Old Aug 01, 2013, 01:17 AM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Jack
Check in my blog:
Electric ducted fan motors
http://aeromodelismoelectrico.blogsp...arch/label/EDF
Manuel V.
manuel v is online now Find More Posts by manuel v
Old Aug 01, 2013, 08:32 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I'll bet it does. Is the back plate and bearing tube composite too? Or does that transition to metal in there somewhere?
It think it was E-Flite that had or maybe even still have a motor with a plastic base that didn't do well in service. It was on the first generation foam glide that became so popular, really a good plane, but the motor base (it had threaded insert molded in for mouning) would develop cracks over time, probably from the heat.
Those aluminum bearing tubes and backplates are the primary route for gettng heat out of the windings. I always touch that base of the motor first to check for heat.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 05, 2013, 06:27 AM
Entropy76 is offline
Find More Posts by Entropy76
The Last Question
Entropy76's Avatar
United States, UT, West Valley City
Joined Oct 2006
Jack
Yes, the bearing tube and backplate are one piece molded in high temp composite. The front has an aluminum motor mount and front bearing that goes approximately 5mm into the composite and same with the aluminum stator tube which holds the middle and rear bearings.
I usually cut off the backplate, or what I called the guard earlier, for ease of winding. This stator was obviously wound before being pressed into the composite.
Entropy76 is offline Find More Posts by Entropy76
Old Sep 28, 2013, 09:44 PM
manuel v's Avatar
Joined Aug 2004
I install 2 or ring of 17.8mm diameter x 2.5mm
But better best one 17.8-18 x 3mm.
In EDF with 28mm duct.
In one EDF of 30.5 as XRP 14B is best a thicker ring.
Around 4mm.
11 turn with 20AWG is easy.
But you can use 21AWG.
This motor is for Wemo mini fan 68mm. to 4-5slipo.
I'm about to RECEIVE one 70mm EDF 10 blades and a 14.
As can'll post the results with the new engine rewind.
Manuel V.
For Sale $200.00 Quick Sale CC 125 esc CC bec hoffman wild beast Het 6404 edf fan mechengineer03 Aircraft - Electric - Power Systems (FS/W) 0 Jan 24, 2013 10:00 PM
Sold Hoffman Beast and Wild Beast EDF motors Gravity Dodger Aircraft - Electric - Jets (FS/W) 6 Nov 23, 2010 03:22 PM
Sold Hoffman Beast & Wild Beast hole digger Aircraft - Electric - Jets (FS/W) 4 Mar 18, 2010 11:17 PM
Discussion Twister W/ Hoffman EDF-70 (Beast) motor video MikeMayberry Foamy EDFs 10 Dec 04, 2008 11:27 PM
Sold Hoffman magnetics Beast 70mm EDF motor and Pentium 80 ESC The Don Aircraft - Electric - Jets (FS/W) 2 Nov 15, 2008 07:09 PM
