Closed Thread
Old Dec 09, 2012, 01:07 AM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I normally do this but it might be tricky to find a nut that small, I'm cutting it down to just a few threads long.
MCrites is offline Find More Posts by MCrites
Old Dec 09, 2012, 08:27 AM
Joined Aug 2005
Has anyone tried a 6s setup yet? I would really like to try that for myself but I'm having a hard time deciding wich motors/esc's to go with
TomasLundberg is offline Find More Posts by TomasLundberg
Old Dec 09, 2012, 05:41 PM
Joined Mar 2012
Originally Posted by åsmund View Post
Here is my video, this is as good as I can get right now..and today I noticed I had turned the camera plate the wrong way,,so the lense of the camera is not in center:P
Yes, very nice Asmund
Originally Posted by c3d76 View Post
Really? I had 4 flights today and as far as I could tell 1.8 fixed the horizon problem. The area I was at was sloped so it's possible it was less noticeable... I'll test again asap.
Oh and my Yaw problem is fixed on the Lobtster, one of the arms had a twist
You were correct Dalaof, Horizon problem is still there but not any worse than 1.03 for me. It is actually a bit better because it seems to recover and level out very quickly once I have stopped "yawing".
I do have a problem with 1.8 though, it looks like the gains and scaling settings are all different from 1.03. It was super windy on my first test so I attributed some bouncing to that, but on the second (calm day) test the gimbal was just not performing either.
I'll try to tune it from scratch to see if that helps otherwise it is back to 1.03 for me too...
c3d76 is offline Find More Posts by c3d76
Old Dec 09, 2012, 05:55 PM
Joined Mar 2012
Hmm, looks like I missed a setting in 1.8 that seems to have done the trick
In the HF configurator, go to Config and calibration > Gimbal mode > calculation modes, and change both to mode 1 instead of mode 0.
Info in attached pic...
I'll have to go on a test flight when rain stops (again), but it looks good on the footage I just took "fake" flying the Lobster around the house
Old Dec 09, 2012, 08:15 PM
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Thanks for the info... I'll have to try it out. No jitters on 1.08 or 1.03, had them on 1.07.
Did you re-calibrate HF after you updated the firmware?
gww528 is offline Find More Posts by gww528
Old Dec 09, 2012, 08:17 PM
United States, OR, Keizer
Joined Jul 2012
Finally- here's some photos of my Shrimp build! Also- dropped the gains even further on roll and smooth as butter now. And yes- that is grass on the unit.
Banana Furikake is online now Find More Posts by Banana Furikake
Old Dec 09, 2012, 08:21 PM
Aerial Abstract Art
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
hmm that is interesting, I'll have to take a look at that config.
I went back to 1.03 and have been playing around with the gains and accl, but still don't have it to a point that I'm happy with, but I'm getting closer. When I moved the gimbal over to the lobster, I'm getting a little more copter movement (tilting in all directions while hovering) then I was on the F550. I'm wondering if a hexa is just a bit more stable then a Y-6 when hovering. Today with no wind, it wasn't too bad (but still doing it), but yesterday in 10-15mph winds, the copter had a lot of wobbling movement. I tried all kinds of gains, but couldn't get it that stable. As far as how it flies, it's totally stable and you wouldn't notice the wobble until you look at the video which is bouncing all over the place. If anyone has any ideas on stabilizing it out, I'll all ears.
On a totally side note, I had some jittering in my roll servo that was also showing up in my video. As it turned out, I had my roll belt too tight and it was putting strain on the servo. I loosened up the belt just a bit and the jitter went away, so that is once step in the right direction.
Daloaf is offline Find More Posts by Daloaf
gww528's Avatar
Joined Mar 2008
Nice build. Where did you get the LED's on the legs? Why did you mount the Hoverfly upside down?
Thx
Old Dec 09, 2012, 08:25 PM
Joined Jul 2012
Thx
Thanks!
LEDs= flytron.
Actually gimbal is right side up- just mounted underneath. That was done to give it a little more clearance from the bottom prop.
Aerial Abstract Art
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Your shrimp is looking great. Can't wait to see some video!
Old Dec 09, 2012, 08:32 PM
Joined Mar 2012
No problem... I did recalibrate after the update to latest 1.8 rev0.
But I'm not sure if recalibration is really needed, last time I rolled back to 1.03 and did not calibrate it still worked perfectly...
Old Dec 09, 2012, 08:35 PM
Joined Mar 2012
Yup, looking forward to some video too
Old Dec 09, 2012, 09:52 PM
jeff2215's Avatar
United States, MI
Joined Dec 2002
Nice Work! There is a lot going on there with wires
Couple questions, where did you get the extra spacers and screws on the motor mounts? (Wait, just looked. Those are different motor mounts then what I have). Also is that a custom bit protection case around the Naza GPS antenna?
Can't wait to see the videos.
jeff2215 is offline Find More Posts by jeff2215
Old Dec 10, 2012, 06:33 AM
... and other flying animals
Joined Apr 2012
Hi folks
I was very busy and haven't read last month in this forum.
I saw at TPPacks, AG 700 is not available. Gary, Andrey, When will it be available again?
And how high has my LG to be?
-Alex
Flying Rabbit is offline Find More Posts by Flying Rabbit
Old Dec 10, 2012, 06:42 AM
Joined Jan 2012
Looks like this one
http://www.rcgroups.com/forums/showt...t#post22858963
Closed Thread
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1470 Oct 24, 2014 02:16 AM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 08:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 01:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 05:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 12:51 PM
