Old Mar 06, 2012, 08:29 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by Dodge DeBoulet View Post
And how the heck do you balance a 2S LiPo with only 2 leads?
There has to be some sort of "in-band" signaling between the pack and the charge circuitry . . . and the balance circuitry is built into the pack?
And that's why it's not a standard 2S LiPo. There's actually circuitry inside.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Mar 06, 2012, 08:32 AM
grumpy42's Avatar
Canada
Joined Aug 2004
Originally Posted by AndyKunz View Post
Give it the overnight charge recommended in the manual. Yup, about 10 hours.
A voltage of 4.8v can represent a pack that is "mostly charged". If you perform a 10 hour charge on a partially depleted pack, you WILL overcharge it.
The battery is not charged if it hasn't started to warm up a little.
On this we can agree. But, if you want to do a 10hour charge, the battery should be depleted.
Originally Posted by lawguy14 View Post
Thanks for the info Andy. I guess you get good and bad info reading these forums. I had read somewhere it was not good to charge it over night and leave it unattended. However I know that you have the inside scoop so I will trust what you say. Thanks
That is true (the DX7s manual even warns against unattended charging). Andy is wrong to be advocating overnight charging for partially depleted packs. Remember, Andy is a software guy.
It is quite unfortunate when an "authoritative source" insists on providing inaccurate information.
grumpy42 is offline Find More Posts by grumpy42
Old Mar 06, 2012, 08:34 AM
Dodge DeBoulet's Avatar
Joined Dec 2011
Andy
Giving it further thought, having the balance circuit in the pack wouldn't necessarily mean that the battery had to "talk" to the charger through any other mechanism than voltage level.
Too bad the hardware guys didn't tap into the charge circuitry for the voltage display. But then again, that circuit probably disconnects once the battery is charged and only reconnects once the wall-wart is plugged in.
Dodge DeBoulet is offline Find More Posts by Dodge DeBoulet
Discussion DX7S Battery Level Indicator Dodge DeBoulet Radios 18 Jun 28, 2014 03:37 PM
Sold new spektrum dx8 2000mah nimh batterynew spektrum dx8 2000mah nimh battery ohsnap Aircraft - General - Radio Equipment (FS/W) 1 Nov 09, 2012 10:13 AM
Sold 4000mAh LiPo Transmitter Battery: DX7s- DX8 davidvm3 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Mar 13, 2012 02:43 AM
Discussion Tenergy battery charging - low voltage indicator - noob lost_texan Batteries and Chargers 2 Mar 02, 2012 04:03 PM
Question Cellpro Safe Adapter & Battery Voltage Difference Protection JimHSoars FMA Direct 8 Nov 05, 2011 07:30 PM
