Old Jun 11, 2013, 04:57 PM
intheairagain's Avatar
Joined Jun 2013
60" E-powered Sbach 342, Nitroplanes??
Hey guys, new to RCG and getting back into R/C after a few years break. I am going to give electrics a try, so I purchased one of these off of that well known auction site.
Item no. 151061321042
I have been searching the web, but have found little info on this plane. But for $170 bucks, I couldn't resist. I am very impressed with the Sbach. Constuction seems to be fairly light and well built. The covering has very few wrinkles. The fiberglass cowl and wheel pants are ligth, and very nicely painted.
The only items that I most likely won't use, are the aluminum landing gear and wing tube. I will replace those with aftermarket carbon products.
Any advise, comments or suggestions would be greatly appreciated. What would be a good motor/esc combo? Batteries? I am going to use either the Hitec HS-225mg's or the 5245's.
Thanks in advance for any help.
intheairagain is offline Find More Posts by intheairagain
Old Jun 11, 2013, 10:05 PM
Fly for fun
7oneWo1f's Avatar
Joined Nov 2011
Congratulations. I would go with 5245s or 7245s depending on how fast and agressive you will fly. The 5245s will be fine...I still use them all the time on 60" planes.
Is that dual elevator servos on this plane? If so, the 5245s might be overkill there.
Too bad about the landing gear and wing tube.
You might want to keep the landing gear for the first few flights though, because aluminum seems to help absorb energy during bounced landings.
I would go with 6S 3300 mah to 3800 mah 25c or higher batteries, so that you can use them in the inevitable next plane. For a motor, I'd look at something about 480-500 kv, an 80 to 90 amp esc, and fly with a 16x8, 16x7, 15x8, or 15x7 prop. I have had success with Gens Ace 25c batteries, but I have lately been liking revolectrix 60C batteries. I like the torque 4016T/500 kv MKII motor a lot. It has a cooling fan built in and has tons of power. Others use some other motors but I haven't yet experienced them.
7oneWo1f is offline Find More Posts by 7oneWo1f
Latest blog entry: Powerpoles explained by Oz
Old Jun 12, 2013, 05:11 AM
Burke, VA
Joined Sep 2009
Nothing wrong with aluminum lg. I have actually replaced the cf gear on a couple of my planes and put on aluminum lg. I fly from really rough soccer fields and the aluminum really makes a difference on durability. Now if you have a nice smooth area for takeoffs and especially landings the cf gear are fine. Other wise 7Wolf is pretty spot on with recommendations. Good luck, keep us posted on how it goes.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jun 12, 2013, 07:00 AM
Joined Jun 2013
Thanks guys for the helpful info. I will probably use the aluminum gear after thinking about it. The field I will be flying from is all grass. It looks nice and smooth, and the club takes good care of it, but its grass none the less.
For the batteries, motor and ESC, where is a good place to go for those items? (I'm sure I opened up a can of worms with that question). I unfortunately don't have an unlimited supply of money, so less expensive is better.
Thanks again for the help.
Old Jun 17, 2013, 09:03 AM
A tale of two slickies
0gravity's Avatar
United States, IL, Chicago
Joined Feb 2010
www.hobbyking. com
look for at the RHINO series. Great to meet you yesterday!
0gravity is offline Find More Posts by 0gravity
Old Jun 17, 2013, 05:10 PM
Joined Jun 2013
Thanks 0gravity, it was a pleasure meeting you. Thanks so much for the great info. Can't wait to get this in the air so I can go flying with you.
Old Jun 17, 2013, 05:49 PM
Crash test pilot
United States, KY, Louisville
Joined Mar 2013
For the torque 4016T/500 kv MKII go to http://www.extremeflightrc.com/
I'd like to hear how the plane does.
Are you flying 3d or Sport?
Dracolyth is offline Find More Posts by Dracolyth
Old Jun 17, 2013, 08:06 PM
Joined Jun 2013
I am going to use this plane to start learning 3D. At least that is the plan right now. It all depends on how it flies.
I looked at the tourqe motors at extremeflight, and they are out of stock right now. But I will keep looking.
Old Jun 17, 2013, 09:08 PM
Crash test pilot
Joined Mar 2013
I've never seen a bad review on em....
Have yet to use them myself but hear nothing but great things about them.
This is worth a read, the airframe review won't help you but the electronics part might help some.
http://docaustinextreme.blogspot.com...rfect.html?m=1
Old Yesterday, 05:04 AM
Burke, VA
Joined Sep 2009
Check out the Exceed Rocket 4120 series from HobbyPartz. They are available in several KV's and I have been using one on my EF 60" MXS and it's got a ton of power and runs cool as a cucumber. I can't vouch for the durability of this particular one, I only have about 30 flights on it so far. But I do have a couple in other sizes In other planes and have flown the heck out of them with no problems.
Old Yesterday, 05:33 AM
0gravity's Avatar
Joined Feb 2010
I loved my torque motor in my 58" katana. I had 1300 watts of power and it was a blast. This motor would do up to 1400 on a 6 cell:
http://www.headsuphobby.com/Firepowe...otor-E-550.htm
The 60 they have looks really good too.
Old Yesterday, 03:24 PM
Joined Jun 2013
Now I have another question, the manual that comes with this plane is on a small 3-1/4" disc. The center hole is about 19/32". It won't fit in the cd-rom on my computer. Where can I take it, to have the manual printed up?
New Product Dynam Sbach 342 available now at Nitroplanes.com xplaneguy 3D Foamies 1644 May 28, 2013 08:50 AM
Help! Hobby King Sbach 342 1400mm and FMS Sbach 342 Yami28 3D Foamies 1 May 21, 2013 04:00 AM
Sold E-Flite UMX Sbach 342 3D (AS3X) with spares kellymacdaddio Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2013 10:36 PM
Discussion Help with power train setup for Sbach 342 drewsdesign Power Systems 0 Feb 11, 2013 09:50 PM
Sold E-Flite UMX Sbach 342 3D (AS3X) K_B Aircraft - Electric - Micro & Indoor Airplanes 4 Feb 03, 2013 12:54 PM
