Old Jul 29, 2004, 02:10 AM
yshimoni is offline
Find More Posts by yshimoni
Joined Nov 2003
Any CNC mill control board design???
My next project is a CNC mill.
Since I can make some simple double-sided PCBs I`m looking for a 3-4 axis CNC control board schematics/design.
The control board looks simple, charging $100-$399 for it looks a bit high for me…
yshimoni is offline Find More Posts by yshimoni
Old Jul 29, 2004, 03:11 AM
KOEZE is offline
Find More Posts by KOEZE
KOEZE's Avatar
The Netherlands
Joined Feb 2004
I'm building this one with a few modifications.
http://magiist.free.eplanet.hu/_dwad...i/ProfiEng.htm
Modifications are mainly seperating the output stage (expensive) from the controller stage so that I can also use it with my expiriments with controlling my mill serially (very fast because you send commands to the pic that translates these into the required PWM signals instead of letting the pc do that and having the LPT port as a bottleneck)
Check out www.luberth.com/cstep and click the link on the top left corner for more info and some videos
EJK
KOEZE is offline Find More Posts by KOEZE
Old Jul 29, 2004, 03:44 PM
kfong is offline
Find More Posts by kfong
Sterling Heights, Michigan, United States
Joined Nov 2003
Try this instead, schematics are online and the boards are a proven design.
http://www.embeddedtronics.com/microstep.html
Works with any software that provides step and direction control. Will need one board per axis. There is also a breakout board that works with EMC and other CNC software that can reconfigure i/o pins.
Kin Fong
kfong is offline Find More Posts by kfong
Old Sep 12, 2004, 10:15 PM
pjr is offline
pjr
Find More Posts by pjr
pjr
pjr's Avatar
Porto Alegre Salgado, Brazil
Joined Aug 2004
try this link .. http://www.cenece.com/
this board have 4 axys and its very easy to build ...it also could be used with a lot of comercial softwares ..
pjr is offline Find More Posts by pjr
Old Sep 13, 2004, 12:52 PM
yshimoni is offline
Joined Nov 2003
thanks for the replys...
Old Sep 13, 2004, 06:49 PM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
I built a small CNC mill using stepper motors about 15 years ago that looked exactly like the one in KOEZE's post. www.luberth.com/cstep I used the parallel port of a PC with opto isolators driving a CD4052 on each axis as a 2 line to 4 line decoder. The 4052 turned on one FET at a time to drive the axis. That way it only took 6 of the 8 bits available on 1 port to drive all 3 axes. I used light bulbs to limit the current on the steppers from a 24 volt power supply, so I didn't need a PWM on the stepper drivers. Did you want to use stepper motors, or DC motors for your machine?
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Sold Socal: CNC Stepper motors, Control board, Axis motoryder Aircraft - General - Miscellaneous (FS/W) 7 Sep 11, 2006 11:21 PM
*EBAY*- CNC Control board with hotwire board Randy G Aircraft - Electric - Airplanes (FS/W) 0 Jan 19, 2005 10:13 PM
Any CNC Machinest here? Mike Hall Electric Plane Talk 2 Jul 27, 2002 04:15 AM
My neighbor has a CNC mill and a Laser Cutter!!! JStory Electric Heli Talk 1 Dec 01, 2001 07:42 PM
