Old Jan 09, 2014, 12:27 PM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
FMS EPO F3A new model
Surprised to see a Sebart Wind S Pro decal on the side of the fuselage
http://www.aliexpress.com/item/2014-...610525184.html
ltc is offline Find More Posts by ltc
Old Jan 09, 2014, 03:16 PM
Team Futaba
Neilbo4's Avatar
United States, MD, Nottingham
Joined Mar 2007
Yeah that Wind S Pro decal is extremely odd...not sure why anyone would put that decal on any other airframe other than a true SebArt Wind S Pro....
Neilbo4 is offline Find More Posts by Neilbo4
Old Jan 09, 2014, 05:10 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Sent a message to MotionRC (USA FMS dealer).
They have no information on this plane.
It has FMS decals, but I suppose that doesn't mean it's actually FMS.
Looks like an interesting plane.
Old Jan 10, 2014, 10:31 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
It is called the Olympus
It will be sold by DiamondHobby (already on their FB page)
http://www.rcgroups.com/forums/showthread.php?t=2050044
Odd that MotionRC said they knew nothing about it, I thought they were a fairly large FMS dealer
Old Mar 31, 2014, 05:59 PM
richard hanson's Avatar
Joined Oct 2007
We just finished assembling one of these FMA Olympus
looks good and yet a couple of things I really didn't like
The mfg really trapped the servo leads going aft, also used very long leads on servo - IF you attempt to replace servos be prepared for a-little work unless you are able to feed a piece of heavy string back thru to the servo mounting points - I didn't do that --- and had to do some innovative drilling with long piece of brass tubing
the servo ends are a lousy fit to std JR connectors - I swapped out all extensions
I alsoswapped out all servos and used Spektrum (Savox mfgd) HV servos
much more torque. they fit perfectly but you have to do your own servo arm connectors as the ones in the kit are CAed in and break if you try to undo the nut
other than the servos --the kit is very well thought out
I also mounted the rx aft the canopy and added a tray forward for the power battery
The batts we use are 2900 and 3200 ma 6 cell-. Also the new servos are fed by a A123 2 cell 1100ma pack.
NO BEC thank you ! I have given up on BEC setups for other than profile foamies .
The mfg did up the ESC/BEC to a 70 amp ESC/5 Amp BEC looks very nicely made but -----
We compared it to our Splendor -
It weighs 3 ounces less -
it is much longer in the aft fuselage and has a much large horizontal stab and smaller elevators
Tho the wingspan is slightly more, the chord is less, so wing area is less
This model will likely like to keep moving and that's fine - we are using these models for the intermediate FAI patterns - The Splendor will do any FAI maneuvers and I suspect this model will do em as well perhaps better tracking - we will see.
I am going to compare Watts on different props - against the Splendor setup -
I don't care for 5 cell setups as compared to 6 cell - too many amps needed for same wattage .
my choice .
richard hanson is offline Find More Posts by richard hanson
New Product New T-28 Trojan 1400mm EPO by FMS jbc Electric Warbirds 7568 Apr 13, 2014 10:48 AM
Discussion New FMS 1400mm F3A Olympus ricksonchow 3D Foamies 15 Apr 09, 2014 11:57 AM
Sold SOLD & SHIPPED! FMS Large EPO 57 inch P-51D Mustang (Airframe Only) New In Box! PittSpecial Aircraft - Electric - Airplanes (FS/W) 4 Apr 04, 2011 11:00 AM
New Product New Giant FMS EPO BF 109 fletchace Electric Warbirds 20 Nov 23, 2010 07:53 PM
Discussion Nitro Planes New! FMS Scale Skyline 182 Trainer EPO Foam "Review" FlyBoyTha1 Foamies (Kits) 8 Oct 29, 2009 03:10 AM
