Old Feb 21, 2013, 10:06 AM
ncp546 is offline
Find More Posts by ncp546
Joined Mar 2012
Question
Miss Elam Upgrade Motor QUESTION
Hey guys, well i have a 1/12 scale Miss Elam, long story short there was a fire in the middle from the electronics. I had to replace everything in it. All electronics that is, so during all my runs water would always get into the hall and motor. Finally at the end of the season, my motor got corroded and stopped turning over.
It was the stock one though that ran with all my new electronics. SO here is my question, what is the fastest motor i can put into my Elam? My electronics consist of:
AquaCraft 60 amp brushless esc lipo ready
Spectrum 2.4 GHz DSM SR200 sport surface receiver
Waterproof traxxas survo
& my controller DX2E DSM radio system.
The boat runs off two 2s lipo batteries. Hobby town did my new electronic swap just to let you know.
Hope to hear some answers! Thanks guys! (and girls maybe)
ncp546 is offline Find More Posts by ncp546
Old Feb 21, 2013, 01:35 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Something in the 2000-2200kv range is your best bet, not sure if a 3674 will fit or if it's too long and you're limited to 3660's?
wparsons is offline Find More Posts by wparsons
Old Feb 23, 2013, 03:47 AM
cyberhoops is online now
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
I think an AQ UL-1 motor would provide all of the speed that hull can handle. With the right prop it could hit 50 mph on 4s, which I think is very respectable, even though I am not sure the Elam hull will stay on the water at that speed.
cyberhoops is online now Find More Posts by cyberhoops
Old Feb 26, 2013, 02:04 PM
ncp546 is offline
Joined Mar 2012
Wow! Saw a video and im impressed! however i only have a 60 amp. Could it handle it? Where can i find this motor as well, i cant find it!
Old Feb 26, 2013, 04:51 PM
dobydog6507 is offline
Find More Posts by dobydog6507
Joined Oct 2011
http://www3.towerhobbies.com/cgi-bin...&I=LXVSV3&P=ML
The 60 amp AQ controller is designed for this motor.
dobydog6507 is offline Find More Posts by dobydog6507
Old Feb 27, 2013, 08:54 AM
ncp546 is offline
Joined Mar 2012
And that will make my boat do this?
Miss gieco ul1 motor 4s2p m445 (0 min 30 sec)
and it wont fry anything?! I cant afford another fire in the boat.
Old Feb 27, 2013, 10:32 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
The UL-1 motor and the 60 amp controller will work fine together. Combine that with a reasonable prop, up to something like an m645, and you should see similar performance to the video and no fires.
Old Feb 27, 2013, 12:48 PM
Joined Oct 2011
http://www.youtube.com/watch?v=FafgQb7cP5M
It should.... as for fires, it all depends on your prop selection and boat set up....the UL-1 motor and 65 Amp controller have been proven in LOTS of race setups over the past few years.
It also sounds like you need to educate yourself on post run maintenance...a simple shot of WD-40 into the motor after each run where you got water in the hull would have prevented to motor from coroding.
Old Feb 28, 2013, 09:20 AM
ncp546 is offline
Joined Mar 2012
Yeah my father told me after it broke (you should of been spraying lubricant in there ) Thanks for the tip, when spring rolls around im going to pick up a few cans. Thanks for the tip!
Old Feb 28, 2013, 09:40 AM
ncp546 is offline
Joined Mar 2012
Here is my boat set up right now. The prop is the standard one that comes with the boat.
For Sale Pro Boat Miss Elam Brushless Cowl - NEW Darin Jordan Boats (FS/W) 1 Feb 11, 2013 10:02 PM
Discussion Miss Elam Converted to Miss Bud Electric velyter Racing Boats - Electric 0 Jul 23, 2012 12:40 PM
Discussion Miss Elam Questions! Sublime_Slayer Racing Boats - Internal Combustion 1 Oct 03, 2009 01:36 PM
Discussion Miss Elam, Miss Llumar, Miss Bud tip Massey Racing Boats - Internal Combustion 5 Aug 12, 2006 04:14 PM
Miss Elam U-4 canard hydroplane reaper Racing Boats - Electric 3 Jun 28, 2004 01:04 PM
