Old Jan 03, 2015, 05:25 PM
ecreative is offline
Find More Posts by ecreative
It's all about Quadcopters
United Kingdom, England, Surrey
Joined Nov 2012
Help!
Eagle Routing Sizes and 3x6 Header Pins
Hi,
I have two problems which I'm hoping you cleaver people will able to help me with.
First what should the routing (thread) size be in eagle for a power distribution board with a 3/4s attached?
Second is there a 3x6 header pin in the eagle library or a downloadable one because i can't find one.
Thank you
ecreative is offline Find More Posts by ecreative
Old Jan 04, 2015, 07:19 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
1. If you're dealing with a lot of current, make the traces as big as possible. You can use the Draw function to create large rectangle areas where the copper is not removed, making them even larger.
2. Use three 1 x 6's instead. If the grid is set properly, they will snap into position and the board will be the same as if you used a single 3 x 6.
dmccormick001 is offline Find More Posts by dmccormick001
Old Jan 04, 2015, 09:13 AM
Joined Nov 2012
Legend! Thank you
Old Jan 04, 2015, 09:14 AM
Joined Nov 2012
Also is the best bet to run power on one side and negative and signal on the other of the pcb
Old Jan 05, 2015, 03:23 AM
jakestew is online now
Find More Posts by jakestew
United States, ID
Joined Sep 2011
You can save yourself a lot of time and frustration by using the SparkFun Eagle library and rules/settings.
There's a lot of settings you'll probably never find, so just get the DRC rules file from sparkfun.
jakestew is online now Find More Posts by jakestew
For Sale 3 x 40 pin Break Away Headers - Right Angle fm_head Aircraft - Electric - Multirotor (FS/W) 0 Nov 09, 2014 09:15 AM
Wanted 3x** Right Angle Pin Headers punkindrublik Aircraft - Electric - Multirotor (FS/W) 3 Sep 25, 2014 07:28 PM
Help! Where can I find M-F 3 way 90 degree header pins? geekness DIY Electronics 6 Nov 17, 2013 06:30 PM
Found 8x3 pin headers for TBS disco bigddybn Aircraft - Electric - Multirotor (FS/W) 8 Nov 10, 2013 09:44 AM
Question AR500 end pin modding (group purchase header pins) Kbofwy Radios 0 Feb 05, 2009 03:10 PM
