Old Jan 31, 2014, 11:25 PM
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
ParkFlyers Cessna
Hey is the Parkflyers Cessna 182 V 3 shown here :http://www.parkflyers.com/Cessna_182...e_p/4304v3.htm
The Same as the Cessna 182 3G3X Version shown on your site here:
http://parkrcmodels.com/product_info...roducts_id=544
They look Identical and wondered if they are the same plane ? Just curious.
Thanks in advance.
HGhost is offline Find More Posts by HGhost
Old Feb 04, 2014, 12:22 AM
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Guess no one knows ?
Old Feb 04, 2014, 09:59 AM
United States, MI, Auburn Hills
Joined Dec 2008
Thanks in advance.
the actual fuselage and wing set look like the Skyartec Cessna - the radio, ESC, Motor and Battery are not the same - further the Skyartec Cessna Radio is a 3 axis gyro setup that will keep the airplane stable and in level flight for the beginner
Max
www.parkrcmodels.com
Parkflying is online now Find More Posts by Parkflying
Site Sponsor
Old Feb 04, 2014, 01:57 PM
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Max
Thanks Allot Max.
Old Feb 05, 2014, 11:44 PM
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Max is your Cessna EPO Foam or is it EPS, ( expanded polystyrene.) material ?
I see you site mentions EPO like technique ? Makes me think of a smooth depron foam type material, feels like plastic-smooth, but is more brittle and breaks easily on impact, not like EPO that crumples.
Can you elaborate ?
Notice you also have a 5 channel version, and uses a 3 S battery...the other company uses 4 ch and 2 S and boasts 60 MPH capabilities ...and uses a Tri-Blade prop, I assume to help achieve that boast ?
Can you provide a tri-blade prop and does it really matter , 2 or 3 blade with this style plane ?
Interested in a Cessna, just trying to decide which way to go .
Also noticed neither plane has Wing strut supports ?
Thanks in Advance for your input.
Old Feb 06, 2014, 07:44 PM
Joined Dec 2008
In line:
Can you elaborate ?
Wings and Fuselage is a very smooth version of EPO; very flexible and shiny - I think a special compound the factory uses - the Vertical Tail and Horizontal Tail Wing are of a harder plastic
Cannot speak about the other having 3 blades - but his motor and battery offer more power - Skyartec has flaps AND a full feature 7 Channel Radio that is fully programable; further the Plane has the newest 3 axis Gyro Receiver that helps keep the plane in level flight for beginners
Factory has a well tuned normal 2 blade prop - this plane is plenty fast
Skyartec Cessna Now has wing supports
Max
www.skyartec-usa.com
Site Sponsor
Old Feb 06, 2014, 09:51 PM
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Thanks again Max
Will give it more thought
you gave me allot to consider.
Review Parkflyers R/C Cessna 182 Pro Series RTF from Parkflyers.com Review DismayingObservation Beginner Training Area (Aircraft-Electric) 5 Aug 13, 2013 05:05 PM
Wanted Cessna 182 parkflyer! Symmbian Parkflyers 2 Jan 21, 2005 01:38 PM
Parkflyers.com Cessna 182 bhpd1438 Electric Plane Talk 4 Jan 14, 2005 01:15 PM
FOR SALE: Wattage Cessna 180 (RTF) Parkflyer BuNisGoD Aircraft - Electric - Airplanes (FS/W) 3 May 08, 2004 11:09 AM
