Old Oct 03, 2015, 02:46 PM
Ken Lapointe is offline
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Dynamax Conversion Kit wHK-5035-700KV
I ordered the Dynamax Conversion Kit wHK-5035-700KV from scorpion motors.
How could I pass it up at only $250 shipped to my door. Heck, most motors will cost at least that.
Comes with motor mount, collet and motor
Package arrived quickly. Its nicely packaged in a tin box with heavy foam.
Pretty large motor, a good bit larger than the hacker that was in the XPS conversion. I took pictures to show the comparison. Of course that also means its heavier.
1 lb 8.4 oz, for the Scorpion and 14.9 oz for the hacker
The mount and assorted bits weigh in at 5.2 oz
I did run into one issue so far when putting the stator fins on the motor housing
The long stator fin hits the motor since the motor is larger in diameter than the motor housing.
This was probably not an issue with the 4000 series motor, but the fin hits the motor with the 5035
I guess the only option is to sand bottom of the end of the fin so it doesn’t hit the motor.
Its only 2 of the stator fins that are like this, the others are short enough that they dont hit anything.
I'll post more after I get things cut down and assembled.
Ken Lapointe is offline Find More Posts by Ken Lapointe
Old Oct 03, 2015, 08:02 PM
lrb75 is online now
Find More Posts by lrb75
United States, VA, Springfield
I have one too. They look nice. Bruff has had good experience with this conversion. I have always changed the bearings on scorpion motors to ceramic before putting the fan in use but it really shouldn't be needed. Get ready for the bill from FEDEX. There was a $5 customs fee that had a $7 convenience fee tacked on.
lrb75 is online now Find More Posts by lrb75
Old Oct 03, 2015, 08:42 PM
Phil Lin is offline
Find More Posts by Phil Lin
Joined Aug 2015
That looks like a good deal.
I helped a local flyer who wanted to convert his glo-dynamax. We ordered the smaller motor then in the deal pkg.
There was one problem when we test ran the fan on a rig. I was looking out in case there was vibration. Sure enough. Turns out the impeller driving washer had a face not square with the bore hole.
Another part he had on hand was substituted & the vibration dropped to normal range. Just something to look out for.
If you get a chance to run your conversion, pls post your motor & fan figures if you can. TIA!
Phil
Phil Lin is offline Find More Posts by Phil Lin
Old Oct 03, 2015, 11:16 PM
Par_18 is online now
Find More Posts by Par_18
United States, VA, Virginia Beach
Joined Dec 2005
I should be receiving mine tomorrow and i'm looking forward to running it. Have you had a chance to run it yet? If so, i'm very curious about the data.
Par_18 is online now Find More Posts by Par_18
Old Oct 04, 2015, 09:31 AM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I did an angle cut on the stator to clear motor.
Bob
bruff is offline Find More Posts by bruff
Old Oct 04, 2015, 11:00 AM
Narragansett, RI
Joined Oct 2000
I cut a simple notch on the end
now I need to build a simple stand for a bit of testing
Old Oct 04, 2015, 12:03 PM
jefffassbinder is offline
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Watts/Amps
Post some numbers when you get a chance Watt/Apps on how many XXs batteries. Curious what this system can do.
jefffassbinder is offline Find More Posts by jefffassbinder
Old Oct 04, 2015, 12:53 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
With a few of you guys having bought this Conversion Kit, it will be nice to see some numbers B-4 I decide to order one..
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 04, 2015, 01:23 PM
Joined Dec 2005
Ken,
I have heard reports about excessive vibrations caused by bent motor shafts. I'm sure you've ran the motor without the fan on already. Did you notice any issues?
Old Oct 04, 2015, 02:05 PM
Narragansett, RI
Joined Oct 2000
Havent run it yet, have to solder on some bullets to the wires still
Old Oct 04, 2015, 10:06 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
Ken:
Looking forward to the "numbers" on this motor/fan combo. I have run the 4035-630KV motors on my Dynamax fans and they run well. However, I have found that the weak link in this motor is the bearings. The Scorpion/Innov8tive Designs website says to lube the bearings every six flights. So, I determine the bearing sizes and then order some ceramic bearings from Boca bearing. The only other thing I have found is that the motors do not tolerate very much current above the stated max for the motor.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Oct 05, 2015, 05:01 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Par_18 View Post
Ken,
The vibration is most likely from fan that's not dynamically balanced (all components balanced together as one vs separate)
I doubt those scorpion shafts can come bent
If anyone needs their fan balanced to 14s pm me
erh7771 is offline Find More Posts by erh7771
Old Oct 05, 2015, 07:01 PM
Joined Dec 2008
I'm looking forward to the numbers Ken Lapointe, Par_18, and lrb75--post.
I want to compare them with what ED ( A10pilot ) has told me awhile back on his Tams Dynamax motor conversion kit/ Het 800-68-685 Motor on 12s- vs - this one.
This one is cheaper--BUT--does it any better???
Old Oct 05, 2015, 07:06 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
is there a bearing in the alum motor adaptor ? it looks to me that would help support that long shaft... just a penny or two of my thoughts .
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 05, 2015, 07:07 PM
Joined Dec 2005
That is what I figured as well. Even the worst quality control would catch a bent shaft. I balanced my fan today with the spinner on it and should have some numbers/video by tomorrow. I'm looking forward to it.
Wanted EJF convertion kit for Dynamax hproa Aircraft - Electric - Jets (FS/W) 8 Sep 30, 2015 01:15 PM
Sold Dynamax Fan with Scorpin HK 5035-650kw goforit Aircraft - Electric - Jets (FS/W) 4 Aug 10, 2014 06:40 AM
Sold Convering - 12 rolls unopened edbu1 Aircraft - General - Miscellaneous (FS/W) 1 Apr 06, 2014 10:27 AM
Discussion Convered Dynamax Fan CoolerByTheLake Electric Ducted Fan Jet Talk 0 May 28, 2012 07:49 PM
Discussion Dynamax Conversion Kit w/HK-5035-700KV from Scorpion Ron101 Electric Ducted Fan Jet Talk 5 Apr 26, 2012 06:55 PM
