Old Aug 04, 2013, 06:07 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Build Log
Yardbird Balsa and fiberglass Pod
I'm getting ready to build a Yardbird wing from Mountain Models. But first I thought I would build a balsa Pod for it.
I bought the short kit from Mountain Models a few weeks ago along with a Boom for a Bubble Dancer.
As with everything I build I have to change things and personalize them. Why you ask! I don't know just something inside my head that says lets do this a different way.
So when I received the kit the first thing I did was look at the plans and decide what I could change. Nothing against you Darth your plans and work are terrific. And I couldn't be doing what I'm about to do without your expertise and build logs.
So I took out the plan and re-drew it. Seeing how I'm a retired Senior Design Engineer that wasn't very hard to do. I shortened the wing 10 ". Why I don't know. I did this by moving all the ribs about 1/8" closer together. The center section of the wing will remain unchanged but a little shorter. The mid section will be one rib shorter and the ribs closer and the tip section will be one rib longer and have less of an angle from the LE to the tip while the TE will have a little more angle to the tip.
But before I start on the wing I'm building a Pod for it that I saw Tom from the Czech Rep build a few years ago. I looked at the pictures of what he did and drew up a plan for the Pod. It's basically two halves. Just like building a boat.
It's all balsa with 1/2" plywood for the wing pedestal and wing mount hold down covered with fiberglass and will be painted to match the wing.
I've been taking pictures as I build so the pictures I'm showing may not be in the correct order.
The Pod and boom is done along with the Tail Feathers which I drew plans for based on the Bubble Dancer and the Yardbird. I still have to do a little more sanding on the Pod to make it ready for paint but basically it's done.
Hopefully I'll start on the wing next week. I'll post pictures of that as I get going.
So here's some pictures of the Pod. Enjoy. I'll probably have to post the pictures in a couple segments.
Eddie
hog2soar is offline Find More Posts by hog2soar
Old Aug 04, 2013, 06:15 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Well something isn't working like it use to for attaching the pictures so I may have to do one at a time
Old Aug 04, 2013, 06:22 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Joining the halves
Old Aug 04, 2013, 06:27 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Preparing to fiberglass and epoxy
Old Aug 04, 2013, 06:32 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Epoxy installed sanding and filler begins
Old Aug 04, 2013, 06:35 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Almost ready for primer plus tail feathers. Will post more pictures later as I get things done. It may be a while,stay tuned.
Eddie
Old Aug 04, 2013, 06:42 PM
Little Red Plane
United States, TN, Knoxville
Joined Dec 2012
Very Nice!
I just love the different approaches that we take as builders.
GarryOgilvie is offline Find More Posts by GarryOgilvie
Old Aug 04, 2013, 07:00 PM
Hawaii
Joined Feb 2009
Very nice Eddie!
SHVentus is offline Find More Posts by SHVentus
Old Aug 04, 2013, 07:07 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Thanks guys. Here's a couple pictures of the tail feathers with the pod and boom just for kind of a visual.
Old Aug 04, 2013, 07:53 PM
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Subscribed to watch Eddie build a Yard-pod-bird Tail dragger? Cool Eddie
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Aug 04, 2013, 08:01 PM
life long racing nut & modeler
granada don's Avatar
Granada Hills Ca.
Joined Nov 2009
Hi Eddie
I like the shape of your Rudder & Stab, your off to a good start
I knew you would like this scratch building stuff, run what you broung just can't beat it
G Don
granada don is offline Find More Posts by granada don
Old Aug 11, 2013, 05:04 AM
Giorgos Stratakis
Stratigio's Avatar
Athens Greece
Joined Jun 2008
Another pleasant surprise from a mod-master.
Great job on the pod, Eddie!
Keep posting...
Stratigio is offline Find More Posts by Stratigio
Old Aug 11, 2013, 11:49 PM
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
Nice pod, Eddie. I love the lines.
W
wingloada is offline Find More Posts by wingloada
Latest blog entry: New projects
Old Aug 13, 2013, 09:01 PM
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
I gotta ask, why shorten the wing? I love the pod, and almost did the same exact thing on my Yardbird. But why shorter?
I'd like to take that 10" and add it to my Yardbird's span.
dion9146 is offline Find More Posts by dion9146
Latest blog entry: Big Gull plan pics
Discussion Balsa fiberglass hinge? overmyhead Hand Launch 5 Apr 23, 2013 10:44 AM
Question Looking for my first fiberglass or balsa edf jet Mike20 Electric Ducted Fan Jet Talk 8 Apr 12, 2013 01:18 AM
Discussion Recommend an ARF 70mm EDF that is balsa/fiberglass? sothpaw Electric Ducted Fan Jet Talk 9 Feb 18, 2013 05:17 AM
Question fiberglass pod help stefalo Composites Fabrication 0 Mar 26, 2008 04:28 PM
