Old Oct 25, 2013, 02:35 PM
paulywood's Avatar
United States, CA, Sacramento
Joined Feb 2003
Help!
CC BEC 10 amp, Handle 12 Servos ???
Will CC 10 amp BEC handle up to 12 Servos, some digital, some not.
http://www.castlecreations.com/suppo...user_guide.pdf
http://www.castlecreations.com/products/ccbec.html
Thanks, Paul.
paulywood is offline Find More Posts by paulywood
Old Oct 25, 2013, 08:32 PM
Corner Ketch, DE
Joined Sep 2005
Hey Paul,
There is no way I would recommend that set up
Use two Batteries in a redundant set up so if you lose one pack you still have enough current to fly
You lose the BEC and your done.
I love Castle and beta tested both for use in sport planes
Did burn up one of the 6 s due to a high capacity Lipo
Burnt a hole in it
Stick with the tried and true set ups
NOBS batteries has some nice a123 packs that I love
Charlie
creeve is offline Find More Posts by creeve
Old Oct 25, 2013, 08:45 PM
paulywood's Avatar
Joined Feb 2003
Originally Posted by creeve View Post
Hey Paul,
Burnt a hole in it
Charlie
But don't I have to bring the voltage down to 5.5 V from the 6.6 V pack with a BEC?
Thanks, Paul.
Old Oct 25, 2013, 09:01 PM
Corner Ketch, DE
Joined Sep 2005
Play it safe and use a Smart Fly or power box
Go over to RCAT there is lots of info there on set ups
Len will chime in here I'm sure
Charlie
Old Oct 25, 2013, 09:25 PM
Nothing like a good WOODIE!
cooper998's Avatar
USA, DE, Newark
Joined Jun 2005
Paul,
You did not mention what type of radio you are using, most newer systems from Futaba and JR can handle up to 7.2v without problems (check your specs to be certain), it's just the servos that limit voltages. There are other options to a BEC to reduce voltages, JR and Spektrum both sell regulators and many aftermarket companies also have them,
Tony
cooper998 is offline Find More Posts by cooper998
Old Oct 25, 2013, 09:37 PM
paulywood's Avatar
Joined Feb 2003
Originally Posted by cooper998 View Post
Paul,
Tony
I have a Futaba 2.4 8FG 14 channel.
I use that BEC above to reduce voltage to the servos not the receiver on other F5J's I have.
Now I have 1/4 scale Ventus 2cx 4.5m with 12 servos.
I wanna run a large LiFe pack 6.6v 3500 mAh or larger for the servos, Or a Lipo 7.4v 5000 mAh and have to reduce voltage to the servos only.
Which options are best, with in $$ reasons ?
Thanks, Paul.
Old Oct 25, 2013, 10:48 PM
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Paul, the voltron voltage regulator. We had a thread in the F3X forum where basically every voltage regulator on the market was stress tested by ChrisB. The Voltron was the clear winner. They are only $30 or so.
http://www.rcgroups.com/forums/showt...t=voltag+regul
With all of that said, there are plenty of servos that can handle 6.6V without a regulator.
Avaldes is online now Find More Posts by Avaldes
Old Oct 26, 2013, 01:36 AM
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Paul,
What is this set up for? I use 6V gel Lead Acid battery for my Blanik L-13 set up ( still need another 4 lb of lead to balance it!). 4.5 Amp, no regulator, just run it off the battery directly. Best yet, the gel battery is $13.00!!
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Oct 26, 2013, 11:57 PM
Scale Glider Guider
Airbus's Avatar
Richmond, BC. Canada
Joined May 2003
I agree with A123 packs. You make a big investment in the airframe so it's worth it to have rock solid power for your good quality radio setup.
And remember to use large gauge wire for the batteries too.
Airbus is offline Find More Posts by Airbus
Old Oct 27, 2013, 01:44 PM
Aerotow and sloping Holland
MaartenX's Avatar
Joined Mar 2012
With all of that said, there are plenty of servos that can handle 6.6V without a regulator.[/QUOTE]
Yup, use LiFePo instead of LiPo.
No self discharge and they don't mind a deep discharge.
Don't worry about the 6,6V, your servos will be able to handle that.
Remember, with older servos we have been using 5 cell niXXX for years.
A freshly charged 5 cell NiMH pack is well over 7 V.
I have never had a servo burn out on that ( nor on a 6,6V LiFePo pack without regulator)
MaartenX is offline Find More Posts by MaartenX
Old Oct 27, 2013, 05:40 PM
Vintage wood is the best!
SZD16's Avatar
In a house
Joined Sep 2002
If you use MKS wing servos in your plane....DO NOT FOLLOW THIS ADVICE!
MKS limits voltage to 5.5v for their wing servos and some others.....if you power them with a LiFe back you will smoke all of your $90 servos.
SZD16 is offline Find More Posts by SZD16
Old Oct 28, 2013, 01:16 PM
MaartenX's Avatar
Joined Mar 2012
I stand corrected. Thank you Pete.
If you want to play it safe, use a regulator or powerbox.
Allways check the specs of your servos.
Old Oct 28, 2013, 02:34 PM
paulywood's Avatar
Joined Feb 2003
Thank You all.
I be using a (2) LiFe Batteries, 2600 mAh with a voltron regulator & Smart Fly BatShare.
thanks, Paul
Sold Castle Creation Thunderbird ESC and CC 10 Amp BEC eroeder Aircraft - Electric - Power Systems (FS/W) 0 Oct 22, 2013 08:37 PM
Sold NEW Castle CC BEC Rx Battery Eliminator 10 Amp output 6S max input 4.8-9 volt output shooboy Aircraft - General - Radio Equipment (FS/W) 10 Sep 08, 2013 01:53 PM
Sold SOLD New CC 10 Amp BEC Merritt Aircraft - Electric - Power Systems (FS/W) 2 Aug 07, 2013 01:44 PM
Sold CC BEC 10 amp seefest Aircraft - General - Radio Equipment (FS/W) 1 Jan 26, 2013 10:30 AM
Discussion CC 10 amp bec and JR 821 servos Harry H Power Systems 6 Mar 03, 2011 10:53 PM
