Old Feb 09, 2015, 10:44 AM
nikpik97 is offline
Find More Posts by nikpik97
Joined Feb 2015
Help!
First Quadcopter. Need help with determining compatibility among other things.
Hi, this is my first post on this forum so I guess I should introduce myself. I am a high school senior and the president of computer/technology club at my school and I'm thinking of majoring in computer engineering in college. I've recently gotten interested in multi rotors and I decided it might be a good club project to build one. Obviously, we want more out of this but I feel it should be a good starting point. Based on this thread: http://www.rcgroups.com/forums/showthread.php?t=1965226
I changed some parts:
4xhttp://hobbyking.com/hobbyking/store/__23091__Carbon_Fiber_Main_Frame_Base_Plate_HK_550 GT.html
1xhttp://hobbyking.com/hobbyking/store/__22322__MultiWii_NanoWii_ATmega32U4_Micro_Flight_ Controller_USB_GYRO_ACC.html
1xhttp://www.hobbyking.com/hobbyking/store/__24899__Turnigy_4X_FHSS_2_4ghz_Transmitter_and_Re ceiver_Mode_1_.html
1xhttp://hobbyking.com/hobbyking/store/__6816__Carbon_Fiber_Tube_hollow_10x750mm.html
4xhttp://hobbyking.com/hobbyking/store/__11429__HobbyKing_12A_BlueSeries_Brushless_Speed_ Controller.html
4xhttp://www.myrcmart.com/zmr-1804-2400kv-micro-outrunner-brushless-motor-anticlockwise-p-6280.html?osCsid=a5au22opn4tv4tdulcvdlv2vl7
2xhttp://hobbyking.com/hobbyking/store/__27902__Counter_Rotating_Three_Blade_5x4_5_Propel ler_Black_1Pair_Bag_.html
1xhttp://www.himodel.com/multi_rotors/D3mm_Shock_Absorbing_Screws_4pcs.html
1xhttp://www.hobbyking.com/hobbyking/store/__9394__Turnigy_2200mAh_3S_30C_Lipo_Pack.html
My goal was to keep it under $250 and it seems that it would meet that goal. I'm not sure of the compatibility, hence why I'm asking. The other members wanted to do programming and other things so hopefully. Maybe something like an arduflyer would be better for the flight controller. Please suggest anything that should be changed. Thanks!!!
nikpik97 is offline Find More Posts by nikpik97
Old Feb 09, 2015, 11:52 AM
Waterbound is offline
Find More Posts by Waterbound
United States, MD, Annapolis
Joined Jun 2013
you might want to include the links so you don't have to copy and paste each one..
Waterbound is offline Find More Posts by Waterbound
Latest blog entry: Hubsan H107D Custom FPV Setup
Old Feb 09, 2015, 12:28 PM
waltr is online now
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
The RCX1804 motors are good for an AUW weight of about 400gram and lower. If the copter is heaver than this you need larger motors.
This means that a 2200mAh battery wiil take it over the minimum weight. A 800 to 1000mAh battery is about right for these motors.
Instead of all that HK stuff just buy the ZMR X250 bare bones kit from myrcmart. This was my first copter and it flies well.
waltr is online now Find More Posts by waltr
Old Feb 10, 2015, 09:28 AM
nikpik97 is offline
Joined Feb 2015
Thanks for the suggestion. I guess that should make it easier on me. I apologize for not posting it the links properly. I didn't know how at the time
Help! Need help with a few things on my first build. mike_drz Scale Kit/Scratch Built 17 Dec 07, 2014 11:03 AM
Discussion need help determining what i need to do to fly mirorless with my tarot 650 x8 up patrickrebstock Multirotor Power Systems 0 Oct 07, 2014 04:12 PM
Help! can you check my motors, among other things. noxxxx Multirotor Power Systems 1 Apr 26, 2014 08:59 AM
Discussion can you check my motors, among other things. noxxxx Multirotor Power Systems 0 Apr 25, 2014 11:30 PM
Crutch questions (among other things) Heli Mod Man Electric Heli Talk 24 Oct 31, 2004 05:00 PM
