Old Nov 01, 2003, 02:06 AM
Permanently banned
Mario's Avatar
Mesa, Arizona, USA
Joined Jul 2000
*** New G10 Frame Ver 2.0 ( Piccolo, Hummingbird, Hybrid) ***
MIA Universal G10 Frame V2.
MIA Universal G10 Frame has been revamped with the following upgrade details:
* Bolt On servos (Hitec HS-55 or similar size) with glove fit for a total custom and super clean appearance.
* Built In Tail Boom Clamp (no more gluing tail booms)
* Longer Receiver /Gyro tray
* Rubber Band Mounting Ears at front and tail setion for holding whaterver equipment in any number of ways to the frame. Now you can mount the gyro on the tail and hold it there with some sservo tape and one small rubber band.
* Kit assembled quick and side frames can be further customized with Bolt-On aluminum bearing motor boom mounting blocks as an option left to the person looking for total customization.
Available November 7, from Helihobby and Sly's Hobby Den.
Mario I. Arguello
www.micro-flight.com
Mario is offline Find More Posts by Mario
Old Nov 01, 2003, 11:42 AM
Toronto Buttonvle, Canada
Joined Aug 2003
What's the pricing going to be like? I like the "superhero" landing gears.
gotak is offline Find More Posts by gotak
Old Nov 02, 2003, 12:38 AM
Permanently banned
Mario's Avatar
Mesa, Arizona, USA
Joined Jul 2000
Pricing will be same as the original MIA G10 universal Frame retrofit kit.
Check with your local MIA dealer.
Mario I. Arguello
Old Nov 03, 2003, 09:49 PM
Paul5910's Avatar
USA, TX, Houston
Joined Jul 2002
What local MIA distributor? I live in Texas.
Paul
Paul5910 is offline Find More Posts by Paul5910
Old Nov 03, 2003, 10:25 PM
Vallejo, California, United States
Joined Sep 2003
re-read the first thread, helihobby and sly's hobby den
frebaln is offline Find More Posts by frebaln
Old Nov 03, 2003, 10:38 PM
Paul5910's Avatar
USA, TX, Houston
Joined Jul 2002
Frebraln ** re-read the first thread, helihobby and sly's hobby den
What "LOCAL" MIA distributor in TEXAS was the question. Get it now?
Old Nov 03, 2003, 10:57 PM
Razy Crandom Guy
Millville, New Jersey (excl EWR), United States
Joined Sep 2001
Mario, I cannot find any information on this on your site. Am I missing it or is it not posted?
WyndShadow is offline Find More Posts by WyndShadow
Old Nov 04, 2003, 01:18 AM
Annapolis, Md
Joined Jul 2003
We all "get it". You will need to order it from helihobby or sly's hobby den. Those are probably the only two places that will carry it.
http://www.micro-flight.com/Distributors.htm
Gazoo is offline Find More Posts by Gazoo
Old Nov 04, 2003, 09:43 AM
Joined Sep 2003
Thanks Gazoo
Old Nov 04, 2003, 10:15 AM
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Mario,
Any prelim pics to share?
Neal
Nobert is offline Find More Posts by Nobert
Old Nov 14, 2003, 03:12 AM
Permanently banned
Mario's Avatar
Mesa, Arizona, USA
Joined Jul 2000
MIA G10 Universal Frame Kit Version 2
This frame works the same as MIA's original G10 Universal.
Uses Piccolo "Flanged" 3 mm ID Main shaft bearings.
Works great with Piccolo CP mechanics due to specific Servo layout, study the photo and note it also has a clamp to allow removing/installing the boom. NO CA GLUE for boom.
Also work swith Hummingbird FP mechanics because they share similarities in mechanical drive components with Piccolo. The Hummingbird has a large spur gear which fits confortably in this frame. The antirotation arm may need to be trimmed since FP Hummingbird mechanics use a shorter shaft than CP Piccolo which effectively lowers the swashplate position.
Not shown for simplicity, but this new frame comes with the original MIA G10 frame spring wire struts and molded skids.
Here is a photo with details. Available through MIA Dealers
Mario I. Arguello
Old Nov 14, 2003, 03:24 AM
Permanently banned
Mario's Avatar
Mesa, Arizona, USA
Joined Jul 2000
Tip for users with the Original MIA G10 Universal Frame:
If you want to add a simple effective boom clamp on your original styte frames, put a small slit, using a Dremel tool, at the top on the tail boom braket and drill a small hole through the rear frame near the boom mount, use a small bolt and nut for creating a boom clamp, you will need to use CA debonder to remove the boom first. Photo shows details.
Mario I. Arguello
Old Nov 14, 2003, 05:05 AM
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Mario,
I see from the pix that you are using HS-55's. Are the HS-50's too small to bolt on the frame?
Thanks!
docphi is offline Find More Posts by docphi
Old Nov 14, 2003, 10:38 AM
Joined Oct 2002
mouth watering
Glenn Cain is offline Find More Posts by Glenn Cain
Old Nov 14, 2003, 11:56 AM
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
What would be the servo positions on the frame for FP helis like the hummingbird? would I not have to have a servo mounted from the back? for fore and aft cyclic? is there a mount there? Bud
spudandretti is offline Find More Posts by spudandretti
Discussion Aero Ace Combat ver.2.0 jive Micro Ready-to-Fly 3 Jun 12, 2006 08:09 PM
Dave Morris Micro Bandit Ver 2.0 maiden today dave morris Electric Ducted Fan Jet Talk 21 Apr 18, 2004 08:44 AM
Dave Morris micro bandit ver 2.0 dave morris Electric Ducted Fan Jet Talk 206 Apr 13, 2004 08:33 PM
EPP Sukhoi SU31 Ver 2.0 Happy|Harry 3D Flying 4 Feb 14, 2004 09:08 PM
g10 frame, MS CP kit, piccolo tail......? foss1997 Electric Heli Talk 3 Sep 22, 2002 10:42 AM
