Old May 15, 2014, 09:31 PM
No mods no glory!
micromantis's Avatar
United States, CA, Redwood City
Joined Nov 2010
RocHobby/FMS Voodoo/Strega, Critical Mass and FG2 Super Corsiar modification Thread
Dedicated modification thread to the RocHobby/FMS Reno Racer's.
Voodoo P-51 1070mm
Strega P-51 1070mm
Critical Mass 1100mm
F2G Super Corsair 1100mm
micromantis is offline Find More Posts by micromantis
Old May 15, 2014, 09:55 PM
No mods no glory!
Joined Nov 2010
Here is mine, 100+ flight's on it and counting. Great looking plane!
We had been discussing mod's on the Strega thread and Critical Mass thread.
Mine has the following mods:
14grams of weight added to the nose (If flying with a 4S 3300mAh pack)
Great Planes 2.5" spinner
APC 10X10E prop (you will have to enlarge the holes on the Great Planes spinner for the prop to fit, quick fix with an Exacto knife or other sharp blade)
Bigfoot Tacon 10 1100kv motor (drops right in with the supplied motor mount, no need for flipping the shaft the supplied prop adapter will fit, it will be a close fit but it will work)
Castle Creations Lite Ice 100Amp ESC (Be sure to set your ECS timing to LOW so you don't roast your motor. You can also add a hard stop on the motor if your landing on grass not to pop your prop)
Thunder Power 4S 3300mAh battery
Painted tail, wing tips and canopy.
Extreme 3M packing tape added to the ailerons and elevator to keep them in place.
Old May 15, 2014, 10:06 PM
No mods no glory!
Joined Nov 2010
A 70Amp ESC will also work with the Tacon 10/APC 10x10/4S combo.
Old May 15, 2014, 11:03 PM
T-CAT's Avatar
Joined Aug 2008
That'a boy. This plane needed it's own thread simply for ease of search for new owners and because the Voodoo is one of the best pai t schemes on the planet .
In your description, just so nobody gets tripped up, you may want to change the spinner description to Great Planes instead of Dubro. It looks like you have the GP with aluminum backplate.
T-CAT is offline Find More Posts by T-CAT
Old May 15, 2014, 11:09 PM
No mods no glory!
Joined Nov 2010
Right on! Voodoo needed it's own place indeed and your right it was a GP spinner. My bad!
Old May 15, 2014, 11:15 PM
No mods no glory!
Joined Nov 2010
I'm going to take some Amp and Watt readings this weekend . If I'm lucky maybe some will bring a radar gun this weekend to the field so I can get some speed readings as well.
Old May 15, 2014, 11:30 PM
T-CAT's Avatar
Joined Aug 2008
I'll do the same man, and we'll compare to make sure we're as accurate as we can be.
Old May 15, 2014, 11:43 PM
No mods no glory!
Joined Nov 2010
Sounds good!
Old May 16, 2014, 12:01 AM
Comin' in HOT!
tdford's Avatar
United States, CO, Denver
Joined Dec 2012
Originally Posted by micromantis View Post
Voodoo needed it's own thread!
Available at: http://www.motionrc.com/
Same P51 airframe as the Strega, there is a lot of information in that thread: http://www.rcgroups.com/forums/showthread.php?t=1980910
Do what you must, but I don't see multiple threads for different paint schemes on other birds.
tdford is offline Find More Posts by tdford
Latest blog entry: Freewing 90mm F-18 v2
Old May 16, 2014, 01:04 AM
taz101's Avatar
Australia, QLD, Oxenford
Joined Oct 2010
+1
There is two threads for the big 1875mm B-17. One for the OD Green Memphis Belle and one for the Silver Liberty Belle.
It is a pain in the rear!!
Guys will post the same question in both threads, yet they only get answers on the Memphis Belle thread. Then they have another question and post it on both threads, again getting multiple answers on the M B thread.
So the Liberty belle thread is nothing but unanswered questions.
Plus this one has been started buy a plane that is not even stock from the get go.
So someone finds the thread reads the first couple of posts and thinks that the plane will be no good in stock form!!
And it was also discussed in the Strega thread to keep it there!
LURCH
taz101 is online now Find More Posts by taz101
Old May 16, 2014, 01:10 AM
T-CAT's Avatar
Joined Aug 2008
This thread can be a Voodoo/Strega/F2/Critical Mass modification thread instead if the original poster agrees. Since they all have the same motor, it's an easy source for modders to look at various setups that people have used.
Old May 16, 2014, 06:48 AM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I have mine stock with the 11x12 apc, fast enough I'm north swapping motors and esc's yet. Flys great.
Evan D is online now Find More Posts by Evan D
Old May 16, 2014, 09:27 AM
Joined Nov 2003
Has anyone gotten a clear radar gun reading on the stock 4S setup? I have read loads of bs and conjecture about how fast this and the Strega are, but have seen no solid number.
Clingman is offline Find More Posts by Clingman
Old May 16, 2014, 09:37 AM
Terror of the Skies
Ace High's Avatar
Canada, BC, Langley
Joined Mar 2013
Personally, I like the idea to have this as a modders type thread . See you guys doing lots of easy great mods here and I can find them quickly if I decide to try them. Much better than trying to find them in the orignal threads
Ace High is online now Find More Posts by Ace High
Old May 16, 2014, 10:27 AM
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
Great looking model! I wonder if they will be at the RCX Expo this weekend.
TimJohnson is offline Find More Posts by TimJohnson
Discussion Durafly P-51 compared to FMS P-51 ? Shung Electric Warbirds 9 Feb 25, 2014 08:05 PM
Wanted Airfield..FMS..1400 P-51 Spinners.... eggsplurt Aircraft - Electric - Airplanes (FS/W) 1 Sep 17, 2013 10:45 PM
