Old Jun 21, 2012, 02:44 AM
Joined Jun 2012
New Product
NEW!!!HOT!!!Fi8612M,Full metal case Standard HV programmable servo
Fi8612M,Full metal case Standard HV programmable servo from Fitec rc model
Features
-Standard digital metal gears servo、2BB
-Corless moter
-All Aluminum alloy case
-Waterproof
-Operating Voltage:6~7.4Volts
-Interface: (like JR)
-Wire length: 30cm
Servo programmable function
1. FAIL SAFE, On or Off
2. Direction of Rotation
3. Travel Speed
4. Servo Max Torque limit, and Punch
5. Center, End, and FAIL SAFE Point
6. Signal Pulse Set-Up
7. Stretch (Holding Power, Running Power, Acceleration and Deceleration)
8. Dead Band Width
9. Resolution Setup
10.“Save and Open” File Options
11. Reset Factory Default Data
12.Read and Write Servo Data
Full Packaged
-Servo×1PCS
-Servo arm×1 bag
-GW: 124g
Fi8612M:
Weight: 73g(2.58oz)
Speed: 0.12sec/60°(6V)
0.09sec/60°(7.4V)
Torque: 10.2kg.cm/141. oz.in(6V)
12.8kg.cm/178.1 oz.in( 7.4V )
Application:1/10Car, Boat, Robot
Fi8622M:
Weight: 73g(2.58oz)
Speed: 0.17sec/60°(6V)
0.15sec/60°(7.4V)
Torque: 18.9kg.cm/262.9 oz.in(6V)
21.3kg.cm/296.3 oz.in( 7.4V )
Application:1/10 1/8 Car, Boat, Robot
Samples are available to test,if you are interested in,welcome your first trial order.
Contact jenny.fitecrc@gmail.com or www.fitecrc.com
hobbyfitec is offline Find More Posts by hobbyfitec
Reply With Quote  (Disabled)
Old Jun 26, 2012, 03:33 AM
Joined Jun 2012
Thank you for your information of latest Servos.
May I know more about "Programmable function" ?
Do you have any instrution manual of the function ?Is them all full metal case?
limspeedracing is offline Find More Posts by limspeedracing
Old Jun 26, 2012, 04:05 AM
Joined Jun 2012
Thank you for your attention!
Yes,The new programmable servo is full metal case as picture shows.
We have software for instrution manual of the function.
Old Jul 02, 2012, 03:33 AM
Joined Jun 2012
PC programmer for Fitec programmable servo
Old Jul 02, 2012, 10:36 PM
Joined Jun 2012
New Fitec Logo
Aboove is our new servo logo.
Old Jul 05, 2012, 02:49 AM
Joined Jun 2012
More information about programmable servo
Your new products are quite interesting. Could you provide a bit more information?
1. USB Programmer — what is this in a nutshell? Is it FTDI USB-Serial converter or what.
Our USB Programmer picture as follow. It is use for programming FT programmable servo.
It is use USB HID agreement, Connecting PC software and servo to communicate.
PC software PROGRAM MODEL as follow.
2. What protocol is used for programming? What the chip is inside: ATmega, ATtinty?
The protocol is compatible with Robotis Dynamixel communication agreement, however, our memory control table has some difference between its. The chip is Atmega.
3. Are they standard range: 180° rotation servos with physical limits?
Yes, they can programmed 180° rotation.and with physical limits.
4. What is “Failsafe mode”?
In selecting FAIL SAFE “ON”, the servo will rotate to a user programmed FAIL SAFE travel point when lose the receivers signal during normal operation.
5. What are Center, End and Failsafe points in your terms?
It is the EPA setup, users can customize the center point and left/right servo travel end points.
P.S. I see you're interested in your product line extension. As an opinion of our company it would be a killer-product if you'll introduce servos with feedback feature (what angle is my servo currently in?) and/or servos with shared bus so that I can connect one servo to another in a chain and to control any of them using just one cable (likely to be 4-wire cable).
Up to now our programmable servo is base on RC servo, however, we can extend our servo to use for ROBOT with shared bus, to control any of them using just one cable(include power wire is 3-wire cable). We can exchange more comments if you are interested in.
Old Jul 13, 2012, 04:27 AM
Joined Jun 2012
How to connect the servo with PC and programming unit
Old Jul 14, 2012, 12:28 AM
Joined Jun 2012
New Product DOMAN RC new programmable HV digital servos springrc Radios 1 May 15, 2012 08:54 PM
New Product GWS S03N3 Metal Case Metal Gear Standard Size Servo gws roger Electric Ducted Fan Jet Talk 2 Jul 11, 2011 10:41 AM
Discussion GWS S03N3 New All Metal Case Metal Gear Standard size Servo gws roger Electric Heli Talk 4 Jul 05, 2011 01:55 AM
New Product GWS S03N3 New All Metal Case Metal Gear Standard size Servo gws roger Electric Plane Talk 1 Jun 06, 2011 12:18 PM
New Product GWS S03N3 All Metal Case Metal Gear Standard Size Servo gws roger Foamies (Scratchbuilt) 0 May 06, 2011 03:06 AM
