Old Feb 07, 2012, 12:15 PM
Sudbury ON Canada
Joined Nov 2009
3 mm flat top warm white leds for headlights
Here's a few pictures of the headlights for my panzer IV ( not installed yet ) and my Pershing ; using 3 mm flat top warm white leds ....
strmnd54 is offline Find More Posts by strmnd54
Old Feb 07, 2012, 10:54 PM
piito's Avatar
Joined Oct 2010
I personally prefer warm white as well - looks more realistic. I ordered few 10mm white led-s few days ago
That will give me some light!
piito is offline Find More Posts by piito
Old Feb 10, 2012, 04:43 PM
Joined Apr 2011
those look great...where did you get those from also is it possible you could show how to wire them
hailo01 is offline Find More Posts by hailo01
Old Feb 10, 2012, 07:16 PM
Semper Fi
GreenAmphibian's Avatar
Northern Triaid North Carolina
Joined Jun 2008
I use the warm light LED's in my builds of WW II models for the same reason, they look better.
GreenAmphibian is offline Find More Posts by GreenAmphibian
Old Feb 10, 2012, 11:43 PM
Sudbury ON Canada
Joined Nov 2009
I got them from this site on ebay ;
http://www.ebay.ca/itm/100-pcs-3mm-W...ht_3354wt_1134
As for the connection , It's a direct replacement of the leds already used for the headlights ...But if you connect them to 7.2 Volts , you will need a 240 Ohms resistor ( like on the first and second pictures)
Discussion Can I hook up a small esc to some LEDs to use as Headlights? wolfcopter Off-road Cars 6 Mar 24, 2010 09:36 AM
For Sale 1mm x 3 mm @ 1mm x 5.7 mm Flat Carbon Milton Aircraft - General - Miscellaneous (FS/W) 8 Apr 30, 2007 12:16 AM
For Sale Blow out Sale Carbon Fiber 1mm X 3 mm Flat Milton Aircraft - General - Miscellaneous (FS/W) 4 Dec 01, 2005 09:10 AM
AC prop adapters for 3.0 mm and 3.2 mm shafts Dr Kiwi Power Systems 10 Apr 03, 2004 02:02 AM
