Old Feb 06, 2013, 06:21 AM
Joined Jul 2009
Kadet LT 40 Kit (parts list)
Hi, I'm looking for help getting a parts list together for my Kadet. I will be building this from a kit and this is all new to me. I have a Spektrum DX7s tx and need to know what to purchase so I can get this RTF.
So far I will be going with a O.S. 46AXII for an engine and uh thats about as far as I have gotten. What exactly do I need? I know I need to purchase a reciever, battery pack, servos, servo wire extensions etc. But am a bit overwhelmed by it all. So heres a list of what i think I need and what I will be getting.
Engine
OS .46AXII
Props
APC 10.5 x 6
APC 11x7
APC 12x7
Servos
A6050 Standard Aircraft Servo x4
Fuel Pump
911 Kwik Fill Fuel Pump
Reciever
AR600 6-CH SPORT DSMX RECEIVER
If anyone could fill in missing components it be much appreciated... i know i need a battery pack but which one?
dce21b is offline Find More Posts by dce21b
Old Feb 06, 2013, 07:13 AM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
that is a great start!
I can assume then that this is your first Internal combustion plane?
to round out what you need too make this ready to fly! you will need say a 8oz or 10oz fuel tank and fuel lines!
http://www.advantagehobby.com/58395/HAY070/?pcat=526
http://www.advantagehobby.com/77178/SUL205/?pcat=526
a switch too turn the plane on, and a charge receptical would be helpfull!
http://www.advantagehobby.com/165629/TACTACM2001/
I like control rods, such a dubro! http://www.advantagehobby.com/23730/DUB500/?pcat=685
lets not forget tires, if your flying off grass, you will need larger tires!
http://www.advantagehobby.com/34542/DAVWR25/?pcat=689
http://www.advantagehobby.com/33054/DAVWR27/?pcat=689
batt. http://www.advantagehobby.com/197102/SPM9520/?pcat=804
these are some of the important parts! this is not getting into the building supplys are the field equipment!
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: Sig Mustang 450
Old Feb 06, 2013, 07:35 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
I just checked the sig site! didn't know that the LT comes with a fuel tank and wheels! so scratch those!
I have only built the senioreta, and the kadet Jr! if the LT fly's anything like them, you will be very happy!
I would also consider some 30 min. epoxy. some slow jet, and some thin jet! and an exacto knife! an assorted pack of sandpaper, that goes from 220 to 400!
Old Feb 06, 2013, 08:32 AM
Joined Jul 2009
Thanks for the links will check it out when i get home... the building supplies i got covered its the working components im not sure of
Old Feb 06, 2013, 10:38 AM
Joined Jul 2009
Updated list
Engine
OS .46AXII
Glow Plugs
O.S. Engines #8 Glow Plug
O.S. Engines #7 Glow Plug
Props
APC 10.5 x 6
11x5 MAS prop
Spinner Prop Nut
730 Spinner Prop Nut 1/4-28
Servos
Hitec HS-422 Servo
Fuel Pump
Reciever
Receiver Battery
Venom Racing NiMH 5C 6V 1600mAh
Switch
Switch Harness w/Charge Lead
Glow Driver
Dynamite Metered Glow Driver with 2600mAhNi-MH & Charger
Electric Starter
Sullivan Products Electric Starter,12V Standard
Saftey Stick
Safety Stick Engine Starter
Old Feb 06, 2013, 12:56 PM
Jacksonville Fla.
Joined Mar 2007
Go with a 6 v battery st 1100 mah
jetmech05 is offline Find More Posts by jetmech05
Old Feb 06, 2013, 02:08 PM
Lumpy05's Avatar
United States, IN, Bloomington
Joined Jan 2012
Definetly recommend you look at 6.6v LiFe receiver packs. I have been using a 1100mah from hobbyking that is less than $5 and have been very pleased. From what I understand the higher voltage and higher amperage of the LiFe packs is desirable, servos faster/stronger. The LiFe chemistry is also very reliable and you dont have to worry about memory effects like you would with NiCd. The linked is what I have been using, the picture is incorrect it comes with standard connector to plug into your switch. You will need a capable charger that can do LiFe.
http://hobbyking.com/hobbyking/store...ver_Pack_.html
Below is a nice combo with manual fuel pump, glow driver, glow plug wrench, and chicken stick. I skipped buying the whole 12v field box battery setup. Using a chicken stick is pretty simple on a small engine, I upgraded later to a lipo powered starter. Make sure you have extra props and glow plugs, typical OS#8 or #7.
Hangar 9 starter combo
http://www.advantagehobby.com/23460/HANSTART/
Align Super Starter
http://www.chiefaircraft.com/agn-hfsstq02.html
You will also need fuel line and fittings for getting the fuel from your fuel bottle
http://www.advantagehobby.com/40217/GPMGPMP4155/
I like having one side from the bottle coiled:
http://www.advantagehobby.com/39791/...2200/?pcat=703
And finally I prefer actual spinners for my planes, it looks nicer Cant go wrong with a Tru-Turn spinner! But the spinner nut you listed will work fine or just use the plastic spinner that comes with your plane kit. The engine will come with a prop nut.
Lumpy05 is offline Find More Posts by Lumpy05
Old Feb 07, 2013, 11:26 AM
Jacksonville Fla.
Joined Mar 2007
You don't need a chicken stick if you have a starter unless you're thinking of a backup. A venom battery may not have the connection you need...check that before you buy and check the price between Venom and say JR or Futaba
Old Feb 07, 2013, 11:40 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
back-up is always a good thing!
don't know how many times I have forgoten ta charge flight box!
Old Feb 08, 2013, 02:26 PM
kerwin50's Avatar
winston mo
Joined Oct 2006
I got my LiFe batts from value hobby as well as a charger for them. 20 bucks for the charger and it works great
kerwin50 is offline Find More Posts by kerwin50
Old Feb 10, 2013, 04:54 PM
tmodelli's Avatar
Orlando FL
Joined Apr 2009
The LT40 comes with a spinner too, btw. No need to buy another one.
I just got one to teach my fiancee how to build. She is having a blast.
tmodelli is offline Find More Posts by tmodelli
Old Feb 10, 2013, 06:19 PM
Joined Jul 2009
Yeah i got mine on friday... had to work for the weekend gonna start building monday
Sold Sig Fourstar 60 Kit & Kadet LT 40 Kit oregon24 Aircraft - Fuel - Airplanes (FS/W) 4 Jan 22, 2008 07:04 PM
Discussion Sig Kadet LT 40 Kit mikerc24 Beginner Training Area (Fuel) 3 Jan 22, 2008 02:54 PM
F/S Sig Kadet LT-40 Kit Slavetonone Aircraft - Fuel - Airplanes (FS/W) 1 Oct 29, 2003 05:00 PM
FS - Sig Kadet LT-40 kit for conversion from glow to elec Dukester Aircraft - Electric - Airplanes (FS/W) 1 Sep 30, 2003 06:50 PM
FS Sig Kadet LT-40 kit Dukester Aircraft - Fuel - Airplanes (FS/W) 6 Sep 30, 2003 06:48 PM
