Old May 14, 2006, 03:43 PM
clarinetjd is offline
Find More Posts by clarinetjd
West Chester, PA
Joined May 2003
Question
Slowstick on GWS floats - setup questions
For those of you who have successfully set up your Slowsticks with GWS floats:
1. Did you use the stock gear wire for the front gear? (ie. just remove the wheels)
2. What did you use for the aft gear? How did you attach it to the plane?
Thanks for your help.
clarinetjd is offline Find More Posts by clarinetjd
Old May 14, 2006, 05:45 PM
jimsp is offline
Find More Posts by jimsp
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Initially I used the standard landing gear to attach the front. Later I made a new landing gear with a little wider stance to give the SS more stability on the water. For the rear I used 1/16 music wire and bolted and glued it to a 1/16 plywood plate. This was held to the fuselage using a high strength Velcro like material I bought at Radio Shack. This stuff is so strong I use it to attach a camera to the Slow Stick.
jimsp is offline Find More Posts by jimsp
GWS Tiger Moth 400 on GWS Floats ???? David A Ramsey Parkflyers 24 Oct 20, 2004 12:56 AM
SS on GWS floats jacob Parkflyers 1 Oct 04, 2004 08:04 AM
Teddy on GWS Floats vkmaynard Foamies (Kits) 1 Aug 13, 2004 08:36 PM
Slow Stick on GWS Floats - Pics & Video TStokes Parkflyers 1 Jul 25, 2004 10:56 PM
Mr. Lin - info on GWS floats? DennisG Parkflyers 0 Jun 20, 2003 10:29 AM
