Old Nov 24, 2012, 12:09 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Micro Bandit becomes the Micro Bullet
Well, fitting 4 servos inside the Micro Bandit was getting pretty tight, so I decided to make a delta wing so that I only needed 2 servos. It`s not an exact copy on Brian`s ill-fated Bullet effort, but it`s close enough, so I decided to dedicate the airframe to the Bullet saga.
If my servos show up today, like they are suppose to, I might fly it tomorrow. At this point the airframe weighs 27.6g, just under an ounce. AUW with 200w and 200g (7oz) thrust should be in the 115g (4oz) range.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Nov 24, 2012, 12:30 PM
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
This is ultra cool. Also the insane speed demon I was talking about! Over 1:1 Power to weight... The delta wng should be cool, and I agree with the two servo saving weight kind of thinking. Just like a flying wing, with built in high alpha capability! Hope your servos get here and good luck on the maiden!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Nov 24, 2012, 12:37 PM
EDF Addicted
MustangAce17's Avatar
Ocala,Florida
Joined Sep 2005
looks very nice Lee!
MustangAce17 is offline Find More Posts by MustangAce17
Old Nov 24, 2012, 12:52 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks guys. The mailman just dropped off my servos and 65c lipos.
Old Nov 24, 2012, 12:58 PM
EDF Addicted
Ocala,Florida
Joined Sep 2005
so maiden by 4
Old Nov 24, 2012, 02:28 PM
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
That thing looks incredible!
Hover or die is offline Find More Posts by Hover or die
Old Nov 24, 2012, 07:46 PM
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Has anybody tried vacuum forming plastic into a fuse?
sikky is offline Find More Posts by sikky
Old Nov 24, 2012, 07:47 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks. Glad ya like it. I've always liked deltas. This started as a conventional sport jet, but has now morphed into a delta anyway.
I've spent all afternoon soldering. I'm switching over to 2mm bullets for power leads since I'm going to be pulling almost 15a. So 6 new lipos, 2 balance/charge leads, new leads for an esc. Now charge and cycle the new cells.
Maybe now I can get back to building.
Old Nov 24, 2012, 07:49 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I've thought about it. I think it has potential.
Old Nov 24, 2012, 08:32 PM
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Should give you room, be stiffer,and lite. If done the shell could have the intakes and thrust tube as formers so a thinner plastic could be used.
Old Dec 02, 2012, 11:54 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Well, after spending a bunch of time on a delta wing, fitting everything in place and mounting the wing, it turns out that there`s no way to balance this thing with the delta. It`s mainly because with the intake locations fixed in their spot, the wing can`t go far enough forward and the lipos can`t go far enough back to get the cg right.
I thought about going back to the Bandit style wing/tail, but because of ducting losses I`d end up with about 3.5oz of thrust on a 5oz jet, and that`s not my style. It would be pretty, but would also be pretty slow, and pretty hard to hand launch.
So, I`m scrapping the Micro Bandit and the Micro Bullet.
However, all is not lost. I was ready to build a new Nanospot to take full advantage of 4s and aprox 200w of power. So I cannibalized the Bandit/Bullet parts to slap together the first Nanospot. It will be refined with an all new airframe, but I didn`t want to let these parts go to waste.
I`m done with this thread, at least for now. So join me in the Nanospot thread if you want to see a shot at the 30mm class speed record.
Lee
Nanospot link
http://www.rcgroups.com/forums/showthread.php?t=1755553
Old Dec 02, 2012, 12:43 PM
Current project: Electrolyte
pdawg's Avatar
United States, CA, Torrance
Joined Apr 2004
Sounds great! Records are made to be broken. Breaking the Blowdarts record of 90mph will demonstrate progress. Rooting you on Lee!
pdawg is online now Find More Posts by pdawg
Old Dec 02, 2012, 06:26 PM
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
If you add canards wouldnt that move the cg forward?
chester2240 is offline Find More Posts by chester2240
Old Dec 02, 2012, 06:43 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That`s a good idea and I might have tried that, but the airframe has already been parted out to become the next Nanospot.
Discussion The Blaze becomes The Bullet Tumbler Electric Ducted Fan Jet Talk 198 Oct 28, 2012 12:18 AM
Discussion 6mm Bullets: Next Step Up From 3.5mm Bullets? roo_ster Power Systems 6 May 25, 2012 09:00 PM
For Sale Coonectors, Ultra T, Bullet, Micro and JST Milton Aircraft - Electric - Power Systems (FS/W) 0 Apr 15, 2006 09:44 AM
Discussion Bullet proofing the micro flyer digisteve Scratchbuilt Indoor and Micro Models 0 Jan 31, 2006 06:05 AM
becoming discouraged in HB2 and whole micro heli thing loserbaby Micro Helis 12 Mar 03, 2005 06:25 PM
