Old Jan 23, 2016, 09:06 PM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
Originally Posted by HGhost View Post
I like the little short one armed one in the front
Ok, thanks! Is it ok if I put both the aileron control wires in one hole or do I put them into two adjacent holes?
Lentar is offline Find More Posts by Lentar
Old Jan 23, 2016, 11:56 PM
HGhost is offline
Find More Posts by HGhost
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
IF you are using them for the Ailerons, it is probably best if you use the Servo Arm you circled
I do not think you can get Both rods into one hole
IF you put in separate holes you will get more travel on one than the other
I missed your post where it said "aileron"
All of mine have the little servo arm, except the servo for the ailerons
HGhost is offline Find More Posts by HGhost
Old Jan 24, 2016, 08:08 AM
Lentar is offline
Joined Oct 2012
Unfortunately I don't have the type I circled, since I got the kit without any electronics. I do have a servo with a round servo arm that I could use. Will that be ok?
Old Jan 24, 2016, 01:10 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Where the Aileron servo sets There is no room for a round "arm"...there is just a slot there.
You can try to put both control linkages in one hole....it will work if you make the hole larger on that smaller arm .
the way i have found easiest to do that is, I use a large sewing needle hold it with pliers...and heat the needle and then insert it in the hole to enlarge the hole to the right size without making it to large or cracking the plastic.
Old Jan 24, 2016, 03:37 PM
Late99 is offline
Find More Posts by Late99
Late99's Avatar
Finland
Joined Aug 2013
If you've got some modelling ply or even old credit card or similar plastic you can modify your own arm like the original one. Just cut little larger piece, drill those two holes and then glue this to original single arm and use couple of small screws to ensure that it will stay fixed...
You just need some very basic tools such as knife & small drill.
I've done several extended arms using this technique.
Late99 is offline Find More Posts by Late99
Old Jan 24, 2016, 04:22 PM
Lentar is offline
Joined Oct 2012
HGhost and Late99:
Some very interesting ideas! I can do that with CC plastic. (I have also found a simple way to use a cheap, readily available 2212 motor with the spring mount, which I will post later)
Old Jan 26, 2016, 02:43 AM
NubiNewbie is offline
Find More Posts by NubiNewbie
Joined Jul 2015
Ghheee!!! Yak12 PNF on backorder in Europe as well as Int.warehouse!
But they have the ARF/kit-version, so maybe that's a way to go.
* Standard 9g servos fit nicely everywhere?
* Any info/advice on alternative motors? The HK-suggestion D2826-6 2200kv is supposed to give 342w/34A - isn't that a bit overpowered?
* Also reads like fitting alternative motors is a bit awkward - any advice?
Thanks!
NubiNewbie is offline Find More Posts by NubiNewbie
Old Jan 26, 2016, 09:58 AM
Lentar is offline
Joined Oct 2012
1. My simple solution to the motor problem. Here I have a 2212-2200kV motor. I used two shims (arrow pointing to one set) and a longer mounting screw through the 16mm holes in the motor. The shims lift the motor can away from the mounting plate, allowing me to use my $7.50 motor and prop adapter, rather than the expensive 2226 motor that is difficult to find.
2. 9g micro servos will fit, but you will need a special servo horn for the aileron servo wires (see my posts and the solutions proposed by HGhost and late99). You could also get the copterx 9g servo which has that type of horn.
3. The kit has 2 props which you can't use unless your motor has a 3mm shaft for the included prop adapter. So you will need a collet type adapter for your props plus props. I will use 64e props.
4. For the ESC I am going to use a YEP 30A.
If you are a true newbie, I would suggest wait for the PNF to come back in stock instead of getting the ARF.
Description:
Old Jan 27, 2016, 01:29 AM
Joined Jul 2015
Thanks!
Seems it would be wise waiting!
Old Jan 30, 2016, 10:24 AM
Joined Jul 2015
...or does anybody has another suggestion for a rather small newbie-plane that can easily be handlaunched (bellylanding is also OK)?
My SportsCub S is so light/small it's very sensitive for wind, so a slightly larger plane was what I was looking for when the Yak12 came up - and then disappeared into the backordered items...
Old Jan 30, 2016, 02:59 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Well I use the E-Flite SAFE Reciever in multiple planes, so almost every plane can be a beginners type plane .
I have an array of planes, I like the size of the Yak 12, and it is hard to find good planes in that size most are always larger or far smaller
The Wilga is a very nice plane it has flaps, it flies much like the Yak 12, it is the same size
The Hobby Zone Super Cub is a nice plane-but it is 3 ch and has SAFE
Also the Delta Ray is a nice plane it also has SAFE but has brushed motors
The Apprentice or the Sportsman S Plus...but both are very large.
Hobbyzone Stratus
just depends on what you are looking for.
Old Jan 31, 2016, 07:51 AM
Lentar is offline
Joined Oct 2012
Like HGhost said, you could get the Hobbyking Wilga (fraternal twin of Yak 12). Or check the Hobbyking Sky Easy (1050mm pusher prop belly lander) in my opinion the best looking pusher prop out there.
Old Feb 10, 2016, 11:29 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
I just snatched up the last Yak 12 in the East Warehouse. A friend of mine got one of these about a year ago, and we had a ball seeing who could keep it in the air with full flaps and under 2ft altitude. With the stock setup, we were getting close to 20 minutes flight time on a 1.0Ah pack. Friend has drifted away from our flying circle of friends, so its time to get my own to park next to my little Wilga.
-CC
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: GWS Funny Park
Old Feb 17, 2016, 12:54 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Maiden flying session with the Yak12 this morning. I had eight 1000mah batteries with me, but I only flew 4. Timer set to 12 minutes with mixed throttle. I swapped the tiny stock tires for some 2 inch units I had in my scrounge box. Had to take the dremel to the hubs to get them to fit on the short axle. Plane flew great.
-CC
Hobbyking Yak-12 Maiden (2 min 1 sec)
Old Feb 17, 2016, 03:00 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Nice Video
Can't beat the Yak's...they are smooth and relaxing flyers...and with a little aerobatics thrown it
was sweet.
New Product EasySky 5Ch Yak-12 tymodel Scale ARF/RTF 2 Apr 29, 2014 11:23 PM
Build Log Rc-Drones Kong8 XL 950mm X8 build w/AG550-NX gimbal Z06 Tony Multirotor Talk 23 Jul 21, 2012 11:15 AM
Discussion 12" WS Yak Torque Issue super_dork 3D Foamies 3 Apr 16, 2012 02:29 AM
For Sale Great Planes 51" Yak-55M Wheel Pants + Wheels NIB $12 Shipped CONUS parkflyer215 Aircraft - General - Miscellaneous (FS/W) 3 Feb 27, 2012 11:49 AM
