Old Sep 05, 2011, 11:54 PM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
What do you use to charge at the field?
So i'm wondering about a solution for charging my lipo's at the field when no mains power is available. Ideally i'd like to avoid using my car battery as this is a task the typical starting cycle car battery will not last long if constantly drained down. What sort of Ah do I need to be looking at 10, 20, 30 or bigger for a charging battery, obviously I go to the field with 2-3 charged batteries but If i'm just looking to top them up to get a couple extra flights in what do i need?
Now obviously this is dependent somewhat on what size batteries i use and how far I discharge them, but if we worked of a maximum of 5000mah per pack and I was doing 2-3 top ups what would think would be reasonable or what do you use.
luke352 is offline Find More Posts by luke352
Old Sep 06, 2011, 12:11 AM
Elios000 is offline
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
deep cycles can deal with being well deep cycled rather well
most people at my field that dont use the mains run off a RV or boat deep cycle
Elios000 is offline Find More Posts by Elios000
Old Sep 06, 2011, 12:38 AM
luke352 is offline
Joined Sep 2008
Yes, my plan is to get a deep cycle forgot to mention that in my post sorry. I'm really just trying to detirmine what size people have found works well so I avoid spending more than I really need to along with the extra weight of a larger battery to lift in and out of the car.
Old Sep 06, 2011, 02:37 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I've just started field charging this year, and I've got an 86Ah deep cycle and a PL-8 charger. I'm usually charging two 3S or 6S 3900mAh packs in parallel, and only a maximum of four charges per session so far. I chose the size because it fits neatly in my flight box, but it seems to be more than enough for my needs at the moment.
You can do the maths if you want, by calculating the watt-hours of the charger battery (say 12v x 86Ah in my case = 1032 watt-hours) and the watt-hours of each flight battery (say 25.2v x 3.9Ah in my case = 98.2 watt-hours): So in my case, five charges of my 6S 3900mAh packs takes about half of my 86Ah battery's capacity. In practice, of course, I never have to charge a pack to its full capacity, so there's some leeway in that calculation.
abenn is offline Find More Posts by abenn
Old Sep 06, 2011, 04:23 AM
CyberJay is online now
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
I take 250Ah of deep cycle goodness to the field with me. The entire setup including charger, fuses, and everything else was around $300 and I never have to worry about having adequate power. The batteries themselves were around $110 from Walmart (I have two in parallel).
-Jay
CyberJay is online now Find More Posts by CyberJay
Old Sep 06, 2011, 06:07 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Our field has power but I still bring my deep cycle battery with me as a backup when there are a lot of electric flyers there.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Sep 06, 2011, 06:19 AM
luke352 is offline
Joined Sep 2008
-Jay
Unfortunately the local battery shop here wanted 159 for a 35Ah deep cycle. Checking ebay and about the best I found was about $69 for 20Ah gel style deep cycle. So understandably with the prices getting around i'm trying to keep it too what i'll need vs want. I'd like 50-80Ah but think it's probably more than i'll need.
Old Sep 06, 2011, 06:32 AM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
I use some generic car battery that I got at Costco for $60. That and a HobbyKing four-port charger. Been using that rig since last summer. Battery lives on a trickle charger when it's home.
rafe_b is offline Find More Posts by rafe_b
Old Sep 06, 2011, 07:34 AM
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
Do your research.. not all "Marine" "RV" or "Deep Cycle" batteries are REALLY Deep Cycle batteries.. I have two Optima Gel type batteries under the hood in my truck, they are advertised as "Deep Cycle" but are not really capable of it. They are also only about 50Ah.
I would think 20-35Ah would be fairly useless as a deep cycle battery.. What are you going to do with it? Run an electric boat motor for 150 feet before having to recharge?
Golf carts are a good source of truly deep cycle batteries. As well as batteries specifically designed for electric boat motors. Note that there are "Marine" engine starting batteries too, these are NOT Deep Cycle.
It's a good investment though.. Buy a good battery now and you'll have power for flying for 4-6 years. You don't have to worry about crashing your deep cycle battery.
I nearly forgot, about 3 months ago I blew a fuse in my truck which caused the alternator to stop charging. At 10:30 at night my wife got stranded on the side of the road. I ran jumper cables from my 250Ah deep cycle batteries up to my starting batteries. It was good enough to get the truck home. Nice bonus to carrying spare batteries.
-Jay
Old Sep 06, 2011, 08:24 AM
CD68 is offline
Find More Posts by CD68
Chris
CD68's Avatar
United States, MO, Peculiar
Joined Aug 2011
I use a 75 Ah deep cycle for in the field, bought at wal mart for like $60. I am using 3s 11.1v bats in my planes ranging from 1800 mAh to 3300 mAh. So far no problems here.
CD68 is offline Find More Posts by CD68
Old Sep 06, 2011, 04:49 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Uhm, school me. I use my car battery at the field. You mean by charging my little 2200Mh 3S batteries I may be overtaxing that thing? I do as many as 6 of 'em and never had an issue with car starting.
dkrhardy is offline Find More Posts by dkrhardy
Old Sep 06, 2011, 08:34 PM
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
You're probably shortening the overall life of the battery. "Starting" batteries aren't designed to be run down, just to provide the current to start the car, then go back to a charging state.
If you were going to have that battery for 6 years, maybe now you'll only have it for 4 years. Just as an example.
-Jay
Old Sep 06, 2011, 09:25 PM
bob_loblaw is offline
Find More Posts by bob_loblaw
bob_loblaw's Avatar
Antarctica
Joined Dec 2009
http://www.rcgroups.com/forums/showt...2#post17332376
bob_loblaw is offline Find More Posts by bob_loblaw
Old Sep 06, 2011, 09:29 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
As mentioned a start battery is not the best option, but even more so there have been a number of cases where someone was charging a lipo in the engine compartment of their car when the lipo decided to catch fire. Tends to cause a lot of damage. Same as those that charge in the trunk of their car or the back of the van.
Lou is offline Find More Posts by Lou
Old Sep 07, 2011, 07:58 AM
bri23520 is offline
Find More Posts by bri23520
Joined Apr 2011
I have charged all my bats for years on my cars battery, just start the car once in a while. no problems ever with the same optima bat. for 7 years
bri23520 is offline Find More Posts by bri23520
Poll Do you keep your LiPos at Storage Charge? Victory Pete Batteries and Chargers 97 Jul 12, 2014 02:11 PM
Discussion What size lenses do you use for what style of flying?? dallibab FPV Talk 15 Oct 27, 2011 12:11 PM
Help! What do you use to charge your flight packs out at the field??? jason H High Performance 49 Jun 23, 2008 01:53 PM
Discussion What do you use to charge your charging battery at home??? Kimble_Schmitz High Performance 13 Jun 15, 2008 01:31 AM
Question What do you use to charge your deep cycle field battery? FlyingW Batteries and Chargers 2 Aug 03, 2007 10:41 PM
