Old Today, 01:06 PM
samvella is offline
Find More Posts by samvella
Joined Jul 2015
Aircraft from scratch.
Hi there,
I would like to build my own aircraft but really am not sure where to get started on the electrical side of things.
I am building the air frame from scratch but I am not sure what electrics to buy.
currently I have seen a transmitter / reciver that looks ok:
http://www.ebay.co.uk/itm/RC-Helicop...item1c4800b254
but I really do not know where to get started with the rest of it, I and to make an aircraft cheaply,
please can you provide links to batteries escs and motors that would all work together as i do not have much of an idea, thanks
samvella is offline Find More Posts by samvella
Old Today, 01:32 PM
Rhea is offline
Find More Posts by Rhea
STOP! I can't take any more.
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Details
It may help if you would give some details as to what you are planning.
How can anyone help if you donít make your question clear?
You have edited your first post but it still doesnít make it any clearer.
Choice of batteries will depend on the size of the aircraft.
Motor and ESC will also depend on the size.
Tell us what you are doing and maybe we can help.
This is just one of many http://www.hobbyking.com/hobbyking/store/index.asp.
Also look at all of the ad banners that show up on the top of these pages.
Rhea is offline Find More Posts by Rhea
Old Today, 01:51 PM
samvella is offline
Joined Jul 2015
you are really nice, thanks
Old Today, 02:43 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Originally Posted by samvella View Post
Hi there,
That radio is fine - I have used one with no problems .
There is a forum here on RCG for scratch built foam planes , many good planes to choose from .
http://www.rcgroups.com/foamies-scratchbuilt-428/
The scratch built plane I use to teach first time flyers is the EzFly , a very good stable flyer and the motor/prop are protected in a nose first crash . If you want to build one , I can help you with electronics choices , etc .
Here is one of my EzFlys that I use to teach first time flyers :
Copy of EzFly with under-cambered wing (1 min 57 sec)
balsa or carbon is online now Find More Posts by balsa or carbon
Old Today, 04:12 PM
Joined Aug 2010
Here are the PDF plans for the EzFly :
http://www.rcgroups.com/forums/showa...6&d=1334660760
You live in the UK ? I believe most people outside the USA/Canada build their foam planes out of Depron , so see if you can get some 6mm thick Depron sheets .
You can get electronics at HobbyKing , UK warehouse . Here are links to the electronics that will work for a standard size EzFly .
Motor : http://www.hobbyking.com/hobbyking/s...arehouse_.html
ESC ( Electronic Speed Control ) :
Servos ( you'll need two ) :
Propeller :
Motor connectors ( connects motor to ESC ) :
Battery connector ( connects battery to ESC ) :
Battery ( get as many as you can afford , probably about 15 minutes flight time per battery ) :
Battery charger :
Old Today, 04:44 PM
samvella is offline
Joined Jul 2015
thanks man. looks awesome!
in regards to the motor etc, will that be enough to power another plane if in the future I was to change air frame ? or is this a small motor for a slow moving aircraft?
Old Today, 04:56 PM
Joined Aug 2010
That motor ( 1500 KV ) has plenty of power - but if you want a little more , here is the same motor with a slightly higher KV ( 1700 ) . KV is RPM's per volt , so the 1700 will rev higher than the 1500 .
Here is one of my planes with the 1700 KV motor - plenty of zip !
Simplest simple delta (1 min 20 sec)
Old Today, 05:46 PM
Rhea is offline
Rhea's Avatar
Joined Oct 2008
I must have misread your inquiry thinking you wanted something to complete an aircraft you had built or were building.
If you want to see other offerings look at this site. http://flitetest.com/
They have a lot of info for beginners as well as kits and free plans for all kinds of planes.
Discussion Scratch building from a kit build plan Taxus812 Balsa Builders 17 May 18, 2015 10:36 PM
Discussion yet another noob first build from scratch stutter Scratchbuilt Multirotors 4 May 12, 2015 10:36 PM
Discussion Quadcopter from scratch pir4t Scratchbuilt Multirotors 2 Apr 28, 2015 03:04 AM
What are the basic rules for creating an aircraft from scratch Mat Modeling Science 11 Oct 10, 2004 07:47 AM
Designing an aircraft from scratch - How To? jzen Power Systems 9 Jun 08, 2001 05:45 AM
