Old Feb 01, 2012, 01:00 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Question
Piezo buzzer help
Rookie/newbie question…
I dismantled a carbon-monoxide detector to salvage some of the parts for RC use. The detector ran on a 9v AC power supply and had a 9v battery back-up. I would like to use the alarm/buzzer for a rc project, but I have been unable to get it to activate.
I de-soldered it from the board. It has 3 pin-type connectors that are labeled G, F, and M…with the G being spaced slightly farther apart than the F and M. I have tried hooking up a 9v battery to the connectors in different arrangements, but have not been able to activate it.
Any ideas?
I found these schematics online (which I do not understand). The model of the buzzer is EFM-290ED
http://www.micromel-components.de/pi...0ed_290es_.htm
Bombay is offline Find More Posts by Bombay
Old Feb 01, 2012, 02:40 PM
crazy4volvo is offline
Find More Posts by crazy4volvo
crazy4volvo's Avatar
Warsaw, Poland
Joined Mar 2009
This buzzer needs an external oscillator/amplifier circuit to operate. The schematic you found is an example of such circuit built with digital CMOS inverting buffers instead of audio amps. Pins G and M are the buzzer's "power" inputs. Pin F provides positive feedback signal which is amplified by CD4049 causing oscillations in similar way, as microphone connected to amp and loudspeaker. If you were able to dismantle a CO detector I'm pretty sure you can build such a simple circuit .
The buzzer alone acts like a capacitor, so you can only hear single click every time you change the polarity of the battery connected to G and M.
crazy4volvo is offline Find More Posts by crazy4volvo
Old Feb 07, 2012, 08:29 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Dziękuję !
Unfortunately, desoldering the parts from the board is about the extend of my electronics knowledge.
I'll keep it on hand if I decide to brush up on my electronics skills.
Thanks again
Old Feb 09, 2012, 07:48 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Originally Posted by Bombay View Post
Dziękuję !
Gesundheit!
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 09, 2012, 08:09 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Originally Posted by dmccormick001 View Post
Gesundheit!
I'd recommend some heavy-duty antibiotics for that!
Discussion Is it possible to connect the piezo buzzer to headphones or a headset? liukku Radios 1 Nov 20, 2010 05:39 AM
Help! Need help with buzzer stigla Flying Wings 16 Jun 15, 2008 11:47 AM
Discussion Piezo Buzzer Buffer circuit? rocky79 DIY Electronics 7 Mar 22, 2007 01:26 PM
Help needed with a Piezo Gyro stabilised camera platform Skid_Mark Aerial Photography 9 Mar 24, 2004 12:06 AM
