Old Mar 03, 2015, 08:08 PM
JonnyJ is offline
Find More Posts by JonnyJ
United States, CA, Santa Monica
Joined Feb 2006
Vibration spikes making alt hold go crazy?
I have a tarot 650 with a genuine 3dr Pixhawk. It flies wonderfully in stabilize but in alt hold or position hold it goes kinda crazy. It is fairly stable at a hover, though it does rise and lower a bit. But when moving it goes through huge altitude swings sometimes it goes ballistic and climbs and the only way to bring it down is to flip back to stabilize. When looking at the logs the vibrations are just a bit out of spec. The primary vibration spike is in the z axis and it happens right before the big rises in altitude.
I have used a laser to balance my motors and my dubro balancer for my props, everything seems very balanced so i'm not sure where the vibration could be coming from? Is it perhaps that the vibration dampening material is not enough? I'm using 4 pieces of kyosho gel as recommended in the apm manual. Could this be my problem?
JonnyJ is offline Find More Posts by JonnyJ
Discussion Odd Alt Hold behavior APM 2.6 matrixman324 Multirotor Talk 2 Nov 09, 2014 03:29 PM
Discussion ALT Hold - Rapid vertical acceleration doehme Multirotor Talk 0 Nov 14, 2013 09:02 PM
Discussion APM 2.5 will not hold ALT, and other ALT issues Adrian Lewer FPV Talk 31 Jul 14, 2013 01:39 AM
Sold Heli ALT Hold Module with Jeti Prog. Box(make FPV/AP easy on your multirotor) $135 Eco8gator Aircraft - Electric - Multirotor (FS/W) 7 Feb 05, 2012 11:08 AM
Sold AP Setup: Helicommand 3D and ALT Hold Module(will hold altitude) both for $235 Eco8gator Aircraft - Electric - Helis (FS/W) 1 Feb 04, 2012 10:29 AM
