength could be counted for, ok, but as a moment can never exist without the two forces, you have to count with the weakest element, thus skin sheeting can not realy be counted for coping with bending moments (but surely for torsion).
When do you plan to start building you ship ?
Old Sep 15, 2014, 09:55 AM
iron eagle's Avatar
Joined Jul 2007
I have got to get back on it after a couple of home repairs are finished, hopefully in the next couple of weeks.
Discussion How well would this canardish jet perform? (just design phase right now) GreenAce92 Foamies (Scratchbuilt) 5 Jan 16, 2009 07:14 AM
More shots with the Depron Dragon and Panasonic DMC-FZ5 CactusJackSlade Aerial Photography 7 Jun 12, 2005 12:46 PM
Yippee! Depron Dragon w/Panasonic DMC-FZ5 - maiden photos CactusJackSlade Aerial Photography 11 Jun 11, 2005 09:37 PM
Depron Dragon's new Panasonic DMC-FZ5 camera set-up - maiden this evening?! CactusJackSlade Aerial Photography 1 Jun 11, 2005 12:30 AM
New A/P Plane - Initial Design Phase Buzz_Man Aerial Photography 4 Apr 21, 2005 12:33 AM
