Old Sep 15, 2003, 08:50 PM
Lincoln Municipal, Nebraska, United States
Joined Mar 2000
Formosa power system choices
Well I went and did it! totally impulse purchase at my lhs. i bought a GWS Formosa...only $45.00 so what the heck!
I was wondering if I should fly it stock with the 350 system or go straight to another set up??
I have presently have available a spare Hacker b20l 15 that might be fun or another option I have is something I have never tried.. I have speed 280 BB just sitting around and I though that perhaps in a gws D gearbox it might work well...don't really know yet! Any ideas?
I do have a few TP 3S 2100 packs I use in my miniflash and G-ride or I could go the the Kans 950's ( I think I have a couple of dozen around here somewhere)
I just can't decide what do you all think? I KNOW how the Hacker would pull htis plane but I am really interested in your thought about the 280bb in a c or d gearbox.
thanks
Steve D
(by the way.... I am back!)
avdflyer is offline Find More Posts by avdflyer
Old Sep 15, 2003, 08:55 PM
Joined Mar 2000
One other thing...almost forgot...Looks like as with most of the GWS planes the mounts for retracts were included...perhaps I should consider retracts...once again what do you think?
Steve D
Old Sep 15, 2003, 09:09 PM
This space for rent
Steven D's Avatar
Peachtree City, Ga USA
Joined Apr 2000
I'm going to try my Razor 300 in a D box, on 3 e-tech 1200's or the new CBP 850 if I can get them. After weighing everything I think I can come in around 12 oz, and certainly under 13 (no landing gear) or 14 with gear. MotoCalc predicts 20 oz of thrust and 40 mph.
And If I don't like it I'll just drop the Hacke B20 15L in I've flown Jeffs with this set up and it does rock, I just want to try something different...
Steven
Steven D is offline Find More Posts by Steven D
Old Sep 16, 2003, 10:11 AM
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
Use the Hacker B20 and the TP 2100 pack.....it will blow you away.
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Sep 16, 2003, 11:03 AM
Joined Jul 2003
I found one too and it should be here today.
I am going to put my Astroflight 010 8-turn in it using a 5:33 GWS box and a 9x7 with TP 2100 3s1p. This combo makes my E-Starter wild so it should work pretty well.
I am going to try an Electron receiver. I am a little scared of the GWS at the speeds this should go. I will put HS-55 on the rudder and elevator and an HS-81 on the alerons.
Jeffro is offline Find More Posts by Jeffro
Old Sep 16, 2003, 11:07 AM
Fayetteville, GA
Joined Oct 2000
An HS 55 would work fine for the ailerons....I feel that an 81 is overkill....unless you don't have another 55 availabe.
Old Sep 16, 2003, 11:20 AM
Pittsburgh
Joined Jul 2002
Formosa....
I am using a Himaxx 4.3-1 in my Formosa, phoenix 25 ESC, FMA M5 receiver and three Cirrus 9gram servos. I didn't put retracts on the plane but I changed the wheel to smaller foam ones. I didn't use the tailwheel either. I just glued the extra control horn as a tail skid. The plane would make any inside or outside maneuver but relatively small to my slimer pattern planes. I don't think the batteries are up to the task since I am using the Parkflyermotors 650 Mah NiMhs. I have some Kans on order and I hope they will be here by the weekend. I've tried the APC 9x6E and 10x4.7SF and I like the first one much better.
Sonneschein is offline Find More Posts by Sonneschein
Old Sep 16, 2003, 08:36 PM
Joined Jul 2003
I went with three HS-55s. AUX is 14.4 oz. Maiden tomorrow AM.
Cool Formosa Power System SHOCKSTRUT Foamies (Kits) 28 Jun 15, 2005 06:54 PM
Question Formosa power system question nieves50 Power Systems 1 Apr 14, 2005 01:37 PM
Question Formosa power system question nieves50 GWS (Grand Wing Servo) 0 Apr 14, 2005 01:01 PM
Rant Formosa Power System Question Bill Lesko GWS (Grand Wing Servo) 11 Mar 16, 2005 06:50 AM
Formosa Power System Question Bill Lesko GWS (Grand Wing Servo) 12 Feb 24, 2005 10:00 AM
