Old Oct 18, 2010, 02:22 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
control horns
hey guys, How do you guys build your model's control horns. I keep running into the problem that if I buy control horns the hole are always too big for the wire that I am using. Not only that but my LHS sells 3 for over 2 euro. The builder in me just doesn't like that.
I have used ice creams sticks but it seems the best way of holding them in place is with hot glue. This just adds extra weight. I am starting to build much larger planes now and I have the feeling that this might not be the best method.
What is the best method when creating control horns that give you a little bit control in how much throw you put in? I would love to see different methods people are using because I have 2 planes sitting around ready to fly part from the control horns.
whakahere is offline Find More Posts by whakahere
Old Oct 18, 2010, 04:35 PM
Aurora Municipal, Illinois, United States
Joined Jul 2002
I use 1/32" ply. I cut about 20 or 30 of them with a pair of scissors and drill the right size hole. I have also used some of them gonzo sized cable ties. Clip off a piece as long as you need and drill your own holes. I used a piece of plastic corner bead for drywall as well as those fake credit cards you get in the mail. I glued the all with just enough epoxy to get the job done. I use this on foamies up to about 30" or 1lb. Anything bigger and I just use commercial control horns. I bought a bunch of 1/2A controls horns and recycle them when I toss a plane. I'm sure there are 100 other snarky control horn ideas on here.
bullseye000 is offline Find More Posts by bullseye000
Old Oct 18, 2010, 04:41 PM
Crash it first, Then fly it
Griffindor's Avatar
The Big Apple
Joined Jul 2008
You could also use old credit cards, and cut them.
Another idea is to use zipties, but those aren't so good.
I've tried this once: you could use the back end of a pen ( the clicky part) and us that, Drill a hole in it for the control rod. I don't know if this is good, because the plane I used it on never flew
I wouldn't really suggest using my latter method, its' just a idea
Griffindor is offline Find More Posts by Griffindor
Old Oct 18, 2010, 04:50 PM
treefinder
springer's Avatar
SE MI
http://www.rcgroups.com/forums/showp...postcount=8810
Here's how I do it. credit cards, works for large and small planes. Haven't bought a store bought horn set yet. I do like hot glue best, but i position the horn on foam control surface, then cut slot with xacto, poke some holes in the horn base that goes into the foam, apply small bead of glue to bottom edge and press in. I usually add a small fillet bead especially on larger planes.
springer is offline Find More Posts by springer
Old Oct 18, 2010, 05:11 PM
lake flyer's Avatar
Joined Nov 2005
If you are flying water planes or flying off wet grass , be sure to waterproof your ply horns . They get very weak and bendy when they get wet . I coat mine with epoxy or use credit cards.
lake flyer is offline Find More Posts by lake flyer
Old Oct 18, 2010, 05:30 PM
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I use popsicle sticks, Lite Ply and credit cards and drill out the hole size and location where I want it.
RogueTitan is offline Find More Posts by RogueTitan
Old Oct 18, 2010, 05:46 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
looks like I am finding credit cards to cut up. they are bad anyway right??
The problem I do have is that in Germany they don't seem to be giving out free credit cards. I will need to find some other plastic card type. Off looking now!
thanks guys.
Old Oct 18, 2010, 06:44 PM
Out the Window
High Flyin''s Avatar
North Central Florida
Joined Jul 2004
whakahere
Also try looking at gift cards in local stores. There are lots out around Christmas here in the States. You can get a couple of them and just not put prepaid cash on them.
High Flyin' is offline Find More Posts by High Flyin'
Old Oct 18, 2010, 10:04 PM
biznak's Avatar
Bellingham, wa
Joined Oct 2009
i am using bread tabs on my scratch cub, and used some of the frame from my floppy disk (hinges) to make horns for a different project, to drill the hole i just use a piece of the wire.
biznak is offline Find More Posts by biznak
Old Oct 19, 2010, 12:57 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I love the gift card idea. So basically I tell them I need it so I can buy their goods and ... sorry I cut it up to make control horns. Great idea
Old Oct 19, 2010, 02:00 AM
Ajutor de băgător de seamă
San Carlos, CA
Joined Mar 2004
Excellent idea! Maybe they use the same thing in Germany too. For those who don't know what a bread tab is, the first hit on google images is a good picture of one.
gigelus2k3 is offline Find More Posts by gigelus2k3
Old Oct 19, 2010, 03:54 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
We do have those bread tabs .... the thing is that is on the cheap bread and my wife only buys the best. She is German and bread mad!
I am now looking out for all the things I can find. Looks like I won't be buying control horns anymore!
Old Oct 19, 2010, 05:21 AM
Flying more::repairing less
trteboe's Avatar
The Alamo City
Joined Feb 2007
I have used Dental Flossers. You can buy a whole bag full for a buck at Dollar Tree.
Lots of good idea in this thread: http://www.rcgroups.com/forums/showthread.php?t=856127
trteboe is offline Find More Posts by trteboe
Old Oct 19, 2010, 09:17 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use the 1/32 ply for the smaller planes. I have drilled smaller holes between the holes in commercial horns. Square drain pipe works well for larger horns using the right angle corners. Great for disposable combat planes.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Oct 19, 2010, 09:25 AM
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
Be careful using the thin ply for larger planes. I made fairly large 1/32" control horns for my 55" Edge, and broke an aileron horn on the maiden flight. Replaced them with gift card horns, and have not had any problems since.
anatoly is online now Find More Posts by anatoly
Discussion heavy duty control horns placement Aerosapien 3D Flying 2 Oct 09, 2010 09:55 AM
Discussion Installing Control Horns swordds Scale Kit/Scratch Built 9 Sep 10, 2010 09:51 AM
IFO control rods/horns setup for Focus III dezflyer Parkflyers 3 Jul 30, 2001 03:28 AM
Twin Jet control horns. phillip Foamies (Kits) 3 Jun 28, 2001 06:10 AM
