Old Oct 10, 2002, 04:25 PM
RandyK1 is offline
Find More Posts by RandyK1
Fiberglass dont bounce???
RandyK1's Avatar
Zion, Il.
Joined Sep 2002
Use of Locktite on props.?
I am looking at my new 14x9.5 cam folder prop. and I am thinking (if this thing comes apart it could be scary). Should I use Locktite on the prop. parts (on the screws that attach the blades to the hub)and if so what # Locktite should I use (if I want to take it apart at a later date to switch blades)? Should I use Locktite on my motor mount screws also (Axi motor)?
Thanks for your help R
RandyK1 is offline Find More Posts by RandyK1
Old Oct 10, 2002, 04:36 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Randy,
Yes, it is generally good sidea to loctite the rotating part. You use almost any kind of loctite, even a drop of paint will do.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Oct 10, 2002, 06:10 PM
Konratz is offline
Find More Posts by Konratz
San Francisco CA
Joined Jan 2002
Randy,
You should use locktite or thread locking compound an any rotating metal to metal fastener you don't want to vibrate apart. Be this a press fit of threaded fastener. Do not use Locktite on plastice parts as it can (and does) damage the plasticizeres in most plastics. This includes the nylon in nylock nuts!
Konrad
Konratz is offline Find More Posts by Konratz
Old Oct 11, 2002, 06:22 AM
fledge is offline
Find More Posts by fledge
fledge's Avatar
in front of p c
Joined Aug 2002
removal
i agree that it sounds like a wise choice to use locktite for the safety issue but how the heck do you guys remove the screws after you have used it?? from my experience;allen screws have a bad habit of striping off when trying to remove them,i cant imagine how lucky you would have to be to get them out if they were put in with loctite,,,please explain ;do you add heat to remove the screws?
fledge
fledge is offline Find More Posts by fledge
Old Oct 11, 2002, 11:42 AM
kaboom is offline
Find More Posts by kaboom
Brampton, Canada
Joined Jun 2002
I use tamiya locktight on everything. Its meant for the rc car guys But I find in works great on the prop nut of my hotliner. It holds tight but can be taken apart without damaging any important parts.
kaboom is offline Find More Posts by kaboom
Old Oct 11, 2002, 06:53 PM
Konratz is offline
San Francisco CA
Joined Jan 2002
fledge,
Locktite comes in many grades, with strengths that range from that of sugar syrup to bonds that would rival a welded joint. See their web site for what will meet your needs.
To release the bond of some of the higher-strength grades will require heat. I apply heat to the fastener with a "sacrificial tool" ( Allen wrench, screw driver etc). The reason I call it a "sacrificial tool" is that I heat the tip in a flame until it's red (and this will remove the temper from the tool). I then place it in the fastener until most of the heat has been transfered to the fastener. I then wait for the fastener to cool down, as the fastener will have expanded when it was hot, making the joint even tighter. (This cool-down step is not required with fasteners that hold from the inside, such as nuts). Use a tempered tool to remove the fastener.
Good luck,
Konrad
Old Oct 12, 2002, 12:02 PM
GregF is offline
Find More Posts by GregF
Joined Oct 2002
If they still use the same color scheme, Loctite Red is very high strength, and Loctite Blue is medium strength that holds well but can be taken apart fairly easily. I like Kontratz's technique using heat, seems like a good idea for small set screws.
GregF is offline Find More Posts by GregF
Old Oct 12, 2002, 05:44 PM
Roger P is offline
Find More Posts by Roger P
Roger P's Avatar
San Diego
Joined Aug 2002
A believer
I just posted a sad report under high speed/javelin. Lost half the prop in flight and vibration led to a crash. I will be a user from now on.
Roger P is offline Find More Posts by Roger P
Old Oct 14, 2002, 12:07 AM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
Yup
I'm a careless builder didn't loctite a prop and ruined a very expensive 10 cell fully molded glider wing as a result.
there are a lot of ways to go wrong in this hobby and prop blades falling off at the end of the runway on a practice landing is one of them. The two useless things in this sport:
The sky above
The runway behind
davidleitch is offline Find More Posts by davidleitch
How can I use APC SF props on GWS gearbox? czechyour6 Power Systems 8 Mar 28, 2005 09:35 AM
How to use APC slowfly props on a stock GWS gear drive? tileflyer 3D Flying 4 Jul 09, 2004 07:58 AM
Use of Locktite on props.? RandyK1 Beginner Training Area (Aircraft-Electric) 2 Oct 10, 2002 05:11 PM
Gunther push-on props totalboss Electric Plane Talk 2 May 15, 2001 07:57 PM
Source for Gunther push-on props ? Greg Covey Electric Plane Talk 4 May 10, 2001 12:30 AM
