Old May 07, 2013, 12:49 PM
Joined May 2013
Need help with discharge/charge settings
Sorry to ask such a basic question, but i just picked up a GT POWER 400WATT 20AMP charger/discharger and am not sure of how low/high settings i should set for discharging/charging/cycling my 7cell,8.4 nimh batteries for my slash(one is 5300mah and other is 3000mah).A little worried about hurting them(have only used a fusion delta peak charger w/o discharge).
Thanks!
speedybanzai is offline Find More Posts by speedybanzai
Old May 08, 2013, 11:35 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Charging depends on the cells, but charging at 1C is always safe. So if it's a 5300mah pack, charge it at 5.3 amps.
You can normally discharge at a higher amperage, but I don't know if your charger will go higher or not. If you want to be safe, stick to 1C discharge as well.
wparsons is offline Find More Posts by wparsons
Discussion I need help to discharge my lipo!! Prince_Al Batteries and Chargers 15 Apr 09, 2013 09:21 PM
Discussion I need help with charging Futaba 8fg Super Prince_Al Radios 3 Apr 06, 2013 12:11 PM
Discussion Help needed. Why the battery is struggling with 3.8volts left of charge? sgrouts Batteries and Chargers 17 Jan 31, 2013 04:36 AM
Discussion need help with twin motor thrust set up Rhondas Electric Plane Talk 9 Jan 27, 2013 06:48 AM
Discussion Need basic help with NIMH charging/discharging rates 400fe Batteries and Chargers 6 Mar 10, 2010 04:14 PM
