Old Aug 07, 2015, 02:14 PM
rafterrc is online now
Find More Posts by rafterrc
Callused Thumbs
rafterrc's Avatar
Joined Jun 2015
In my Radian Pro, I have taped one along side the servos on the right side of the Rx/servo bay and stuffed the other one vertically, twisted at ~90 deg from the other one down (plane upside down) the battery recess. Yesterday, I was somewhere between 2,000 and 3,000 ft altitude (eyeball and trigonometry no vario), and got an RSSI alarm at 45. The ship was 2-3000 ft away. I was hoping for something more like a mile.
I might be able to get them on the hatch not sticking down but parallel to the fuse using the 3D printed Aloft Hobbies' fixture. I guess I'll try it with appropriate antenna protection for landing.
On 8/21/5:
I did try the PCBs on the belly of the plane, horizontal (parallel to the longitudinal fuse axis). The result was poorer reception. If there were room between the canopy and wings, I'd bore two holes at 90 deg from one another, and try there. I'm now positive that the one antenna close to the servos presents some interference, because the signal is weaker with the servos between the Tx and Rx. I'd even try it without the plastic covers, if I know that I could orient them rotated 90 deg from one another like the 3D printed fixture.
rafterrc is online now Find More Posts by rafterrc
Old Oct 10, 2015, 08:44 PM
RyanBRZ is offline
Find More Posts by RyanBRZ
Joined Dec 2014
I just received a set of these PCB antennas to be used with a FrSky D8R-XP receiver. On the tx end I have a FrSky DJT module with a 7db patch.
I just ordered one of those mounts that hold each antenna on an angle, 90 degrees from each other, with one turned 90 degrees which is supposed to improve reception.
Do you guys agree that mounting these on the rear undercarriage of my frame will work while also having my vtx antenna pointing upward also on the rear of my frame? Trying to avoid interference.
RyanBRZ is offline Find More Posts by RyanBRZ
Old Nov 08, 2015, 07:44 AM
Tom T is offline
Find More Posts by Tom T
Learning to crash
Tom T's Avatar
United States, IN, Indianapolis
Joined May 2014
I just wasnt happy with the PCB antenna stuffed next to the servo in the bay of my Radian pro and the other PCB antenna hot glued horizontally on the back of the bay under the canopy. So I swapped them out for the longer antennas with the little balun coils. seems to work a little better. But to be honest I still dont get the range I think I should while monitoring the RSSI from my X9D+ and X8R rx. Even though it passes a range test out to 150' in all directions. I just dont like to hear my RSSI calling out 55-60 or less when the planes only 400+ out and 150' up. My SWR is always at 0 or 1, and even cupping the TX antenna with my hand I can make my SWR raise up to 13+/- and come back to 0 or 1 again. I've got a 5dbi replacement antenna for it, but havent installed it yet. No issues flying a big quad out to 3500+ feet with an X8R and same TX.
Tom T is offline Find More Posts by Tom T
Old Nov 10, 2015, 06:55 PM
marcus le renard is online now
Find More Posts by marcus le renard
Joined Sep 2015
Mines are mount with the 90 degree holder from Bangood right on top of the canopy of my hobbyking sky eye. With a 5dbi whip antenna I manage to get 4,8km today (almost 3 miles).
*Don't judge my little guy, he's been through a lot
I'll try to place them on the side because the signal get blocked by the motor when I'm flying straight. Will keep you update!
marcus le renard is online now Find More Posts by marcus le renard
Old Nov 11, 2015, 12:49 PM
Joined Sep 2015
Alright try it again today with the antennas on the side at 90 degree. Got 5148m far at 816m altitude.
Great lost of signal when turning right. I'll try to mount them at the same place and angle but farther of the fuselage.
I might receive my 7dbi patch antenna on Friday. With this one I'll probably be able to reach 10km easily.
Old Jan 05, 2016, 11:02 PM
TiborZalo is offline
Find More Posts by TiborZalo
quads
Joined Dec 2015
hi guys i smashed the end of the 8xr antenna using one of these mounts under the quad. Good reception bad placement... is there an actual replacement for the antenna Can find much on the web. One side is still working but i have tested it much.
QUOTE 'No issues flying a big quad out to 3500+ feet with an X8R and same TX.' QUOTE
TiborZalo is offline Find More Posts by TiborZalo
Old Jan 06, 2016, 12:36 AM
Joined Sep 2015
RMRC is back order but rangevideo have them in stock: http://www.rangevideo.com/receivers/...enna-pair.html :-)
Help! FrSky Rx Antenna Placement Questions changosurf FPV Talk 3 Jan 15, 2016 06:19 AM
Discussion PCB antenna orientation and placement question pelted FrSky 1 Apr 30, 2014 07:28 AM
Sold NIP FrSKy X8R S.Bus Receiver with PCB Antennas punkindrublik Aircraft - General - Radio Equipment (FS/W) 2 Jan 01, 2014 09:12 PM
Discussion Jr 9303 and FrSky Module - Tx Antenna placement Fly2High Radios 5 Apr 24, 2012 12:47 PM
Discussion FrSky antenna placement and range WiseDuck Radios 4 Feb 19, 2012 12:41 PM
