Old Aug 24, 2014, 06:23 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Burned my motor about 1.5 minutes into the first flight today. Was able to belly in , out in soft brush so there wasn't any damage. Looks like just the motor at this point. Almost snapped it several times while getting it turned back into the wind, but didn't. It's a very forgiving airframe, even at almost 12lbs. She'll be back.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Aug 24, 2014, 10:07 PM
United States, AL, Northport
Joined Apr 2010
Join the club. Going to replace the whole thing then tweak the castle to run better than last.
Glad you got it down.
Razerworkz is offline Find More Posts by Razerworkz
Old Aug 28, 2014, 01:28 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Turned out that the main thrust bearing worked it's way out of the base on my outrunner which caused the shut down. I've put the fan back together with a 1180kv version of the same motor to run on 10s.
Initial tests show about 120a for about 4.4kw. I have several different packs that I can use for 10s..... 4000 mah 65c for an AUW of only 10.5lbs......10s2p 8000mah 25c for AUW of 12.25lbs............and the granddaddy 10s2p 65c 8000mah, AUW of 13lbs. All of them will offer about the same power of course, the difference will be flight times and weight of course. Should be interesting. A 10s 6000 mah would come in handy, but no gotta that one.
Also I got the fan running a little smoother, so maybe the sound quality will improve some.
Old Aug 28, 2014, 04:46 PM
Joined Apr 2010
How are you getting 2 packs of 8000 in the nose?
My 2p for 5cell 5000 won't fit unless end to end.
Old Aug 28, 2014, 06:08 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
10s 2P 8000mah is 2 x 10s 4000 mah packs
The 2P is there just to designate that the cells are not 8000mah, but 2 x 4000 mah in parallel.
Old Aug 28, 2014, 06:44 PM
Joined Mar 2005
Anybody have a new spare motor. Let out the blue smoke 1.5 min into maiden flight ?
Tony
T-spin is offline Find More Posts by T-spin
Old Aug 28, 2014, 07:56 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I'm planning to sell my motor/fan. It's brand new. I just rerouted the motorlleads through the fan shroud instead of out the back.
Old Aug 30, 2014, 04:14 PM
Joined Mar 2005
Well Lee really helped me out should have a motor here Tuesday morn. Hope this one doesn't burn out. I used all my luck on the 1st landing.
Tony
Old Aug 30, 2014, 04:48 PM
Mitchie's Avatar
Canada, QC, Gatineau
Joined Jan 2011
Sounds like the motor in this one is a little iffy!
Mitchie is offline Find More Posts by Mitchie
Old Aug 30, 2014, 04:59 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Tony's is the first one to burn on the first flight as far as I know. I'd say that it's righton the edge though. No head room on the motor, so throttle management is a must. The strength of the lipos and the air temperature need to be considered.
Also with motors like this you will get a clunker sometimes.
I hope this one works well for you Tony.
Old Aug 30, 2014, 05:08 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
On my motor problems......... I got the fan back together and sure enough, the motor issue knocked out the esc. So I've finished installing a CC120 ICE2 hv. At full 37v, it pulls 110a for roughly 4kw. So I have almost the same power on 10s @ 110a as I didwwith 14s and 80a. Running just a 4000 mah my flight time will be about 2:15 on the timer then it will be time to land. With 8000mah, total flight times should be close to 6min from take off to touch down.
I plan an afternoon of flying tomorrow.
Old Aug 30, 2014, 05:43 PM
Monaco
Joined Dec 2006
Flap control on 3 position switch or slider ?
This is my first EDF with flaps. Am I better off using a 3 position switch to operate the flaps, or using a slider where I can vary the flap angle continuously ?
I fly full house gliders and I like having the butterfly / crow on the left stick and fully variable. However I can also see the merit of having just 2 fixed flap positions so that the Cobra's flight characteristics are consistent for each position, and I learn to control the sink rate with the throttle and the speed with the elevator / angle of attack
EuroDriver is offline Find More Posts by EuroDriver
Old Aug 30, 2014, 05:55 PM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
I use two flap positions, about 15 degrees or so for takeoff and everything you can get for landing. It makes it easy to setup the compensation though I dont remember it needing much.
barracudahockey is offline Find More Posts by barracudahockey
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I'm using the switch, I think that most guys go that route, with 2 options for the amount of flap deflection. Even at almost 12lbs 15 to 20 degrees is plenty. I tried full flap once on a no wind landing, and the Cobra seemed to just stop in midair. I pulled it up to 1/2 flap. I prefer some speed for landing. I can't imagine 45 degrees of flap on a 9lb Cobra. It would probably VTOL with a 10mph breeze.
Old Aug 30, 2014, 06:21 PM
Joined Sep 2004
I used to do that thing like the Blue Angles do with their 18. Full flaps, nose up about 20 degrees and come across the field about 5 mph using about 1/3 power. Most folks are amazed how slow this thing will fly with full control.
Discussion HK coming soon new fiberglass sport jet 90mm Tim Wan Electric Ducted Fan Jet Talk 99 Nov 16, 2014 12:13 AM
Build Log 90mm Sport Jet (Inspired by the JMP Firebird) JLink125 Scratchbuilt EDFs 136 Feb 11, 2014 11:03 PM
Question Where`s that new Fiberglass 90mm Sport Jet? Knife Liddle HobbyKing 1 Dec 09, 2013 02:30 AM
Sold New Jet Teng JTM 90mm Viper Jet w/TJ90 & Tamjet Retracts Alkaline Aircraft - Electric - Jets (FS/W) 4 Oct 23, 2013 02:44 PM
Sold HK F9F-8 Cougar Composite 90mm EDF Jet 1100mm (ARF) lmpbpd Aircraft - Electric - Jets (FS/W) 0 Oct 16, 2013 10:18 PM
