Old Sep 12, 2014, 09:09 AM
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
Originally Posted by PHDBouncingBob View Post
Just finished a New Reverb. Same 3000 kv Dr. Mad Thrust motor turning a APC 5.25x6.25 prop.
The 2200 A-spec 65-130C is just slightly faster than the 2200 HD 60c. If you stay throttled up, the HD 60C might "puff" on you. As I don't, the HD 60C will save a few bucks and does require you to trim the aft canopy area ever so slightly to slip it in and out. Yet, as you can see, the canopy still covers the rear fuselage opening.
Am using some JB quick set weld on the belly as we land on asphalt. Have tried "other" ideas but this is by far working the best.
With this motor/prop/battery setup the Reverb sees 175-180 mph and on its best day, has been @189 mph.
Best.
are you not running a spinner because of heat issues with the motor?
i have this set up in my slopeX. i dont have cooling holes as of yet because everything runs cool on 3s. the esc is a yep 150 amp with the mod done. it runs cool also on 3s.
also did you guys see the new lihv bolt packs at HK. these should be even better when fully charged.
later andrew k.
57sailplane is offline Find More Posts by 57sailplane
Old Sep 12, 2014, 11:25 AM
Joined Nov 2013
later andrew k.
Our field is in the Southwest desert. Day time temps are hot(95F+ is normal with runway temps getting above 125 F). With the bullet am just trying to get as much airflow in as possible. The motor and battery temps are warm (not hot). The esc runs warm.
I posted a logger a while back. Static amps were 113 and watts 1647. The motor is rated for 85 amps and 1300 watt. So, inflight its close. I did a logger flight which showed rpm, amps & watts but I can't find it.
We have a inferred temp gun. I can't remember exactly what the temps were but will check them again.
Have to look at these new packs.
Best.
PHDBouncingBob is offline Find More Posts by PHDBouncingBob
Old Sep 22, 2014, 02:15 PM
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
finishing up my 2nd reverb.The 1st one I ran with a 16/15/2 and a 2s batt,no probs.This one has my 16/f5d/2ce and will use 4s,still trying to fit in my esc and separate sbec.what a chore
oly_rcer is offline Find More Posts by oly_rcer
Old Sep 22, 2014, 11:58 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Nice, Oly! APC 6x5.5 suites your setup fine
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Sep 25, 2014, 05:10 PM
DesMoines,Wa
Joined Feb 2008
Okay,Let's try this again,I feel good about this one.hs 65mg in the tail,hb65 in ail.Mega 16/25/2ce(2300kv)Jeti spin 75 and hk sbec.6x5.5.wing tape for better visabilty.
Old Sep 25, 2014, 06:05 PM
Crashing into the sky!
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Very nice, should be fun.
jackosmeister is offline Find More Posts by jackosmeister
Old Sep 25, 2014, 07:02 PM
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Be careful of that spinner at higher rpm..... I had one fail.
BulletMaster is offline Find More Posts by BulletMaster
Old Sep 25, 2014, 09:11 PM
Edhs's Avatar
the seventh planet
Joined Dec 2010
Looks good Oly. I like it when people take the time to post the KV so I dont have to look it up. Can I ask a question? Is that a BEC taped to the ESC in the cockpit photo? Not trying to be critical but if at all possible I would try to keep some space between thees two as if the ESC goes it might take out the BEC.
Edhs is offline Find More Posts by Edhs
Old Sep 25, 2014, 09:23 PM
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Yeah, ditto on the bec, have fun
mustflynow2 is online now Find More Posts by mustflynow2
Old Sep 25, 2014, 09:40 PM
DesMoines,Wa
Joined Feb 2008
Cool,thx for the tip,have room on other side to put bec
Old Sep 27, 2014, 06:51 PM
DesMoines,Wa
Joined Feb 2008
Had a great day with the reverb.pulling 57a static,forgot watts.Soon as I get spin box will be able to chart it.Maiden flight,had bud throw it out,easy launch and needed no trim at all,flew straight.Rolls and loops are tight and turns on a dime with no noticeable wing flex.speed was great but just as prop started singing I had to shut down so never got it full speed,it's fast tho.Landings were very easy,slows down well and drops with spoilerons.all flights put it in the middle of landing field.Great little plane
Old Sep 29, 2014, 04:56 PM
Joined Nov 2013
Best.
After about 35 flights on the new Reverb, no problems. with the previously stated power setup, using a temp gun, with a OAT of 85 F, the motors running 110-115 F. The A-spec and HD 60C battery shows 105-115 F. The esc is running 110-115F. These temps are 4-7 secs full on, then around 15 secs off, on then off again type flights.
Best.
Old Oct 03, 2014, 05:47 PM
Joined Oct 2009
Well we had a great run together, but sadly after ~75 flights the Reverb is no more. The wing sheared off and departed in flight at the wing bolt mount. Will order another one this winter
nighthawk0077 is online now Find More Posts by nighthawk0077
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
