Old Mar 05, 2014, 11:20 AM
rodsmith123 is offline
Find More Posts by rodsmith123
Major Electron Addiction
USA, NC, Wilmington
Joined Aug 2006
Originally Posted by aerofundan View Post
Hi Rod, sounds to me like something is wrong, are you sure you are using a Series harness or a 6s pack? with the 15x8 it should be well over 1000 watts! If not i suggest that you send a video to support@pa and they will analize and tell you whats wrong! The PA system is a true plug and play system, if you are not getting the power its a problem with the battery, or esc or motor for sure. Anyway contact PA and they will help you figure it out. Just in case Thrust motors and Quantum speed controllers have a full 2 year warranty!
The pack is a 35-70c 6s 3300. I used an Eagle tree data logger for the test run and had good voltage under load.
rodsmith123 is offline Find More Posts by rodsmith123
Old Mar 05, 2014, 12:55 PM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Originally Posted by gtimmons View Post
Well the tech support guy from Vexa Servoxciter called me today. He comfirmed that the unit will not program the servo, (not save a custom center). Have to use a Hitech programmer for that. You can save your recievers center signal to the Servoxciter and have that signal sent to the servo. This makes setup easer but looks like I will have to buy the Hitech programmer.
Thanks for everyones help and suggestions
Big G
Just want to be sure you also understand that the Hitec servo programmer only programs Hitec digital servos from the 5XXX and 7XXX series. It will not program servos from another manufacturer nor will it program Hitec analog servos. If your servos are not Hitec and they are programable you need to buy the same manufacturer's programmer. I could not find a post stating what servos you were using and seeing as you already bought one tool that didn't do what you want just wanted you to know and not buy another tool that will not work either.
But Aerofundan is right you don't really need to reprogram the servo center a good radio will sort that all out.
camoy is offline Find More Posts by camoy
Old Mar 05, 2014, 08:41 PM
camoy is offline
I can't fly
camoy's Avatar
Joined Dec 2006
Can someone tell me the weight of the quantum 70 amp ESC? Trying to determine if an ESC I already have will work.
Old Mar 06, 2014, 09:37 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
I don't know the exact weight, but compared to say a normal CC 100, its waaaaay lighter!
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Mar 06, 2014, 01:33 PM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Checked PA's site and it doesn't specify weight of the Quantum 70, but if you compare the YEP esc's an 80A is 70g (including wires) and the 60A is Weight: 63g (including wires)
So I guess somewhere in that region.Just to give you an idea,but knowing PA it's probably 50g
chop stiX is offline Find More Posts by chop stiX
Old Mar 06, 2014, 01:36 PM
camoy is offline
I can't fly
camoy's Avatar
Joined Dec 2006
Thanks but not looking to use a castle creations 100
Old Mar 06, 2014, 05:12 PM
AndreasHeger is offline
Find More Posts by AndreasHeger
PA, WMPF & HE Team Pilot
AndreasHeger's Avatar
United States, OH, Amelia
Joined Apr 2008
good guess - it's 67 gramm
AndreasHeger is offline Find More Posts by AndreasHeger
Old Mar 06, 2014, 05:40 PM
camoy is offline
I can't fly
camoy's Avatar
Joined Dec 2006
Awesome thanks for posting that AdreasHeger
Looks like you just got a new toy in time for spring flying.
Old Mar 07, 2014, 09:39 AM
aerofundan's Avatar
Panama
Joined Jul 2005
So who is enjoying their ADXL??? I will be getting one soon now that the weather is starting to get better here! It has been very windy for the past months, and winter is about to start here (which means perfect flying weather, very little wind and not so high temps)
Site Sponsor
Old Mar 07, 2014, 03:54 PM
ckleanth is online now
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
@ guys at PA
can I ask for a favour please?
I'm seriously considering buying an adxl but only to convert it to gas. I'm planning to powering it with a 4 stroke petrol saito (or equivalent)
If possible can you please take one adxl without motor and motor cage and measure how much weight you need to balance considering (with rx, servo, bec and a 2s 1800-2000mah lets say 300 gram in the fueselage as further back as you can safely place them) and assuming I can fit a tank at cg?
Is the covers fuel resistant?
(If easier can you guys consider making a gas adxl version?
ckleanth is online now Find More Posts by ckleanth
Old Mar 07, 2014, 04:02 PM
faldomak is offline
Find More Posts by faldomak
Croatia, City of Zagreb, Zagreb
Joined Oct 2012
Winter is about to end here (funny how we see winter differently) have not flown my XL (anything actually) for a month now - constant rain and strong winds. But this weekend should be fine spring weather, no wind and sunny.
Have 12 new SLS Xtron battery packs so (makes 24 with last years packs) non stop flying Saturday an Sunday.
Must confess - excited as before first XL flight. Must be addiction revocation syndrome.
Have a question - left my XL standing on its nose against the wall (for a month) is there a danger to twist motor box or firewall or something?
Edit PS - please please please do NOT start selling BIG AMR before maybe end of summer. There is no way I can explain two PA planes in less than six months.
faldomak is offline Find More Posts by faldomak
Old Mar 07, 2014, 05:08 PM
Giln is offline
Find More Posts by Giln
Joined Oct 2007
Length of Servo Arms
Can anyone please tell me the length of the PA servo arms?
Can't find them in my kit and I might have substitutes.
Giln is offline Find More Posts by Giln
Old Mar 07, 2014, 05:22 PM
camoy is offline
I can't fly
camoy's Avatar
Joined Dec 2006
The CF servo arms do not come with the kit they are an add on so they are not something you would find in the kit. If no one gets back to you by tonight I will measure mine and let you know
Old Mar 07, 2014, 05:34 PM
Giln is offline
Joined Oct 2007
I bought the full IPA and would have thought it would have come with that.
Old Mar 07, 2014, 05:57 PM
camoy is offline
I can't fly
camoy's Avatar
Joined Dec 2006
Originally Posted by Giln View Post
Okay which IPA kit did you get the $505 one or the $705 one? If you got the IPA setup that came with the hitec servos then you should have received the CF servo horns. If that is the case you should contact PA and they will make it right.
If you got the $505 IPA setup then no it still doesn't come with them
Mini-HowTo Precision Aerobatics Addiction X rear mounting a rudder servo p91304 Electric Plane Talk 7 Dec 05, 2014 04:42 AM
For Sale precision aerobatics addiction NEW <<LPU>>> ED3 Aircraft - Electric - Airplanes (FS/W) 8 May 01, 2013 09:25 PM
For Sale precision aerobatics addiction NEW <<LPU>>> price drop>>> ED3 Aircraft - Electric - Airplanes (FS/W) 3 May 01, 2013 09:24 PM
Sold Precision Aerobatics Addiction - LPU - REDUCED Triptykon Aircraft - Electric - Airplanes (FS/W) 0 Apr 06, 2013 08:05 PM
Sold Precision Aerobatics Addiction LPU DFW cchriste Aircraft - Electric - Airplanes (FS/W) 5 Apr 04, 2013 11:47 AM
