Old Aug 04, 2005, 01:54 PM
matrix66 is offline
Find More Posts by matrix66
Joined May 2005
GWS 4ch. receiver connections?
OK, before I make a mistake, what are the correct connections on a GWS RP4II (F) receiver? The 4 connectors are marked 1,2,3,and4/B. I am assuming 4/B is the battery connection. This is the stock radio system for my new GWS Beaver, and with all the paperwork that came with it, nothing actually shows this receiver connections for a 4 channel receiver. Schematics for 6 channel, and lots of written instructions, but not in the language I can read! I did notice that some other GWS receivers use channel 1 for battery, and some used the highest channel (or at least thats what the diagrams showed).
Matt
matrix66 is offline Find More Posts by matrix66
Old Aug 04, 2005, 02:07 PM
gadget98 is offline
Find More Posts by gadget98
Santa Cruz, CA
Joined Jan 2005
The battery terminal is not used b/c the receiver will get battery power from the speed controller connection(throttle). The throttle is channel 3 I think. Channel 1 is for rudder, Channel 2 is for elevator, Channel 3 is for throttle. If you have aelerons, then they go on channel 1 and the rudder is channel 4. What you need to do is plug the speed controller in to channel 3 and then another servo in to 1 or 2. Then test the operation of your transmitter and then plug the servos in so that the controls work correctly (left stick up/down controls throttle, right stick up/down is elevator, right stick left/right is aelerons or rudder)
-Richard
gadget98 is offline Find More Posts by gadget98
Old Aug 04, 2005, 02:15 PM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
I just set one up the other day. Just as the last guy said
3 channel setup
Channel 1 = Rudder
Channel 2 = Elevator
Channel 3 = Throttle
Channel 4 = Battery
4 channel setup
Channel 1 = Ailerons
Channel 4 = Rudder/Battery
Generally you don't need the battery as it gets power thru the speed controller connected on channel 3.
You can see all of the GWS documentation here
L0stS0ul is offline Find More Posts by L0stS0ul
Old Aug 04, 2005, 02:25 PM
matrix66 is offline
Joined May 2005
Thanks guys. ESC on ch.3 makes sense. I will have to look again, but I swear that the diagrams showed ESCs connecting to channel 1 on some of the GWS receivers. I did not look to see what the application was.
Old Aug 04, 2005, 03:23 PM
Cubber is offline
Find More Posts by Cubber
Naturally altered
Joined Feb 2005
Gws receivers are pinned out the same as their intended Radio system. What is written above would work for i would think for Futabas but JR versions are pinned out the following
1-Throttle
2- Ailerons
3- Elevator
4- Rudder
Cubber is offline Find More Posts by Cubber
Old Aug 04, 2005, 03:31 PM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
All correct above. Its more to do with the transmitter sequence than the reciever.If not using an esc, channel 4B is used with a Y connector with the batt. on one wire and the rudder servo on the other, assuming it's Futaba.
flypaper 2 is online now Find More Posts by flypaper 2
Old Aug 04, 2005, 11:37 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
It is solely dependent upon the transmitter. The receiver only separates and decodes the various signals and sends them out to their respective receiver outputs. It has no way of knowing what set of signals does what, nor does it care.
What transmitter are you using?
All the positive pins and all the negative pins are tied together - it matters not which set of pins you use to supply power.
BEC is offline Find More Posts by BEC
Sold NIP GWS 4ch Receiver 'J' w/xtal ch. 51 kwilliby Aircraft - General - Radio Equipment (FS/W) 10 Feb 07, 2006 11:26 PM
For Sale NIP GWS 4ch Receiver kwilliby Aircraft - General - Radio Equipment (FS/W) 1 Oct 18, 2005 08:20 PM
FS - GWS 4Ch Receiver w/crystal ch38 & GP C-10 Speed Control bhenry Aircraft - Electric - Airplanes (FS/W) 3 Sep 18, 2004 12:41 AM
FS: GWS 4ch receiver MrFlyer Aircraft - Electric - Airplanes (FS/W) 8 Dec 12, 2003 08:54 PM
f/s gws 4ch receiver gregg f Aircraft - Electric - Airplanes (FS/W) 1 Sep 18, 2002 11:01 PM
