Old May 06, 2013, 06:56 AM
Dillzio's Avatar
Australia, SA, Parafield
Joined Oct 2009
Gorilla glue: original vs wood glue
Hi Gang,
Someone suggested I post my thread here as the foaming scratchbuild crowd would be more likely to have experience with gorilla glue.
I was hoping i could hear back from some people on their preference for using original gorilla glue as compared with gorilla wood glue for working on foam.
Original:
Wood glue:
And to avoid confusion, there's also this one which many people call 'Gorilla White'. It's a fast setting version of original gorilla glue that does apparently set white but it still takes longer to set than gorilla wood glue:
I know the original is great for the lightweight filling of spaces because it foams up, but it can leave brown stains, and controlling the foam up with tape or cleaning it up can be a bit of a hassle. Gorilla wood glue (which I haven't used yet) has the advantage of setting more quickly, being water soluble for easy cleanup (particularly from hands) and being white for more attractive repairs.
I think i've even heard of some people mixing the two together. I myself have tried mixing gorilla original with a bit of PVA woodglue myself and found it did make it foam up a bit more, which is good for lighweight gap filling but due to all the airspaces it's not a strong as when the glue's activated by a little bit of water.
According to this usage chart the wood glue is not suitable for foam:
But according to a few threads (such as the one linked below) there are people that have used it with foam successfully:
http://forum.rc-airplane-world.com/v...t=1639&start=0
So please, share with me your experiences of using gorilla glue for foam models
Dillzio is offline Find More Posts by Dillzio
Old May 06, 2013, 08:07 AM
CAP smasher
compressor man's Avatar
GA,USA
Joined Jul 2010
I have used regular white glue (Elmers) on EPS foam and it seemed to have a pretty strong bond when dried.
compressor man is offline Find More Posts by compressor man
Old May 06, 2013, 08:24 AM
treefinder
springer's Avatar
SE MI
I started with original brown gg, but as soon as i found the white i swirched and it is now my primary glue. It cures fast enough that i can work continuous. Glue wing, let set while i work on fuse, glue fuse while i work on wing.
springer is online now Find More Posts by springer
Old May 06, 2013, 08:33 AM
vinnieg's Avatar
United States, NJ, Edgewater
Joined Feb 2012
I have used Gorilla White and Gorilla Wood glue on foam (in particular DTF). Both work great. The Gorilla white dries white and does foam up but is very stiff. It actually makes the foam around it stiff as well. DTF is a pretty flimsy when you remove the paper so it could use a spar in certain models. I use Gorilla White to install the spar (bamboo skewers, or hard balsa) because it fills in the gap and makes the entire area very stiff. Because of this stiffness, Gorilla White works really will for joining the vertical and horizontal fuselage sections of 3d profile foamies. It has been my go to glue for most applications (even motor mounts and control horns).
I use Gorilla Wood glue mostly for laminating multiple sheets of DTF together primarily because it is cheap. It takes a longer time to try than Gorilla White and dries tan in color. I have used Gorilla Wood on end joins but I prefer Gorilla White for that purpose now.
vinnieg is offline Find More Posts by vinnieg
Old May 06, 2013, 08:36 AM
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Hi Dillzio,
Where are they selling the white GG here in OZ?
Whiskers is online now Find More Posts by Whiskers
Old May 06, 2013, 09:50 AM
Dillzio's Avatar
Joined Oct 2009
Hi Whiskers,
As far as I can tell they don't sell it here, it's not on the australian website anyway.
Best bet would be to go on the aussie gorilla website, check out what distributors there are in your area and give them a call.
Old May 06, 2013, 11:18 AM
Canada
Joined Nov 2000
Just as counterpoint, I recently read some involved/detailed posting on a glue test comparison adventure.
Result suggested that Gorilla glue was less 'good' than simple white wood (PVA) glue.
Surprised me.
Might even be accurate though as the posted test read as quite careful and comprehensive.
Bare is offline Find More Posts by Bare
Old May 08, 2013, 11:46 AM
Dillzio's Avatar
Joined Oct 2009
Surprised me.
Depends where you look, you can't go by just one test, so many of them conflict each other. Also, much of that literature is about carpentry- gorilla glue is infinitely better than PVA glue on foam.
I was reading one comparison a couple of days ago that said that both glues are stronger than the wood fibers, so in testing the wood failed before the glue did. Gorilla apparently works much better than PVA when it's joining endgrains, because they soak up the glue like a straw and result in a much stronger join
Discussion Gorilla glue: original vs wood glue Dillzio The Builders Workshop 9 May 11, 2013 11:17 PM
Question Wood Glue VS. CA NEW222 Fuel Plane Talk 26 May 06, 2013 02:19 PM
Discussion Wood glue vs CA Kirwin Sailplane Talk 43 Mar 30, 2013 10:14 PM
Discussion Curing Polyurethane Glue aka Gorilla Glue - any thoughts? macinr Slope 16 Jan 15, 2013 02:07 PM
Cool New SUMO Glue vs Gorilla Glue MikeBiv The Builders Workshop 19 Oct 08, 2006 12:14 PM
