Old Feb 12, 2012, 12:14 AM
NanoDave's Avatar
Los Angeles, Ca
Joined Jul 2004
New Product
Speed Shark from Nanoplanes.net
I finally got around to getting the New Balsa Speed Shark prototype done.
Here are some pictures of the progress at the moment. I've already noted some minor changes that need to be done to the design, mainly a thinner fuselage aft section with more curves to look similar to our Nanoshark.
After I conclude more flight testing and build a second prototype with the updates I should be ready to produce the kits.
Hopefully these will be available in the next month or two.
The Red plane is the NEW Balsa Speed Shark prototype.
The Blue plane is the Balsa Babyshark already available.
NanoDave is online now Find More Posts by NanoDave
Old Feb 12, 2012, 12:32 AM
Potage, MI
Joined Dec 2003
I keep looking at the Balsa Babyshark but this is even more appealing. It will be a little easier to see as it speeds by!
Vince
Vince53 is offline Find More Posts by Vince53
Old Feb 12, 2012, 12:48 AM
Sure it'll work
Flyextreme's Avatar
United States, CA, Torrance
Joined Nov 2005
Are you not making depron kits any more? I don't see any "in stock".
Have any specs on the Speed Shark?
Flyextreme is offline Find More Posts by Flyextreme
Old Feb 12, 2012, 07:48 AM
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
Looks good!
I'm not even finished building my Babyshark yet, and I want one of these!
Rodan is offline Find More Posts by Rodan
Old Feb 12, 2012, 10:25 AM
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
What is the power setup and specs if you have them handy?
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Feb 12, 2012, 12:55 PM
NanoDave's Avatar
Los Angeles, Ca
Joined Jul 2004
Hey Guys
Here are the specs:
Wing span =....................................... 32"
Length =............................................. 24" (tip of spinner to tip of rudder)
Dry Weight =......................................13.4 oz
RTF wgt with 1900mah 11.1v 45C = 19.2 oz
(Will fit up to 1900 mah 14.8v 45)
Motor =............................................Micro Dan MD 2510-2700kv
ESC =.............................................ZTW 60 Amp or 85 Amp (I used 85 amp)
Lipo =..............................................Nan opower 1900mah 3S or 1900mah 4S
Elevator Servo =............................ HS-55
Wing Servos =............................... D47 x 2
So far I've only test flew it a few times yesterday on the 3S set up. I'm waiting on some new batteries to try it on 4S. Can't wait!
It flies like it's on rails like a pylon racer. The wing seems to hold up to the same abuse I usually put the Balsa Babyshark through, but so far the testing has only been on 3S... Really itching to try a 4S!
If you look at the MicroDan spec for the 2510-2700kv motor it is pretty impressive. I'm eager to try a 5.25 x 6.25 prop on 4S and see what happens
I took some video of the maiden and a couple of flights after too. I'll try to post a video later tonight after flying it some more today. I'll also be taking some more video this afternoon. Hopefully i'll get some good shots.
Old Feb 12, 2012, 01:17 PM
NanoDave's Avatar
Los Angeles, Ca
Joined Jul 2004
We are definitely continuing the Depron Shark kits. It simply sold completely out after the AMA expo and AEF. The new stock of kits should arrive by the end of next week
Old Feb 12, 2012, 01:51 PM
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
If this plane flies as great as the BBS(and I am willing to bet it does)I hope you can keep up with the orders!The tracking and performance on the lil one is truely awsome,turns heads anytime I fly it,problem is I have to turn my own head faster then everybody else whos just watching....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Feb 12, 2012, 04:13 PM
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Awesome Dave....I'm all in...will you have some kits that are kinda ARF.......I can't take time to build .....my Fishin Fever has got me down.......Like Joe...I'm SOooo impressed at these Nanos....man they are smooth...Keep up the Great Innovations....Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Feb 12, 2012, 05:28 PM
fh64_lucky's Avatar
Joined May 2005
Back off Billy,1st kit is mine!!!
Old Feb 12, 2012, 05:33 PM
stanordave's Avatar
Joined Jan 2006
I just ordered a BBS yesterday but this is the size I really want! Well maybe I can practice my visual acuity on the Baby..
stanordave is offline Find More Posts by stanordave
Old Feb 12, 2012, 07:46 PM
When in doubt, gas it!
KTMRacr's Avatar
United States, KS, Spring Hill
Joined Dec 2010
Totally bitchin! I will definitely be trying this one out!
KTMRacr is offline Find More Posts by KTMRacr
Old Feb 12, 2012, 11:44 PM
NanoDave's Avatar
Los Angeles, Ca
Joined Jul 2004
Thanks guys!
I'm really glad you like it. Hopefully many others will too...
We had a really good day of testing this plane out today. It flew great! Handles beautifully! It flies fast like it's on rails, and glides almost like a glider. Take offs are super easy and landings are also super easy, it just floats beautifully for a soft touch down.
The only thing we still haven't been able to test is the 4S set up. I think that will take some time as I need to order some Nano power lipos in the size we need: 1900mah 14.8v 45C.
Mean time I can't seem to find a suitable alternative that is in stock. bummer.
So anyways, I'm uploading a video to youtube right now and will post the link in about 20 minutes...
I decided to post the FUN video first where Adam is punishing the airframe with some high G's
Once we get the 4S pack then I'll post some speed run videos...
Old Feb 13, 2012, 12:00 AM
NanoDave's Avatar
Los Angeles, Ca
Joined Jul 2004
Sorry Billy,
For the time being, I'm not going to be able to take orders. I really need to spend my spare time creating and designing new planes. When I can make some time in the future I'll try to let you guys know.
Old Feb 13, 2012, 12:01 AM
NanoDave's Avatar
Los Angeles, Ca
Joined Jul 2004
ok guys here is the video!
Enjoy!
Balsa Speed Shark Prototype by Nanoplanes (3 min 5 sec)
Rave Micro Pylons - RTF / Nanoplanes.net epwierman High Performance 26 Dec 20, 2011 11:08 PM
Discussion Baby Shark by nanoplanes.net epwierman Foamies (Kits) 2 Apr 01, 2011 12:42 PM
Mini-Review Nanoshark from nanoplanes.net Frojd Foamies (Kits) 62 Sep 07, 2008 04:38 PM
Discussion NanoPlanes Shark w/ GWS Speed 400 jkarnacki Foamies (Scratchbuilt) 11 Jan 17, 2008 12:04 PM
Discussion New 3D Nano Shark by Nanoplanes.net NanoDave 3D Flying 12 Sep 28, 2005 02:20 PM
