Old Jun 14, 2004, 01:40 PM
Joined May 2004
7.4 volt 1600mah li-on battery for aerohawk
will a 7.4volt li-on battery be able to replace the 8.4volt stock nimh battery. i know that the 1600 mah will make the flights longer but, will the 7.4volts be enough power for the heli. i am running stock tail motor and the 29 bb motor. here is the battery link if you want to see it http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5903323557
thanks
zac6164 is offline Find More Posts by zac6164
Old Jun 14, 2004, 03:13 PM
The one and only
dadde's Avatar
Hjo, Sweden
Joined Apr 2004
Yeah it will work fine
dadde is offline Find More Posts by dadde
Old Jun 14, 2004, 03:53 PM
Melbourne Australia
Joined May 2003
what's the C rating for the pack ? You will need to be able to run atleat 6amps continous to be safe, which means the pack must be rated for atleast 3-4C. At 1600mah you're probably safe, but just thought I should check. Some cell phone and laptop batteries have high mah but low C rating and would not suit e-flight.
The 7.4 issue however is not an issue. Lots of people, including myself get great performance from a 2s 7.4volt pack. At 1600mah, you're looking at 20-30 minute flights. Make sure you get heatsinks and provide cooling for your mixer. I fried my motor in 3 days and mixer in 2 weeks because I left everything stock, yet flew for 20 or so minutes.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Jun 14, 2004, 05:16 PM
MeVs Gravity, Gravity won
Jarg's Avatar
Cambridge, U.K.
Joined May 2004
it is a li ion, not a lipo so can not hadle sudden bursts as well, for $65 shiped you are better off getting a hobbico mkII quick charger for $50 (hellihobby.com) and a 1200 e teck i think for $23(helihobby as well), totla $73 which is only $8 more and you get a proper charger
just to warn you the charger adaptor looks like a 300mHa jobbie so you would be looking at 5 hour charge times
just got a hobbico mkII my self, going to go to lipo soon
Jarg
Jarg is offline Find More Posts by Jarg
Old Jun 14, 2004, 06:10 PM
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
thanks
I think you'll cook li-ions at that amp draw, good ips drive battery at 2-3 amps max.
Art Newland is online now Find More Posts by Art Newland
Old Jun 14, 2004, 07:08 PM
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
I have a 2C 1500 Kokam Li-Poly, it just flew almost 15 minutes in the hover! I'm am as pleased with this setup then ever, It only took me a month to work it out. I would stay away from Li-Ion......and stick with what works, you will save money, and be happier.....the Li-Poly is the way to go.....I was getting 3 to 4 minutes on the Birdseeds......This battery is incredible!
Geoffrey109 is offline Find More Posts by Geoffrey109
Wanted 7.4 volt - 2-cell 800mAh Li-Poly for Honey Bee FP dsliwins Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 19, 2007 12:18 PM
Discussion Common Sense RC 7.4 volt - 1250mAh 8C Li-Poly Pack OnGuard Batteries and Chargers 3 Jul 07, 2006 07:43 PM
Sold 3 COMMON SENSE 7.4 VOLT 2000mah 10C LI-PO PACKS "NEW" NICK H Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 02, 2006 11:54 AM
4460 mah 7.4 volt Reciever pack Li-ION jrplane Aircraft - Fuel - Airplanes (FS/W) 0 Mar 16, 2004 07:47 AM
F.S. 800 mah lithium ion battery 7.4 volt Kyle G. Aircraft - Electric - Airplanes (FS/W) 3 Mar 02, 2004 09:22 PM
