Jan 23, 2008, 09:04 PM
Houston, Tx
Joined Oct 2006
It can work if you have the correct prop and gear. The prop will determine the current draw on the battery, too big and you get a flaming ESC, too small and you don't get off the ground.
I would change your connectors to something standardized that you will use from here on out. Deans would be the connector of choice. But, yes you can change the connector on either the battery or the ESC. Battery being the more problematic choice since it could go up in flames if you short the leads.
Good luck and good flying,
John
