Old Feb 03, 2016, 09:18 PM
Jasper Q is offline
Find More Posts by Jasper Q
event horizon
United States, FL, Lighthouse Point
Joined Oct 2014
Discovered that baro resets to O when armed, I had asked that's question earlier as to why the baro jumped around sitting on the bench, when armed it reports 0 ft. and pretty much stays there while sitting.
Jasper Q is offline Find More Posts by Jasper Q
Old Feb 03, 2016, 09:58 PM
Jasper Q is offline
event horizon
Joined Oct 2014
Discovered in order for alt hold to work hover throttle PWM needs to be monitored/noted and adjusted in the code. Then Alt hold works well.
This were I heard it although I can't exactly understand everything he says.
Program Altitude-Hold on Super-X micro quad (multiwii nano) (6 min 22 sec)
Old Feb 22, 2016, 05:42 PM
newtoallthis is offline
Find More Posts by newtoallthis
Joined Feb 2016
hi i am having troubles with my MULTIWII PRO EZ3.0 FLIGHT CONTROLLER W/ GPS OPTION, arduino reads the right com port but multiwii does not. i'v searched and searched but not alot of this makes sense yet. i'm still learning. just wondering what you would suggest.
newtoallthis is offline Find More Posts by newtoallthis
Old Feb 22, 2016, 05:53 PM
Nickshchaos81 is offline
Find More Posts by Nickshchaos81
United States, MT, Great Falls
Joined Jan 2014
The multiwii can only output to 1 comport at a time. So make sure you don't have anything plugged into telemetry
Nickshchaos81 is offline Find More Posts by Nickshchaos81
Old Feb 23, 2016, 11:12 AM
Joined Feb 2016
so unplug telemetry?
Old Feb 24, 2016, 03:31 PM
Joined Feb 2016
ok, i got the com port to show in mission planner but it won't connect it says it does not detect a heart beat.
Old May 25, 2016, 11:58 AM
Zviki is offline
Find More Posts by Zviki
Joined Mar 2016
Is driver correctly installed? Look for it in "device manager" under "Ports". And only Mission planner should be open on PC (I mean without any flasher or similar apps).
Sent from my SM-N910C using Tapatalk
Zviki is offline Find More Posts by Zviki
Old May 25, 2016, 12:12 PM
Zviki is offline
Joined Mar 2016
My problem is that I can't get Spektrum ar6200 receiver to work. At the moment is MegaPirateNG on my drone, v3. 0.1-R4, because there's a gps drifting with the "latest" 3.1.5-R2 version. Now I'm trying to flash Multiwii 2.4 with Arduino, but what IMU to choose for HK Multiwii pro board? Any suggestions for better firmware (quadX)?
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 01:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 04:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 03:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 10:29 PM
