Old Oct 09, 2014, 07:22 PM
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
By the way--today she stood on her own three legs... The ESM V3 electric retracts seem to work very nicely. Now I'm off to put all the electronics on board. I regret now gluing the aluminum tubes into the center wing section, as they now make this 49" wide. If I had glued them to the wing tips--I wouldn't have had this problem. Now the center body doesn't fit in my car (sold the Expedition and now it's either the Wrangler or Durango...)
ysolomon is offline Find More Posts by ysolomon
Old Oct 10, 2014, 02:30 PM
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
A thought: what if I cut the aluminum tubes at the nacelles, glue them in the wing tips as well, and then get a carbon fiber tube that will exactly fit the inner side of the aluminum tube, but glue those to the wing tips, thus making this plane a little narrower and can transport it to the field? I'm guessing that a CF tube like that might add a pound to the plane...
Old Oct 11, 2014, 06:26 PM
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
More progress... Ended up only using one Matchbox for the flaps (it has 4 channels). All I had to do is reverse two of them. So, channel layout (AR9100 + DX18):
1. THRO (Y of both throttles)
2. RAL
3. REL
4. RUD
5. FLP (all four, through the Matchbox)
6. LAL
7. GEAR
8. DOOR (not used yet, as I have not installed main doors
9. LEL
As far as propellers--I have the serrated washer, then prop, then the original motor washer, then original nut, then jam nut. I hope this is enough. I will test it plenty before ever taking to the air...
Old Oct 12, 2014, 08:11 PM
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
2. RAL
3. REL
4. RUD
6. LAL
7. GEAR
9. LEL
Looks like you opened up the cockpit area?
Dangaras is offline Find More Posts by Dangaras
Old Oct 12, 2014, 10:58 PM
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Only the covering, and then glued pieces of balsa and Velcro for all the electronics.
For Sale Big F7F tigercat - ESM WARBIRDS benjo Aircraft - Fuel - Airplanes (FS/W) 1 Mar 27, 2014 05:33 PM
Discussion Grumman F7F Tigercat (RBC kit) Build chinehamgeorge Electric Warbirds 30 Aug 10, 2011 08:30 AM
Discussion F7F Tigercat Build J Morgan Electric Warbirds 66 Sep 11, 2009 09:59 AM
Build Log B-25 Mitchell & F7F Tigercat Build philip noel Scale Kit/Scratch Built 163 Apr 09, 2008 07:56 AM
Bluecore F7F Tigercat Ready to fly!!! Bsouthwell Foamies (Kits) 20 Jun 30, 2002 03:52 AM
