Old Feb 07, 2016, 04:57 PM
AirspeedNZ is offline
Find More Posts by AirspeedNZ
AirspeedNZ's Avatar
North Island of New Zealand
Joined Jan 2009
Build Log
Shock Fox Including plan.
Thought I'd share with everyone what I started to put together yesterday
At this stage most of the parts have been cut out and dry fitted to test for alignment - Looking okay for the most part.
I have added the PDF of the original plan here
AirspeedNZ is offline Find More Posts by AirspeedNZ
Last edited by AirspeedNZ; Feb 12, 2016 at 10:42 PM. Reason: Addition of PDF plans
Old Feb 07, 2016, 05:55 PM
AirspeedNZ's Avatar
Joined Jan 2009
Just the KFM portions and spars to add then the radio gear before a few test flights in the back yard to see how it glides. Will update with further photos etc once done.
Old Feb 09, 2016, 03:37 AM
AirspeedNZ's Avatar
Joined Jan 2009
No progress today unfortunately as I had that horrible thing called work to take care of. And there where perfect flying conditions today too dammit.
Old Feb 10, 2016, 02:09 AM
AirspeedNZ's Avatar
Joined Jan 2009
Spar slots cut in the wings tonight though I found that my straight edge was a little less than straight lol. Will have to use a little filler in small areas around the spars. more photos to follow soon.
Old Feb 11, 2016, 12:09 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
interesting!
Your design?
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Feb 11, 2016, 12:14 AM
AirspeedNZ's Avatar
Joined Jan 2009
No Ward, not my design but one I found online some time ago. Just thought it was the right time to have a shot at seeing what it could do. In light conditions at work on my lunch breaks I should be able to get a flight in.
I have modified the wing though to try out something that I haven't before. (Made it a KFM wing of sorts)
AirspeedNZ's Avatar
Joined Jan 2009
Still thinking about the best gear setup for it at the moment.
Old Feb 12, 2016, 10:15 PM
AirspeedNZ's Avatar
Joined Jan 2009
More photos
Firstly a big thank you to Peter Gollagher for the assistance with the assembly this afternoon. Here are some more photographs of the assembly. Final work to do will be the trimming of the leading edges and an overall check of the CoG before a quick few test glides. then add the radio gear and wait for a good day to maiden the Shock Fox.
For Sale Fox R?CCarburetor , Fox carb adapter and Fox carb body for C/L engine apilgrim Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 10, 2015 10:25 PM
Discussion I'm shocked! Shocked to learn that government loans = tuition hikes ... logan5 Life, The Universe, and Politics 2 Jul 08, 2015 01:08 PM
Question the Meaning: 30WT shock oil & #300 Shock Oil Hugo Reyes Off-road Cars 5 Jun 05, 2014 09:00 PM
Discussion Shock Oil, Shock Size, and Diff Oil for Trooper bjc4073 Off-road Cars 2 Dec 16, 2013 02:40 PM
Discussion Shocks,shocks,shocks......Axial wraith 1111Mavrick Rock Crawlers 3 Nov 23, 2011 05:57 PM
