Old Apr 13, 2014, 10:27 PM
Joined Nov 2012
Originally Posted by egiman007 View Post
Why you are selling it John?
Going Bigger.
John
MOPAerial is offline Find More Posts by MOPAerial
Old Apr 16, 2014, 09:42 PM
Joined Feb 2013
Drive voltage for motors
What is the reccommended drive voltage for the motors supplied with the "M" version ? I realize one has some lattitude with the "Power" settings, but I want to run the gimbal directly off of the 6S flight pack, if possible. If the motors are wound for 3S packs, i.e. higher kV, it probably wouldn't be a good idea just to turn the power down to 50% and go with it.
Electro 2 is offline Find More Posts by Electro 2
Old Apr 18, 2014, 05:11 PM
Helnet @--X
Helnet's Avatar
Canada,Qc
Joined Dec 2003
Infinity L for sale
Brand New. Already assembled and ready to use it. It is new. I used only one time for testing.
To large for our setup.
Helnet is offline Find More Posts by Helnet
Old Apr 18, 2014, 05:47 PM
Helnet @--X
Helnet's Avatar
Canada,Qc
Joined Dec 2003
Jakub,
Ca I use a canon 700D or t5i and 18X55 lens on the new 3 axis M model?
Old Yesterday, 06:38 AM
jakuban's Avatar
Poland, Lublin Voivodeship, Lublin
Joined Nov 2008
Originally Posted by Helnet View Post
Jakub,
Sure, if I am not wrong this is 580g + 190g = 770g.
Up to 900g is ok for InfnityM / M-P3.
Dimensions of camera are also not a problem.
Camera shelf is 165mm wide and 63mm long.
Best,
Jakub
jakuban is offline Find More Posts by jakuban
Old Today, 12:06 AM
albertog's Avatar
Panama, San Miguelito
Joined Apr 2011
3rd axis
got the infinity 3er axis running...
how do you balance the 3rd axis... any post??? youtube to watch???
thanks
albertog is online now Find More Posts by albertog
Old Today, 12:30 AM
albertog's Avatar
Joined Apr 2011
Bastien hello
how do you balance the 3rd axis?
Originally Posted by helicoblast View Post
Rob,
I checked your video and thought the same about over tightened screws first.
Something else came from what I've seen.
I'm quite sure the yaw axis is not balanced. I've the InfinityM gimbal, quite the same frame but just smaller. All the weight of the assembly is on the rear of the plate attached to the yaw motor, so there's a lot of effort pushed on the motor axis.
Place the whole assembly on the side, to have the yaw axis on the horizontal plan.
Now slide the gimbal in the direction of the yaw motor to balance this axis as well as possible, and try again.
This could explain:
- the behavior of your first and second video, as the motor was fighting the weight of the unbalanced assembly
- the behavior of your last video, where the power is sufficient to fight the weight but the unbalanced weight is still giving problems.
Maybe the over tightened screw does not help in this situation.
Let me know.
Bastien
Build Log CarbonCore Y6 with AG550 gimbal for GH2 dslr DerekB Multirotor Talk 378 Nov 12, 2013 12:40 PM
New Product Molded Carbon Swift Gimbal Multirotor Talk 5 Jan 10, 2013 01:04 PM
For Sale DIY 3 axis Camera Gimbal for DSLR helisfreak Aircraft - Electric - Helis (FS/W) 14 Nov 11, 2012 09:08 AM
Discussion X468 Gator DSLR Gimbal on HD mount Tests cdi3d Multirotor Talk 0 May 08, 2012 02:25 PM
Sold 2 axis Camera Gimbal Large for DSLR or Trade nicnaimless Aircraft - Electric - Multirotor (FS/W) 5 Feb 26, 2012 06:41 PM
