Old Mar 07, 2012, 03:13 AM
cody069 is online now
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
I think the 21 gives up at 1000...It can't operate at that level. But it wouldn't cause the start of the problem.
cody069 is online now Find More Posts by cody069
Old Mar 07, 2012, 03:25 AM
muduck is offline
Find More Posts by muduck
muduck's Avatar
Australia, NSW
Joined Apr 2004
[QUOTE=PMRfly;20962651]guys, question on the ubec front...
i've tried UBEC's many times but its always interfered with my video signal (need to put in a power clean up board i am told...)
You do have some ferrite rings on the OUT cable????
muduck is offline Find More Posts by muduck
Old Mar 07, 2012, 03:51 AM
PMRfly is offline
Find More Posts by PMRfly
Joined Mar 2011
[QUOTE=muduck;20962794]
yeah tried ferrite, but doesnt do much if anything.. ;-(
PMRfly is offline Find More Posts by PMRfly
Reply With Quote  (Disabled)
Old Mar 07, 2012, 03:52 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
ok then i need a favour... can you go outside and encourage the rain to go south for the weekend?
Don't do that, im in Tassie, and am going away for weekend
sammyc is offline Find More Posts by sammyc
Old Mar 07, 2012, 04:00 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Nah, mine are RC305 and HK does state that their operating voltage are 5v so I'm guessing when we put 12v into them it just turns it into heat.
Teamsherman is offline Find More Posts by Teamsherman
Old Mar 07, 2012, 04:02 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Originally Posted by Gimmer View Post
I hope not, I use 2s as well. From HK web site Rc305 - Receiver operating voltage: 5VDC. I would be surprised if using a 2s made any difference other than less heat.
Whats the lowest voltage a RC305 can reliably run down to? I haven't been letting my 2S get too low, don't want it to stop mid-flight but im sure it can go down a fair amount below the 7.4V terminal voltage of the battery.
It sure does run a lot cooler on 2S vs 3S, barely even warm at all after use as long as the suns not belting down on it.
Old Mar 07, 2012, 02:34 PM
Peril is offline
Find More Posts by Peril
Jets Suck (and blow)
Peril's Avatar
Australia, QLD, Deception Bay
I've done a fair amount of research into this topic re 305 vRX voltage pre my first flight FPV. The unit is able to operate with 2 cell LiPo quite comfortably. The regulator actually has to drop the voltage to 3.7v for the vTX units internal operation. There is a margin of voltage loss obviously involved here, but the starting volts of 12v is very excessive and generates a lot of heat, thus causing some failures. Guys have tested the minimum stable RX starting voltage but I can't remember exactly what that was. They did confirm that 2 cell LiPo is the go in preference to 3 cell which caused a few failures due to 'melt down'.
Which is why I use 7.4v 4000mh, this is enough to run the RX/Goggles for many many hours
If HK states 5v minimum, I'd say that's about on the money from what I know
Peril is offline Find More Posts by Peril
Old Mar 07, 2012, 03:17 PM
PMRfly is offline
Joined Mar 2011
Originally Posted by omelette View Post
Was thinking the FY21AP chucked a hissy fit, so it was discussed briefly in that thread, the GPS clock stopped exactly the moment she went haywire and also lost throttle. So I'm now thinking it maybe the cheap HK Ubec I was running couldn't keep up with the show.
Peril, I thought I'd broken a wing but I was still moving every thing just to get some sort of reaction, even full throttle which didn't work because I can't hear it on the gopro footage.
Here is a better crash clip showing the OSD in better detail.
http://www.youtube.com/watch?v=iaGXQ...eature=related
omelette,
I've been looking back at your footage. i am very sure that you and I have the same problem with FY21 and or ESC issues effecting FY21. My "brown out" vid below looks very similar to yours. Unfortunately i don't have telem of the incident on this vid, as this vid was predominantly recorded on the cannon a2200, but i am going to dig out the GS footage/recordings to see what the telem says.
FPV'n Around - Brown Out (4 min 6 sec)
Only diff i can see is you were flying in faf mode, i was flying in RC mode. I still get occasional b/o's today, but how i have resolved it (very much a short term solution) is load f/s on the radio so it switches plane to rth mode on instance of b/o. this results in (on instance of b/o) a very quick movement from rc mode to rth mode for half a second while it b/o's and then switches back to rc mode when it regains half a second later. Obviously this is a short term solution and i'm still trying to work things out to 'fix things'.
IF i dont have f/s on the futaba set to rth mode with 60% thrott, the plane dives for the ground. This is what happened in the brown out vid and another instance. luckily the plane survived in the b/o vid, but in the other instance, it died a horrible death...
when i first had this problem i went about replacing all of my gear piece by piece to find the problem. i replaced everything and i mean everything accept the 21. ESC, Servo's, batteries, rc radios, rc rx's, vrx's, tx'x, LRS etc etc etc. Note, i have two combo set's of 21/117's on two diff skywalkers and the problem occurred on both sets.
My set up is here:
http://www.rcgroups.com/forums/member.php?u=352875
(half way down the page)
Seems we share the problem... i wonder how many others there are...
Old Mar 07, 2012, 03:43 PM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
LOST...... Big Red thing that sits in the Sky. They call it " SUN "
FOUND...... Plenty of WATER. Will swap it for the SUN if you find it.
On a lighter note : I'v got nothing
Bx
Boxhead is offline Find More Posts by Boxhead
Old Mar 07, 2012, 03:51 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Bx
Ill swap either of those for the WIND, I have plenty of that here
Old Mar 07, 2012, 04:40 PM
Firepower is online now
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
omelette,
https://vimeo.com/32728763
My set up is here:
EDIT: I wrote the following after reading that you only mentioned the Turnigy ESC in your initial listing and no extra UBEC. But you did mention recently that you are using a 15amp UBEC so the following does not apply to you.
One common factor are the 3amp BECs and is yours any good? Also, is that enough for all that gear? We assume they are good but the tests that have been done have shown some are no good. Like I said recently I will only be using these 10amp UBECs in future (unless they are proven to have problems but I do not think so):
http://www.wiredrc.com.au/shop/Speed.../prod_695.html
You may be using UHF radios but if using Spektrum DMS2 then there is another problem that you have to pay extra attention to like voltage.
Firepower is online now Find More Posts by Firepower
Old Mar 07, 2012, 05:19 PM
narcas is offline
Find More Posts by narcas
Lame-As The real alternative!
narcas's Avatar
Bulli, Australia
Joined Nov 2006
Ok i'll take your WIND if you take my TIRED.
narcas is offline Find More Posts by narcas
Old Mar 07, 2012, 05:21 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Ive got enough of that, im TIRED of the WIND lol
Old Mar 07, 2012, 05:37 PM
PMRfly is offline
Joined Mar 2011
no, i'm not using a sep ubec atm, due to noise on the video signal that it produced. i need to work out what my strategy is to re-introduce a separate ubec... i think i might have to just use a completely separate battery for the ubec, as every ubec i have used has too much interference on the vid signal..
oh and yes, i'm using uhf...
Old Mar 07, 2012, 09:38 PM
Member #1
Joined Aug 2011
Im using a UBEC off the balance plug on my main flight battery Pete, and as yet in close at Hammo i had no interference from it, but i guess i'll find out properly this Saturday when we push them out a little further than possible at Hammo.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10091 Today 07:53 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 07:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
