Old Dec 12, 2014, 08:46 AM
Trey4U is offline
Find More Posts by Trey4U
United States, AL, Daphne
Joined Nov 2009
I Need Templates
I posted this in the Classifieds but figured I'd put it here as well:
Juzwuz is busy until some time next year but I'd like to get some laser cut templates so I can start cutting cores. PM me for details of what I need then you can give me a price.
Trey
Trey4U is offline Find More Posts by Trey4U
Old Dec 12, 2014, 04:13 PM
Trey4U is offline
Joined Nov 2009
I'm looking at G_T's SynerJ foil and Drela's AG foils. I can't seem to find the thickness of Drela's AG40, AG41, AG42 and AG43. Anyone know the thicknesses?
Trey
Old Dec 12, 2014, 06:22 PM
GarryOgilvie is online now
Find More Posts by GarryOgilvie
Professional sink locator
United States, NC, Greenville
Joined Dec 2012
Profili has a template tool. Have you looked at it?
GarryOgilvie is online now Find More Posts by GarryOgilvie
Old Dec 12, 2014, 06:58 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
If you take this free program:
http://www.xflr5.com/xflr5.htm
And these airfoils
http://www.charlesriverrc.org/articl...t-airfoils.htm
....and these airfoils
http://m-selig.ae.illinois.edu/ads/coord_database.html
That should keep you busy.
When I get home if you don't have the answers I can go to Profili or XFLR5 I can get you the specific info you requested.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Dec 13, 2014, 09:53 AM
Red Merle ALES
Joined Apr 2002
Trey
AG40-02f
Max Thickness 8.00% at 27.8% of the chord
Max Camber 2.04% at 39.1% of the chord
AG41-02f
Max Thickness 7.72% at 26.4% of the chord
Max Camber 2.01% at 37.7% of the chord
AG42-02f
Max Thickness 7.31% at 25.0% of the chord
Max Camber 1.98% at 34.9% of the chord
AG43-02f
Max Thickness 6.54% at 22.2% of the chord
Max Camber 1.84% at 34.9% of the chord
Old Dec 13, 2014, 01:46 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Trey,
This tip may be superfluous, but will offer it in case it is not obvious.
When you get the templates cut, make sure they are cut with proper hot wire cutting entry and exit ramps and not just a sharp turn where the chord line intersects the airfoil shape.
This discovery was a huge breakthrough in hot wire cutting for me. No sanding at the trailing edge required, and only a slight amount required at the leading edge.
Further details provided if necessary.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Dec 13, 2014, 02:32 PM
Trey4U is offline
Joined Nov 2009
Originally Posted by Curtis Suter View Post
AG40-02f
AG41-02f
AG42-02f
AG43-02f
Thanks! I got XFLR5 but couldn't figure out how to import Drela's coordinates. Got Profili which had some of Drela's foils but not the ones I wanted. Couldn't figure out how to import coordinates there either. Thanks again.
Originally Posted by Jim.Thompson View Post
Trey,
Yep, learned that the hard way over 20 years ago.
Trey
Old Dec 13, 2014, 02:48 PM
Joined Aug 2008
Trey
Very good!
Old Dec 14, 2014, 11:09 PM
flyingfever is offline
Find More Posts by flyingfever
Joined Jul 2009
Trey,
What do you mean by "proper hot wire cutting entry and exit ramps". I know there's a ramp or lip at the leading edge to start and aat trailing edge to exit, but a picture or explanation would really help. Do you use 2-piece airfoils, 1 for bottom, and the top that rests on the bottom one for the toptop, or a 1-piece airfoil cut out, and held on with tacks, etc.? Thanks.
flyingfever is offline Find More Posts by flyingfever
Old Dec 14, 2014, 11:31 PM
Joined Aug 2008
Ok FF, I will explain. I might also get time to do a drawing tonight. I could post that later.
But here goes:
Leading edge shape when drawn ex Profili2 or similar, will show a sharp change of direction from the horizontal chord line to the curve of the leading edge of the airfoil. In both directions of course. Up for the top and down for the bottom.
This can create a problem with getting the wire to start moving through the foam.
A simple small radius curve of lets say, 6 - 10 mm (depending upon the size of the templates concerned) at this point will alleviate this problem. The curve will intersect the chord line and the beginning of the airfoil shape. This leaves a very small protusion that will be sanded off later.
The same curve is made on both top and bottom templates. Yes, I use separate top and bottom templates. I did try using a bottom template and an airfoil shaped one that sat on top for the top cut, but abandoned it after lots of problems with the wire going between the two instead of up and over for the top cut. Besides, it did not allow for the curve, mentioned above.
The Trailing Edge;
This is simple. The line of the last 1/3 of the airfoil is continued on instead of transitioning to the horizontal chord line. No sharp change of direction, which means that there is no problems created due to the inevitable wire lag. Done this way, it results in cores that need no sanding at the TE.
I hope that is reasonably clear.
Old Dec 15, 2014, 07:02 AM
Red Merle ALES
Joined Apr 2002
This is how I do it.
http://www.rcgroups.com/forums/showp...2&postcount=21
Curtis
Old Dec 15, 2014, 12:10 PM
Joined Aug 2008
The exit ramps appear to be on the chord line Curtis, at least that is the case in the top template, view # 137.
That will involved a change in direction of the wire at the templates. The wire lag will mean that it will not follow faithfully at the middle and so create some slight thickening there.
See my description above re how and why I avoid this.
I see that you have provided a "ramp" entry at the LE though.
It seems I will have to draw that diagram or diagrams.
Old Dec 15, 2014, 12:34 PM
Red Merle ALES
Joined Apr 2002
There is a 1/4" of foam at the trailing edge (TE) that is not used. The vertical line on the template at the trailing edge is the actual end of the wings TE. This way when the wing is done and I'm transporting the wings in the foam cores there is a 1/4" of foam to protect the fragile trailing edges.
I also like the foam core to be a smidgen shorter than the actual chord of the wing so that once bagged the top and bottom skins are touching one another.
Curtis
PS By the way, I measure with eyeballs and not a micrometer. In other words I'm more of what works than what the exact measurements are supposed to be.
Old Dec 15, 2014, 12:57 PM
Joined Aug 2008
I appreciate that this is a bit hard to communicate without pictures.
Maybe this diagram will clarify.
Please observe the trailing edge part of the template. There is no change of direction to create distortion due to the inevitable wire lag.
Old Dec 15, 2014, 01:20 PM
Joined Aug 2008
No ramps.
This diagram is one of a template ex Profili2 without entry and exit ramps. Note: the line at the trailing edge does change direction and so creating thickening effect around the middle of the panel at the TE.
Discussion Need wing rib templates 1/10 f15a george scarlett Balsa Builders 0 Jun 15, 2014 02:48 PM
Alert I really need a template for the shocky firewall Pattern Kid 3D Flying 4 Oct 05, 2004 02:56 PM
Question Estarter fuse templates needed for Beaver GreatGazoo GWS (Grand Wing Servo) 3 Apr 25, 2004 10:31 PM
Need template for 120 Swashplate Servo Installation jnyoun Micro Helis 2 Oct 21, 2003 02:19 PM
Need foam wing template help! zbrubaker Foamies (Kits) 3 Jul 01, 2003 01:05 PM
