Old Dec 18, 2013, 11:03 AM
orting Washington
Joined Dec 2006
what it looks like is if you are a wimp like me,
dis connect a red wire .
If you are not a wimp, just plug it in and look for smoke.
walt
walt b is offline Find More Posts by walt b
Old Dec 18, 2013, 11:41 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
This topic has been brought up from time to time, and I like the idea of using a short extension, and removing red wire from that, instead of the ESC itself..
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 19, 2013, 10:18 AM
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
Walt,
I have usually worked to get the red wire, with the lead attached, pulled out of the plug and then I fold it over and tape it (lead and all) to the wires. This way if I want to use it in something else with a single motor, I can re-insert it lead and all into the plug. I was never a fan of that but hadn't consider there was an easier way.
It seems so simple to do it with the extension. Wish I would have thought of that or run across it sooner. That's why we post here.
BTW, you doing a twin version of this Walt? The Skunkworks in Floraida have been quite of late. When are we going to dothat paralellel build?
i12flyrc is offline Find More Posts by i12flyrc
Old Dec 19, 2013, 10:46 AM
orting Washington
Joined Dec 2006
I am doing Sloper Joe's Phantom with twin 50 mm fans
with others in the que
Old Dec 21, 2013, 10:19 AM
orting Washington
Joined Dec 2006
I just received an E mail from HK .
They said you should disconnect a red wire when connecting two
Red Brick 20 amp ESCs to a receiver
Otherwise the receiver will receive to much current.
They have an extension with no red wire ,Cost is under a dollar
Old Dec 21, 2013, 10:40 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Rule of thumb
A Linear bec esc you leave both reds connected
A Sbec esc you disconnect one
D_FAST is offline Find More Posts by D_FAST
Latest blog entry: Dassualt Alpha Jet
Discussion A-6 Intruder Profile, Kf-2 PLANS sugas182 Foamies (Scratchbuilt) 9 Jul 19, 2012 03:31 PM
Wanted A-6 Intruder Orion Pax Aircraft - Electric - Jets (FS/W) 2 Apr 30, 2012 07:26 PM
For Sale A-6 Intruder EDF Angelo Aircraft - Electric - Airplanes (FS/W) 2 Mar 21, 2012 08:10 PM
For Sale A-6 Intruder Angelo Aircraft - Electric - Jets (FS/W) 0 Mar 21, 2012 06:15 PM
For Sale Kyosho A-6 Intruder, Chicago area Angelo Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2012 11:04 AM
