Old Sep 22, 2003, 04:53 AM
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Would building the p-fet IRLML6402 n-fet IRLML2502 bridge like Andy mentioned on the bit rx mods page be an alternative to the op amp coil driver? Or even salvaging 2 npn/pnp h bridges from bit rxs?
I was wondering if there was a website with general beginner info on PCB layout and the differences in sizes of components.
I think I found a dip to pic adapter at Digikey.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Sep 27, 2003, 06:05 AM
Joined Nov 2002
I found a few sites with a little info for DIY-LRFRS.
I found a simple page about smd sizes and tips for soldering and a code book so you can figure out which device you have by the numbers.
http://www.marsport.demon.co.uk/smd/mainframe.htm
There is supposed to be some info here about sizes but I was unable to find it.
http://www.ipc.org/contentpage.asp?Pageid=4
Here is a PCB layout program I think
From the screen shots it looks as if you draw the circuit and the program will make a pcb layout.
I think it will output G code or a file that will convert to G code.
gnu electronic design automation
http://www.geda.seul.org/
I still havent figured out the packages I should get.
Is this the correct one for the 12C509A -
PIC12LC509A-04I/SN SOIC 150 mil?
There is ther's also the dip 300 mil This is too big for the RX
and a DFN package not sure about DFN
Billy
Old Sep 27, 2003, 06:33 AM
Australia
Joined Sep 2001
Billy,
Info should be usefull, thanks.
If you want to keep Rx small and light, SN is right part.
Dave
david_dewit is offline Find More Posts by david_dewit
Old Sep 27, 2003, 08:15 AM
Joined Nov 2002
I'm still searching at MicroChip.
Since the 16F84A is rewriteable and the rx code will work on it also I wonder if the SSOP 208 mil package is almost as lightweight as the 12C509A 150 mil ? This would be better for tinkering with the code.
The 12C509A comes in a UV eraseable package but I think it's DIP.
Billy
Old Sep 27, 2003, 12:24 PM
JMP_blackfoot's Avatar
Birthplace of Aviation
Joined Jul 2003
Have a close look at 12F629, you might like it.
Also 16F630, depending on the required number of pins.
Good luck.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Oct 01, 2003, 08:01 PM
Australia
Joined Sep 2001
Bit motor version of balsa living room flyer.
These small balsa models have proven to be very durable, hard to break. Nowhere near the strength of CF, but a fraction of the cost. Wings covered in glad wrap.
Dave
Old Oct 02, 2003, 08:54 AM
Joined Nov 2002
David
Did you get the current draw down?
Or is that a 145 I see there?
Either way what's your gear ratio, prop size,
motor resistance etc?
How does it fly?
I see you have added an airfoil also.
Nice.
Billy
Old Oct 03, 2003, 01:26 AM
Australia
Joined Sep 2001
Billy,
145 LP
approx 18:1
160mm adjustable pitch prop
yellow or orange motor, 500-600mA
6% camber
flies great
Dave
Old Oct 03, 2003, 02:18 AM
Australia
Joined Sep 2001
Couple of pcb layouts as a guide. Change to suit needs.
Almost finished drawing them up on computer, I will replace these drawings when done.
Drawings are fairly acurate. 1sq = 1mm
Cap value in uF
Dave
For Maxim charge pump
Old Oct 03, 2003, 02:19 AM
Australia
Joined Sep 2001
For LTC charge pump
Old Oct 03, 2003, 03:20 AM
Australia
Joined Sep 2001
Maxim1595 schematic
Old Oct 03, 2003, 11:52 AM
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
Hi Dave.
Amazing board designs you have there !
I am yet to aquire that skill, must take lots of pratice.
Could you design one with no booster (there is a LV 12C5xx).
Josh
j8m8l is offline Find More Posts by j8m8l
Old Oct 03, 2003, 06:55 PM
Winter Springs, Florida
Joined Dec 2002
Dave,
Thank you very much for the drawings. Just making those little boards is gonna be hard enough for me let alone designing them.
In your opinion, (or anybody else who has one!), wich would be lighter, the 200ohm coil tied directly to the PIC or winding say two 30 ohm coils with #42 wire and adding the maxim4020 to drive them like Koichi did? Making the actuaters or making the PC boards seem to be about the same level of difficulty so I'd like to do the lightest solution. Put another way, what does that op-amp weigh versus 2 times an additional 170ohms of wire? I weighed a 50 ohm length of #42 wire on my not so great scale and it came in about .2 grams. I've ordered the op-amps anyway.
Rick
Rick Calloway is offline Find More Posts by Rick Calloway
Old Oct 03, 2003, 09:40 PM
Australia
Joined Sep 2001
Josh,
get that done for you.
Rick,
In process of making op-amp version. I got some 1595 and 4020 samples, three LTC charge pumps and enough of other components to make five receivers. Actuators cost me about a dollar to make. When all is said and done I think I'll be a long way in front.
I'll make sure drawing of op-amp version is ok and post it.
50ohm coils is min. for op-amp version I think.
As far as weight goes, could go either way. I couldn't easily get any thin enough pcb. So to reduce weight, I can easily delaminate pcb (single sided) with knife ply by ply untill pcb is about 0.4mm thick, then just give it a light sanding. For double sided pcb I have to join, with epoxy, two 0.4mm pieces back to back. So for 50ohm version, pcb is twice as thick, twice as much copper, through hole links and extra component. This may be slightly heavier. All things being equal (pcb), it could be a little lighter. The decission i think is whether you want more powerful actuators.
I don't use 0603 caps, bit small to work with. I like to get pcb and components ready, with a very small amount of five minute epoxy, glue parts in place, when dry solder.
Dave
Old Oct 04, 2003, 05:59 AM
j8m8l's Avatar
London UK
Joined Apr 2002
Awesome, thanks Dave.
There is one thing that I do not fully understand. Why are OP-AMPs being used, why not H-BRIDGEs?
Josh
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
