Old Jan 29, 2013, 11:03 AM
nick 30
nick30head's Avatar
Joined May 2009
sound unit application
i have a diesal sound unit in my rock crawler, the unit plugs into the reciever while the esc plugs into the sound unit to give you proportional sound in forward and reverse, 2 wires connect to the speaker while the battery wires are pluged into a spare reciever channel (can be powered by a seperate battery)
the seperate batt voltage (upto 12v) denotes the volume.
i think its still to loud so can i put a volume control dial switch between the sound unit and speaker or shall i buy a new smaller speaker ?
nick30head is offline Find More Posts by nick30head
Old Jan 29, 2013, 11:59 PM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Are you sure there is no adjustment for volume on the diesel sound generator? Usually there is a potmeter to adjust sound and volume. Like this SMD module:
SoloProFan is online now Find More Posts by SoloProFan
Old Jan 30, 2013, 01:18 AM
nick 30
nick30head's Avatar
Joined May 2009
defo no pot on the sound unit
the unit is called
DIESEL ENGINE SOUND UNIT
alan bond design
found at technobotsonline.com
Old Jan 30, 2013, 01:53 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
From the manual it says this about volume:
"As the speaker signal is digital in nature, for simplicity, cost and efficiency the
speaker is switched directly to its battery supply. This results in the output
volume not being adjustable.
To a very large degree, the quality and volume
of sound produced will depend very largely on the speaker itself and the way
it is mounted in the model. For example, if using the 6V propulsion battery
the resultant sound is too quiet, or on 12V it is too loud then an auxiliary
battery or batteries of higher or lower overall voltage may be used to achieve
the volume level required. A pack of AA cells is quite adequate for this
purpose, with the benefit that the number of cells may be easily adjusted
So it appears you adjust the volume by altering the input voltage. Perhaps a variable resistor can also be used to limit the output volume, but there is a chance sound quality is affected, and the resistor will dissipate unused power into heat.
Sold Model Sound Inc. Shockwave Sound System NIB $200 tmulder Aircraft - General - Miscellaneous (FS/W) 1 Apr 13, 2013 02:14 PM
Sold 2 Units 3M EPX Plus ll Adhesive Applicators tonyjet Aircraft - General - Miscellaneous (FS/W) 0 Apr 24, 2012 03:03 PM
Help! EDF unit + motor application assitance requested Hepdog Electric Ducted Fan Jet Talk 4 Aug 25, 2007 01:26 PM
Question what is the best type of unit for my application jberk Robotics 2 May 17, 2007 08:46 PM
